09-25-2017, 16:32 | #19141 (permalink) |
No Life Poster Join Date: Aug 2009 Location: Germany
Member: 1087322 Status: Offline Thanks Meter: 173 | Code: Waiting ADB device... OK Lese Telefoninfo... Model: GT-S7580 Android version: 4.2.2 Produkt Code: Phone version: S7580XXUBOA1 PDA version: S7580XXUBOA1 CSC version: S7580OXXBOA1 CSC country code: Germany CSC sales code: DBT HW version: MP 0.102 Phone SN: xxxxxxxxxx Modem board: RF cal date: 20141017 IMEI: 355xxxxxxxxxxxxxx Checking Super user right... korrekt Reading data from phone... OK Entsperren... OK Neustart des Handys..... OK Unlock done Done with Samsung Tool PRO v.29.4 |
09-26-2017, 14:46 | #19142 (permalink) |
No Life Poster Join Date: May 2014 Location: D.I.Khan [KPK] Age: 35
Member: 2192499 Status: Offline Sonork: Stopped using.. Thanks Meter: 1,763 | SM-A310F FRP Removed Successfully 7.0 Cheers to z3x Code: Operation: Reset FRP Selected model: SM-A310F Software version: 29.4 Waiting ADB device... OK Reading phone info... Model: SM-A310F Android version: 7.0 Product code: Phone version: PDA version: A310FXXU3CQF5 CSC version: A310FOJV3CQF6 CSC country code: UAE CSC sales code: XSG HW version: Phone SN: R28J22NZ5HL Chip name: EXYNOS7580 Modem board: Security patch: 2017-06-01 RF cal date: IMEI: Bypass FRP... OK For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.29.4 |
The Following 2 Users Say Thank You to EjazATF For This Useful Post: |
09-26-2017, 15:15 | #19143 (permalink) |
Freak Poster Join Date: Apr 2016 Location: the boss of samsung
Member: 2558211 Status: Offline Thanks Meter: 90 | UNLOCK INSTRUCTIONS: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. To reset Google account activation or Samsung reactivation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Reset FRP/React/EE Selected model: SM-J105B Software version: 29.4 Searching Samsung USB Flash interface... COM19 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP lock... OK Reset done For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.29.4 |
09-26-2017, 16:53 | #19144 (permalink) |
No Life Poster Join Date: Oct 2005 Location: TITI 2002 SERVIS CELULAR PG/AL
Member: 193804 Status: Offline Sonork: 100.1684818 Thanks Meter: 1,693 | Operation: Read Codes Selected model: SM-J120AZ Software version: 29.4 Waiting ADB device... OK Reading phone info... Model: SAMSUNG-SM-J120AZ Android version: 6.0.1 Product code: SM2J120AZKZAIO Phone version: J120AZTUS3AQE1 PDA version: J120AZTUS3AQE1 CSC version: J120AZAIO3AQE1 CSC country code: USA CSC sales code: AIO HW version: REV0.3 Phone SN: R58H55HSM8J Chip name: EXYNOS3475 Modem board: SHANNON308 Security patch: 2017-05-01 RF cal date: 20160531 IMEI: 356419073961809 Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Initialization data... OK Writing zTool... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data... OK HWID: BB 8A EC 50 B7 85 89 BA 7D 3E B3 D4 FD 01 DB B3 Calculating... OK Checking hash file... OK Please wait, calculating codes... OK (time - 00:00:02) Freeze code: 27247061 NET lock: 26291819 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.29.4 |
09-27-2017, 11:30 | #19145 (permalink) |
No Life Poster Join Date: Sep 2011 Location: Dhaka,Bangldesh
Member: 1659078 Status: Offline Sonork: Mahidi Munna Thanks Meter: 199 | G928F Frp Remove Done UFS Methood Operation: Reset FRP UFS Selected model: SM-G928F Selected port: COM86 Prolific USB-to-Serial Comm Port Software version: 29.4 Hold 'Vol down' and press 'POWER ON' for 2-3 seconds Checking phone at COM86 OK Phone detected, do not release 'Vol down' Reading data from phone... OK Release 'Vol down' now Comparing selected model... match (G928F) Setup connection... OK Reseting FRP... OK Rebooting phone... OK Reset FRP done Done with Samsung Tool PRO v.29.4 |
