Old 12-25-2017, 12:22   #1 (permalink)
Member: 2701138
Thanks Meter: 2
Samsung gear s3 reactivation lock
Hi. I have SAMSUNG GEAR S3 (Model: R765)
I have Reactivation Lock.
I want try bypass it.
I need combination firmware and official firmware.
And in the samsung tool pro a don't see R765, I see R760 Only in the Z3x Shell. I from Russia, sorry my bad English. Please help me!
Old 12-28-2017, 01:52   #2 (permalink)
Member: 420658
Thanks Meter: 211
1.
Be VERY carefully with SM-R765 family/group...
NO valid Firmware leaked... nearly all obsolete...
Rollback Prevention!
Software Revision Check!!!
2.
There are whole alphabet from SM-R765...
Which one you have exactly?
SM-R765S or SM-R765L or SM-R765K from Korea?
Or
SM-R765A ATT
SM-R765T TMB
SM-R765F XSP
SM-R765V Verizon
SM-R765N New Zealand?
3.
Vnimanie...
Ochen plocho igrat drugoje Proschifki...
Moschno lamat
PM me... if you want.
Maybe we could try something...
Best Regards
The Following 3 Users Say Thank You to adfree For This Useful Post:
Old 12-28-2017, 08:25   #3 (permalink)
Member: 2701138
Thanks Meter: 2
I have SM-R765 (In odin) and i Have SM-R765S (Under Cover)
Old 12-28-2017, 17:31   #4 (permalink)
Member: 420658
Thanks Meter: 211
For SM-R765S the Korean variant...
I have only FOTA packages...
cm.bin and sboot.bin as FULL Images...
NO Firmware
NO Combination Firmware leaked.
Wrong Firmware kills SM-R765... examples:
https://forum.xda-developers.com/gea...r765s-t3665558
On this SM-R765S is WRONG BQC2 Combination Firmware flashed = DEAD
https://forum.xda-developers.com/gea...rdown-t3659431
Here on SM-R765F user flashed SM-R765T[/COLOR] = DEAD
SM-R765F Firmware available... but OLD obsolete Software Revision 1 only. But he need Software Revision 2...
Best Regards
Old 12-30-2017, 02:26   #5 (permalink)
Member: 420658
Thanks Meter: 211
RL is in STEADY partition...
SM-R720 and SM-R732 in p14
SM-R760 and SM-R770 in p15
SM-R765CRAP and SM-R775 seems p16
With Combination Firmware no problem to write empty 256 KB...
With SDB over WiFi...
But for SM-R765S nothing available.
The only IDEA... because NOT tested by me nor feedback from others...
Look at Pics...
partition.pit from SM-R775A as example...
You see STEADY is filename -
... only 1 time -
In Gear S2 more then 1 -... so not good idea to try...
NO idea if Combination Firmware mandatory...
NO idea if RISK to kill/brick or trigger Knox...
OWN RISK!
Please dump/read your PIT from SM-R765S...
So we could try to compare... if 1:1 or different...
Best Regards
File Type: zip test1.zip (537 Bytes, 539 views)
Old 12-30-2017, 02:45   #6 (permalink)
Member: 420658
Thanks Meter: 211
Usefull... IMHO.
If PIT file is dumped/readed from SM-R765S...
partition.pit
And infos from Odin screen... like Photo...
Here Warranty void is not more:
0 (0x0000)
In line with AP SWREV... Software Revision:
B:2
Maybe you can upload Photo from yours...
Best Regards
The Following 2 Users Say Thank You to adfree For This Useful Post:
Old 12-30-2017, 08:57   #7 (permalink)
Member: 420658
Thanks Meter: 211
If Software Revison 1...
Then few Combination Firmware floating around:
COMBINATION-FTMA_R765VVRU1AQC3.tar.md5
COMBINATION-FTMA_R765NXXU1AQE1.tar.md5
Samsung SM-R765V
R765N Product SW / COMBINATION File | GSM FirmWare
WARNING!!!
Not tested if good idea to flash from SM-R765V Verizon or SM-R765N Newzealand...Best Regards
Old 12-30-2017, 09:17   #8 (permalink)
Member: 420658
Thanks Meter: 211
In Z3X support...
COMBINATION_FTMA_R775AUCU1AQD1.zip
COMBINATION_FTMA_R775TUVU1AQC3.zip
COMBINATION_FTMA_R775VVRU1AQC3.zip
For SM-R775V and SM-R775T...
SM-R765A Combination Firmware looks corrupt... because only 170 MB
But same problem...
Software Revision 1 ...
And no idea if good to try...
Own risk!
Best Regards
Old 12-30-2017, 21:14   #9 (permalink)
Member: 420658
Thanks Meter: 211
Example.
How easy it is, if Combination Firmware is available.
Because ROOT...
Then easy with SDB Tool with WiFi only.
Best Regards
Old 01-04-2018, 09:10   #10 (permalink)
Member: 420658
Thanks Meter: 211
AP_R775TUVU1BQL1_usr.tar.md5
BL_R775TUVU1BQL1_usr.tar.md5
CP_R775TUVU1BQL1_CL671756_QB8299983_SIGNED.tar.md5
CSC_TMB_R775TTMB1BQL1_usr.tar.md5
Hmmm.
Team from pars_hamrah were able to offer latest Tizen 3 Firmware for SM-R775T TMB...
So in theory not impossible... as it seems.
Best Regards
Old 01-16-2018, 01:56   #11 (permalink)
Member: 420658
Thanks Meter: 211
R_Series | GSM FirmWare
Maybe contact them via Telegram or Whatsapp or...
They offered latest SM-R765A ATT Firmware...
So maybe Korean SM-R765 Firmware is not sooo far...
I have since monthSSSS no luck...
Request Firmware for SM-R765F and SM-R765(S))
Best Regards
The Following User Says Thank You to adfree For This Useful Post:
Old 01-18-2018, 03:35   #12 (permalink)
Member: 420658
Thanks Meter: 211
https://fccid.io/A3LSMR765KOR/Intern...-part1-3119898
This is how the SM-R765 looks inside...
You have 2 ways to connect USB cable.
A
POGO Connector in Rear Case/Back Cover
B.
Direct to PBA/PCB
Look here as an example for Variant A:
Best Regards
Old 01-18-2018, 04:31   #13 (permalink)
Member: 420658
Thanks Meter: 211
SM-R765 user have luck... because external POGO connector inside:
In theory this should also fit to SM-R760...
So maybe somebody could help to identify part number please.
http://forum.gsmhosting.com/vbb/12873181-post21.html
Thanx in advance.
Attached Pics... to illustrate 2 Variants of USB connection.
Best Regards
Old 02-01-2018, 23:44   #14 (permalink)
Member: 1390461
Thanks Meter: 80
have also a gear s3 frontier sm-r760 locked to samsung accound.any way to bypass the activation?
The Following User Says Thank You to upgraderazvan For This Useful Post:
Old 02-02-2018, 20:20   #15 (permalink)
Member: 420658
Thanks Meter: 211
Tiny mistake... my fault...
I have forgotten to pre add:
sdb shell
I hope this time Batch files okay...
Best Regards
Page generated in 0.28058 seconds with 9 queries
