05-01-2022, 10:19 | #50 (permalink) |
Insane Poster Join Date: Aug 2018 Location: Iran
Member: 2860421 Status: Offline Thanks Meter: 20 | UNLOCK INSTRUCTIONS: To read security codes using sever: Knox warranty does not matter. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Reset FRP Selected model: SM-J610F Software version: 44.4 Searching Samsung modem... detected COM33 Reading phone info... Model: SM-J610F AP version: J610FXXS7CUD3 CSC version: J610FOJM7CUD1 CP version: J610FXXS7CUD2 OS version: 10 Product code: THR Phone SN: RZ8K IMEI: 3534 IMEI2: 353 Unique number: CGX00EEFD07C2A5 Checking avaiable method... OK Go to 'Emergency call' and dial *#0*# If the code does not work, then reflash the phone OK Executing 1st step... OK Waiting ADB device... OK Executing 2nd step... OK Rebooting phone... OK For complete reset FRP, goto 'Settings - General management - Reset' and make 'Factory data reset' Done with Samsung Tool PRO v.44.4 [SM-J610F,Reset FRP] |
05-01-2022, 10:20 | #51 (permalink) |
Member: 2860421 Status: Offline Thanks Meter: 20 | Searching Samsung modem... detected COM34 Reading phone info... Model: SM-A217F AP version: A217FXXU6CUH1 CSC version: A217FOJM6CUH1 CP version: A217FXXU6CUG2 OS version: 11 Product code: XSG Phone SN: R58 IMEI: 351 IMEI2: 35 Checking avaiable method... OK Go to 'Emergency call' and dial *#0*# If the code does not work, then reflash the phone OK Executing 1st step... OK Waiting ADB device... OK Executing 2nd step... OK Rebooting phone... OK For complete reset FRP, goto 'Settings - General management - Reset' and make 'Factory data reset' Done with Samsung Tool PRO v.44.4 [SM-A217F,Reset FRP] |
05-01-2022, 10:22 | #52 (permalink) |
Member: 2860421 Status: Offline Thanks Meter: 20 | Searching Samsung modem... detected COM34 Reading phone info... Model: SM-A217F AP version: A217FXXU6CUH1 CSC version: A217FOJM6CUH1 CP version: A217FXXU6CUG2 OS version: 11 Product code: XSG Phone SN: R58NB3Y2GCX IMEI: 35 IMEI2: 35 Unique number: CR8100AE552C6A7 Checking avaiable method... OK Go to 'Emergency call' and dial *#0*# If the code does not work, then reflash the phone OK Executing 1st step... OK Waiting ADB device... OK Executing 2nd step... OK Rebooting phone... OK For complete reset FRP, goto 'Settings - General management - Reset' and make 'Factory data reset' Done with Samsung Tool PRO v.44.4 [SM-A217F,Reset FRP] |
05-01-2022, 11:53 | #54 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Budapest Age: 54
Member: 87188 Status: Offline Thanks Meter: 229 | Searching Samsung modem... detected COM333 Reading phone info... Model: SM-G973F AP version: G973FXXSCFUH5 CSC version: G973FODXCFUH3 CP version: G973FXXUCFUH3 OS version: 11 Product code: TMH Phone SN: RF8M812xxxx IMEI: 3587891029xxxxx IMEI2: 3587901029xxxxx Unique number: CE061936B81D05733F7E Checking avaiable method... OK Go to 'Emergency call' and dial *#0*# If the code does not work, then reflash the phone OK Executing 1st step... OK Waiting ADB device... OK Executing 2nd step... OK Rebooting phone... OK For complete reset FRP, goto 'Settings - General management - Reset' and make 'Factory data reset' Done with Samsung Tool PRO v.44.4 [SM-G973F,Reset FRP] Work. Thanks! (no more Alliance shield is needed) |