09-27-2017, 14:41 | #19146 (permalink) |
No Life Poster Join Date: Sep 2016 Location: IN THIS WORLD Age: 33
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore or press 'Write CERT' to restore certificates. To backup/restore QCN, phone diagnostic port must be enabled. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Type *#9090# and select 'DM/DUN over HSIC'. Or use 'Activate Diag' function from 'Repair' tab. 4. Connect the phone to PC with USB cable, install drivers if needed. 5. Select diagnostic port in port settings. 6. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore. Operation: Write CERT Selected model: SM-J500FN Selected port: COM81 ?SAMSUNG Mobile USB Serial Port Software version: 29.3.1 Checking CERT file... OK KEY ID: 0151 Waiting ADB device... OK Reading phone info... Model: SM-J500FN Android version: 5.1.1 Product code: SM-J500FZKAEUR Phone version: J500FNXXU1APL1 PDA version: FA51_J500FNXXU1APL1 CSC version: CSC country code: CSC sales code: HW version: MP 0.400 Phone SN: RV8G809XJ2R Modem board: MSM8916 RF cal date: 2015.08.13 IMEI: 3xxxxxxxxxxxxx Writing AT RIL... OK Initialization AT RIL... OK Bypass MSL... OK Checking for compatible phone and cert... OK Phone KEY ID: 0151 Writing CERT... OK Checking CERT status... OK Rebooting phone... OK Done with Samsung Tool PRO v.29.3.1 |
09-27-2017, 15:44 | #19147 (permalink) |
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options' for Android 4.0 - 4.1.2 or tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options' in Android 4.2+. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore. 6. Press 'Read CERT' button to read certificates or 'Write CERT' to restore. 7. Press 'Write NV DATA' if you need to restore NV backup. Operation: Read CERT Selected model: GT-I9500 Software version: 29.3.1 Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: GT-I9500 Android version: 5.0.1 Product code: GT-I9500ZWATUR Phone version: I9500XXUHPC1 PDA version: I9500XXUHPJ3 CSC version: I9500OJVHPK1 CSC country code: TURKEY CSC sales code: TUR HW version: MP 0.800 Phone SN: R31F301L76J Modem board: XMM6360 Security patch: 2016-10-01 RF cal date: 2014.3.15 IMEI: 2515925302514f0 Checking Super user right... true Reading NV data... OK Checking magic... OK Running zTool, please wait... OK Detected new type of security version 1 Calculating... OK Certificate file saved to C:\Program Files (x86)\Z3X\Samsung\SamsungToolPRO\backup\Cert\GT-I9500_351612064509448_R31F301L76J_27-9-2017_17-40-27.cert Done with Samsung Tool PRO v.29.3.1 |
09-27-2017, 15:53 | #19148 (permalink) |
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options' for Android 4.0 - 4.1.2 or tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options' in Android 4.2+. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore. 6. Press 'Read CERT' button to read certificates or 'Write CERT' to restore. 7. Press 'Write NV DATA' if you need to restore NV backup. Operation: Write CERT Selected model: GT-I9500 Software version: 29.3.1 Checking CERT file... OK KEY ID: 0833 Waiting ADB device... OK Reading phone info... Model: GT-I9500 Android version: 5.0.1 Product code: GT-I9500ZWATUR Phone version: I9500XXUHOA7 PDA version: I9500XXUHPJ3 CSC version: I9500OJVHPK1 CSC country code: TURKEY CSC sales code: TUR HW version: MP 0.800 Phone SN: R31F301L76J Modem board: XMM6360 Security patch: 2016-10-01 RF cal date: 2014.3.15 IMEI: 2xxxxxxxxxxxxxxx Checking Super user right... true Reading NV data... OK Checking magic... OK Running zTool, please wait... OK Detected new type of security version 1 Calculating... OK Writing NV Data... OK Rebooting phone... OK Write CERT done Done with Samsung Tool PRO v.29.3.1 |
