12-28-2016, 12:30 | #1 (permalink) |
Insane Poster Join Date: Jul 2009 Location: nigeria
Member: 1074258 Status: Offline Sonork: kinglotas Thanks Meter: 28 | SCV32 invalid sim 100% [DONE] 1, Select scv32 2, Read info 3, Unlock. 4, Disconnect cable 5, Connect scv32 to wifi 6, Go to settings on SCV32 7, Click aboout 8, Click status 9, Click SIM card status 10, Click SIM lock status 11, UPDATE SIM CARD STATUS 12, DOWNLOAD NOW 13, DOWNLOAD NOW 14, OK Service will appear 15, Reboot and you will see no service 16, Select SCV32 17, Unlock 100% Done Don't forget Thanks |
The Following 21 Users Say Thank You to kinglotas For This Useful Post: |
02-16-2017, 10:06 | #2 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Z <> A Age: 49
Member: 413160 Status: Offline Sonork: 100.1657278 Thanks Meter: 96 | SCV32 invalid sim 100% DONE Z3X Done with Samsung Tool PRO v.27.6 1, Select scv32 2, Read info 3, Unlock. 4, Disconnect cable 5, Connect scv32 to wifi 6, Go to settings on SCV32 7, Click aboout 8, Click status 9, Click SIM card status 10, Click SIM lock status 11, UPDATE SIM CARD STATUS after doing this update failed any suggestion ? |
07-08-2017, 09:26 | #4 (permalink) |
No Life Poster Join Date: Dec 2003 Location: Karachi Pakistan Age: 38
Member: 47321 Status: Offline Sonork: 100.54032 Thanks Meter: 497 | Searching Samsung modem... detected COM240 Reading phone info... Ok Model: SCV32 AP version: SCV32KDU1APG2 CSC version: SCV32KDI1APG2 CP version: SCV32KDU1APG2 Product code: KDI Phone SN: R58GC0GLE4X Unique number: CR20074ACF218A2 Reading IMEI... Ok IMEI: 354912070372592 (SIGN: OK) Reading data from phone... Ok Unlocking... Ok Rebooting phone... Ok Unlock done Done with Samsung Tool PRO v.28.1 update failed |
08-21-2017, 08:56 | #5 (permalink) |
No Life Poster Join Date: Feb 2005 Location: (United States Of GINGOOG CITY Age: 47
Member: 120328 Status: Offline Thanks Meter: 243 | Searching Samsung modem... detected COM1422 Reading phone info... OK Model: SCV32 AP version: SCV32KDU1API1 CSC version: SCV32KDI1API1 CP version: SCV32KDU1API1 Product code: KDI Phone SN: R58H30N Unique number: CR20073BDF2 Reading IMEI... OK IMEI: 35491207107 (SIGN: OK) Reading data from phone... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.29.1 |
09-06-2017, 11:13 | #9 (permalink) | |
Freak Poster Join Date: Apr 2011
Member: 1556436 Status: Offline Thanks Meter: 66 | Quote:
U need to root scv32 then do a cert backup of your scv32 after that u need a custom cert ( i have it in case u need it) to write on it which will change the imei but its ok, then put a foreign sim, go to setting then update sim with wifi after that write back the original cert that u backup at first, but for some reason u might need to repeat this process manytimes to get it done and only z3x version 27.0 can do this job and i dont know why. | |
The Following User Says Thank You to samuelsteve For This Useful Post: |
09-07-2017, 06:16 | #10 (permalink) |
Junior Member Join Date: Jul 2015
Member: 2428790 Status: Offline Sonork: [email protected] Thanks Meter: 3 | |
11-03-2017, 10:51 | #12 (permalink) | |
Insane Poster Join Date: Jul 2016 Location: Nepal
Member: 2603680 Status: Offline Thanks Meter: 25 | Quote:
08-05-2018, 08:00 | #15 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Pako new road,Nepal
Member: 257603 Status: Offline Sonork: 100.1605284 Thanks Meter: 147 | scv32 unlock failed UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock. To read security codes: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read codes' button to read security codes. To read security codes via diagnostic port: 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read Codes DIAG' button to read security codes. To reset Google account activation or Samsung reactivation lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Unlock Selected model: SCV32 Software version: 33.5 Searching Samsung modem... detected COM350 Reading phone info... Model: SCV32 AP version: SCV32KDU1BQF3 CSC version: SCV32KDI1BQF3 CP version: SCV32KDU1AOL5 Product code: KDI Phone SN: R58GC0CYLGK IMEI: 354912070319924 Unique number: CR2007E29F23DA2 Reading IMEI... OK IMEI: 354912070319924 (SIGN: OK) Reading data from phone... OK Unlocking... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.33.5 sim update status failed.. any suggestion ? |
The Following User Says Thank You to jawedjp For This Useful Post: |
