09-08-2018, 10:09 | #17 (permalink) | |
Junior Member Join Date: Jun 2012 Location: Philippines
Member: 1775915 Status: Offline Sonork: jomary Thanks Meter: 1 | Quote:
09-08-2018, 10:24 | #18 (permalink) | |
Freak Poster Join Date: Apr 2011
Member: 1556436 Status: Offline Thanks Meter: 66 | Quote:
Chimera tool is best for read and write cert for this scv32 A8, z3x is full of errors. | |
09-15-2018, 13:17 | #20 (permalink) |
Freak Poster Join Date: Dec 2008 Location: Davao City, Philippines
Member: 935609 Status: Offline Thanks Meter: 154 | Heres A Solution for SCV32 invalid sim and Update Failed Files you need: Combi firmware files availableat Z3x support (COMBINATION_FAC_FA51_SCV32KDU1AOL1_FAC_CL6550526) Officiall firmware : in my case i use this SCV32KDU1AOL5_SCV32KDI1AOL5 (other version may work also) Pocedure: * flash combi firmware, after rebooting it will ask network locked code * code will reset to default ( 00000000) * input the unlock codes then hit unlock * then flash back the Official firmware....but wait, before you flash uncheck hidden, cache and modem * after rebooting it will ask again for network lock code put back the codes.. then your done this is very important before doing all the procedures inform your customer that everytime he/she switch off the phone then switch on it will ask the code |
The Following User Says Thank You to right_click For This Useful Post: |
10-15-2018, 13:04 | #21 (permalink) | |
No Life Poster Join Date: Dec 2003 Location: Karachi Pakistan Age: 38
Member: 47321 Status: Offline Sonork: 100.54032 Thanks Meter: 497 | Quote:
Thank You You solution works perfect ... | |
The Following User Says Thank You to Aamir_Zia For This Useful Post: |
01-17-2019, 11:57 | #23 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Pakistan/UAE/WorldWide
Member: 417298 Status: Offline Sonork: 100.1578269 Thanks Meter: 18,268 | Not works . after flash Combination now not accept stock firmware . always error on write system image . Still searching method write system image |
The Following User Says Thank You to Mohsin-* For This Useful Post: |