09-27-2017, 17:58 | #19149 (permalink) |
Freak Poster Join Date: Mar 2007 Location: u.k
Member: 467279 Status: Offline Thanks Meter: 42 | lg k4 kg 120e done LG 2-3G Tool v9.35 supported models: 1445 Elapsed: 10 secs. --> (v9.35) Model name: LG-K120E Software verion: K12011a Android verion: 5.1.1 IMEI: 357137078702478 Reading... done IMEI_1: IMEI_2: NCK: 1918179601296940 SPCK: 9583760952565018 NSCK: 0221204148270775 CPCK: 9584335227991966 SIMCK: 0364495591755059 Sec zone saved: ..\Backup\LG-K120E_357137078702478_27092017_174659.lgsb1 Reboot... Elapsed: 5 secs. --> (v9.35) |
09-27-2017, 19:35 | #19150 (permalink) |
Junior Member Join Date: Feb 2006
Member: 229861 Status: Offline Thanks Meter: 8 | unlock not done Searching Samsung modem... detected COM558 Reading phone info... OK Model: SM-G955FD AP version: G955FXXU1AQH3 CSC version: G955FOXM1AQH3 CP version: G955FXXU1AQH3 Product code: MID Phone SN: R58J56FM7TT Unique number: CE041714C283909F0D Reading IMEI... OK IMEI: 3591160816------ Reading SN... OK Phone SN: R58J5----- Enter MSL: 181A504+------------------------ Bypass MSL... OK Unlocking... OK Codes set to 00000000 Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.29.4 after the process i insert the sim and use 00000000 and say incorrect |
09-28-2017, 14:39 | #19151 (permalink) |
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore. 6. Press 'Read CERT' button to read certificates or 'Write CERT' to restore. 7. Press 'Write NV DATA' if you need to restore NV backup. Operation: Write CERT Selected model: SM-N910C Software version: 29.4 Checking CERT file... OK KEY ID: 0065 Waiting ADB device... OK Reading phone info... Model: SM-N910C Android version: 6.0.1 Product code: SM-N910CZKETUR Phone version: N910CXXU1DPI1 PDA version: N910CXXS2DQHG CSC version: N910CQOJT2DPJ3 CSC country code: TCS CSC sales code: TUR HW version: MP 0.800 Phone SN: RF8G52C19GA Modem board: DB7450R Security patch: 2017-08-01 RF cal date: 2015.05.30 IMEI: 355843063882173 Checking Super user right... true Reading NV data... OK Analyzing NV data... OK Writing NV Data... OK Rebooting phone... OK Waiting ADB device... OK Reading phone info... Model: SM-N910C Android version: 6.0.1 Product code: SM-N910CZKETUR Phone version: N910CXXU1DPI1 PDA version: N910CXXS2DQHG CSC version: N910CQOJT2DPJ3 CSC country code: TURKEY CSC sales code: TUR HW version: MP 0.800 Phone SN: RF8G52C19GA Modem board: DB7450R Security patch: 2017-08-01 RF cal date: 2015.05.30 IMEI: 3XXXXXXXXXXXXXXX Writing AT RIL... OK Initialization AT RIL... root required Checking Super user right... true Initialization AT RIL... OK Bypass MSL... OK Checking for compatible phone and cert... OK Phone KEY ID: 0065 Writing CERT... OK Checking CERT status... OK Rebooting phone... OK Write CERT done Done with Samsung Tool PRO v.29.4 |
09-28-2017, 15:56 | #19152 (permalink) |
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | REPAIR INSTRUCTIONS: Repair IMEI/Serial/BT/WiFi/Product Code: 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Reboot phone. 4. Connect USB cable, install drivers if needed. 5. Select Samsung diagnostic port in port settings. 6. Press 'Reset MSL' button to deactivate security. 7. Wait till phone reboot. 8. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 9. Select device in ADB settings. 10. Fill values what you need to repair. 11. Press 'Repair' button. Reset EFS, Disable Factory Mode: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity. Backup will be created automatically. 6. If you have yellow table on your device screen, then press 'Disable Factory Mode' button. Wipe EFS/NVM: If you have 'IMEI null/null' or 'Phone baseband unknown' errors, Then you can try to repair this errors with this function. 1. Power on the phone in download mode (turn off phone, hold Volume Down + Home + Power). 2. Connect USB cable, install drivers if needed. 3. Press 'Wipe EFS/NVM' button to deactivate security. 4. Wait till phone reboot. Operation: Repair Selected model: GT-I9200 Selected port: COM99 ?SAMSUNG Mobile USB Serial Port Software version: 29.4 Waiting ADB device... OK Reading phone info... Model: GT-I9200 Android version: 4.2.2 Product code: Not Active Phone version: I9200XXUCNB1 PDA version: I9200XXUCNB1 CSC version: I9200OJVCNB1 CSC country code: Kenya CSC sales code: AFR HW version: Phone SN: RV1D66B61YN Modem board: MSM8230AB RF cal date: NONE IMEI: 3XXXXXXXXXXXXX Writing AT RIL... OK Initialization AT RIL... OK Bypass MSL OK Repairing IMEI... OK Rebooting phone... OK Repair done Done with Samsung Tool PRO v.29.4 |
09-29-2017, 04:45 | #19153 (permalink) |
No Life Poster Join Date: May 2009 Location: pattaya
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 385 | Operation: Unlock Selected model: SM-N910T Selected port: COM704 SAMSUNG Mobile USB Serial Port Software version: 29.4 Reading phone info... Reading IMEI... OK IMEI: 354594061858928 Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool PRO v.29.4 |
09-29-2017, 13:30 | #19154 (permalink) |
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. Operation: Repair Selected model: SM-J120H/DS Software version: 29.4 If you are looking for 'Repair Network' function then you should use 'Patch Certificate' Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SM-J120H Android version: 5.1.1 Product code: SM-J120HZWDCAC Phone version: J120HXXU0AQB1 PDA version: J120HXXU0AQE2 CSC version: J120HOXE0AQE1 CSC country code: Central Asia CSC sales code: CAC HW version: MP 0.400 Phone SN: R51J105ETEH Modem board: SC7727SE Security patch: 2017-05-01 RF cal date: 20170110 IMEI: 2xxxxxxxxxxxxxx Checking Super user right... true Checking MSL... OK Initialization AT RIL... OK Bypass MSL OK Repairing IMEI... OK Rebooting phone... OK Repair done Done with Samsung Tool PRO v.29.4 |
09-29-2017, 13:30 | #19155 (permalink) |
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. Operation: Patch Certificate Selected model: SM-J120H/DS Software version: 29.4 Waiting ADB device... OK Reading phone info... Model: SM-J120H Android version: 5.1.1 Product code: SM-J120HZWDCAC Phone version: J120HXXU0AQB1 PDA version: J120HXXU0AQE2 CSC version: J120HOXE0AQE1 CSC country code: Central Asia CSC sales code: CAC HW version: MP 0.400 Phone SN: R51J105ETEH Modem board: SC7727SE Security patch: 2017-05-01 RF cal date: 20170110 IMEI: 2xxxxxxxxxxxxxx Checking Super user right... true Patching CERT check... OK Rebooting phone... OK Patching CERT check... done Done with Samsung Tool PRO v.29.4 |
Post here successfully unlock or IMEI repair LG | andrew_tm | Z3X-Team Products | 1841 | 07-06-2022 14:14 |
Post here successfully unlock or IMEI repair Infinity Box | R@ZIB-BD | Infinity-Box | 3 | 07-04-2014 16:37 |
Post here successfully unlock or IMEI repair LG | R@ZIB-BD | Z3X-Team Products | 2 | 02-01-2011 17:29 |
