12-02-2010, 19:07 | #77 (permalink) |
No Life Poster Join Date: Jun 2004 Location: lebanon Age: 45
Member: 68311 Status: Offline Thanks Meter: 34 | [QUOTE=alex yong;6639437]after follow your method, my iphone 3G now is ios 4.1 and the BB is 6.15, but i cannot kick it out of recovery mode, now it stay in recovery mode always... i have tried all but still the same |
12-02-2010, 20:38 | #78 (permalink) | |
Junior Member Join Date: Nov 2010
Member: 1454820 Status: Offline Thanks Meter: 13 | [QUOTE=nofear197979;6641785] Quote:
again iPhone 3G (not s) *Using 4.1 firmware NOT 4.1.2* 1)plug your phone into PC and load redsn0w_win_0.9.6b5 click to load iPhone1,2_4.1_8B117_Restore firmware then just click enter pawned DFU mode now. (nothing else) 2)load itunes it will say your phone was found in recovery mode and needs to be restored so press "shift" and point to iPhone1,2_4.1_8B117_Restore firmware - it installs and after about 10mins you get 1015 error 3) your phone will now be on the itunes USB cable screen 4) load tinyumbrella-4.21.01 it will detect a iphone just press Exit Recovery 5)Wait about 2minutes and the phone Should reboot and go back to the firmware apple loading screen - which after about 2mins does a strange apple install screen like firmware updgrade 6) After about 2mins you should be back onto the apple stock activation screen - well that is what i see becuase my phone is not unlocked 7) Go back to redsnow loading the 4.1 firmware Again NOT 4.1.2 and select jailbreak using the cydia and percent (and other options if you need except baseband) 5) once the iphone is rebooted and it should be fixed if its fixed - you can keep as it is or do the same but swaping the to firmware 4.1.2 Last edited by acid90; 12-02-2010 at 20:47. | |
The Following 11 Users Say Thank You to acid90 For This Useful Post: |
12-02-2010, 21:06 | #79 (permalink) | |
Member: 1454820 Status: Offline Thanks Meter: 13 | [QUOTE=acid90;6642083] Quote:
12-03-2010, 04:41 | #80 (permalink) | |
Freak Poster Join Date: Dec 2002 Age: 50
Member: 19190 Status: Offline Thanks Meter: 28 | [QUOTE=acid90;6642083] Quote:
i have try again and again, but it still same problem as like the picture below. | |
12-03-2010, 09:27 | #81 (permalink) | |
Member: 1454820 Status: Offline Thanks Meter: 13 | [QUOTE=alex yong;6642984] Quote:
also check out the NEW redsnow this morning https://sites.google.com/a/iphone-dev.com/files/home/redsn0w_win_0.9.6b6.zip?attredirects=0&d=1 which is use to hackivate your phone better via SAM http://www.bingner.com/SAM.html Installation This will allow you to do official activation on an iPhone without a stock SIM This is pointless on anything but an iPhone Add http://repo.bingner.com as a repo in Cydia Install "SAM" and "SAMPrefs" Follow the steps in Troubleshooting/Hacktivated with redsn0w or PwnageTool Go to Settings > SAM and click "De-Activate iPhone" Activate with iTunes If iTunes says invalid SIM, you will need to manually select the appropriate carrier under one of the methods besides "Automatic" and click on a SIMID. Troubleshooting Hacktivated with redsn0w or PwnageTool: You will need to revert to a stock lockdownd for SAM to function Option #1: redsn0w for iPhone 3G or 3GS on firmware 4.0 or later Download redsn0w 0.9.6b6 or later from http://blog.iphone-dev.org Run redsn0w and select the "Deactivate" option Option #2: my custom stockify program - works on any phone 3.0+ With SAM and SAMPrefs installed; install openssh and secure shell into your phone. Run "stockify" and it will revert your lockdownd to a stock lockdownd Reboot your phone Last edited by acid90; 12-03-2010 at 09:35. | |
12-03-2010, 12:56 | #82 (permalink) |
Junior Member Join Date: Apr 2009
Member: 1017029 Status: Offline Thanks Meter: 0 | Thanks for Posting the info about the tiny umbrella had tried all other ways with no joy. Went through the process last night and cracked the 1015 error. Been trying to get past that since last weekend. I would have been glad just to get back to the apple main screen with cydia installed. Tried the unlock this morning and managed to get the T.mob sim working. Thanks again Regards Ian H |
12-04-2010, 01:18 | #83 (permalink) |
Junior Member Join Date: Feb 2009
Member: 968593 Status: Offline Sonork: gdelacruz Thanks Meter: 0 | still stuck on recovery mode ... badly need help hi everyone, initially, successfully upgrade 3.1.2 to 4.0.1 then to 4.2.1 and unlocked. after some time of installing ipa files and sync with itunes 10.1.x my iphone crashes forcing me to reboot. unfortunately it started me in a cycle of "recovery mode" state. ----------------- for some time followed some guides to perform recovery for this issues ------------ TRIED THIS GUIDE BUT FAILED ME (1601) ERROR USING CUSTOM FW Originally Posted by mani_satcell 1.open redsnow latest version 2.browse file 4.2.1 3gs orginal firmware 3.select only this option ( just enter pwned DFU mode right now) 4.then flash with this MEGAUPLOAD - The leading online storage and file delivery service custom firmware 5.after finish flash Do redsnow jailbreak procedure ( if new bootrom means stuck in apple logo after jailbreak pls dont try to flash again just do with redsnow JUST BOOT TETHERED RIGHT NOW option and wait for boot) -------------------------------- AND STILL BACK ON RECOVERY MODE |
12-04-2010, 04:12 | #84 (permalink) |
Member: 968593 Status: Offline Sonork: gdelacruz Thanks Meter: 0 | Stuck with ios 4.2.1 BB6.15 3G THIS REALLY DRAINED MY HEAD FOR 48HRs TRYING TO RECOVER MY UNIT. GLAD DID WORK FOR ME AND HOPE CAN HELP OTHERS tried to restore using many guides and failed. this was a collection of the guides provided in this forum, just have to mixk them out and voala it worked! (make sure no sim is inserted) 1. uninstalled all apple softwares in my PC (WinXP) 2. use Windows Clean Up Utility to delete all related apple softwares (iTUnes) (Safari) (QTime) (Mobile Installation Support) (Apple Appplication Support) (Bonjour) 3. Do a fresh install of itunes (do it online), then update everything from itunes. ---------------------------- 4. Start itunes 5. Plugin ur iPhone and allow itunes to detect everthing. the close itunes. 6. Then turn off your iphone (make sure ite off) 7. use redsnow 096b5 and flash iphone using stock firmware 4.2.1 (this should take a while ending up in either in recovery mode) 8. now use ireb r2 and click ung device (for me 3G) 8. perform DFU method until your screen turns green. 7. start itune again and this time load the custome firmware. 8. use CUSTOME FIRMWARE 4.1 -->iPhone1_2_4.1_8B117_Custom_Restore.ipsw UPLOADED TO: 9. wait until itunes finishes, the cycle should take about 2 times (showing firmware restoration and firmware installatiion) 10. now your iphone lives again (take note it will be in 4.1 bb 6.15) 11.check if cydia is already available if not then use redsnow 096b5 and 4.1 stock firmware to jailbreak. 12. now perform unlock using repo666.ultrasn0w.com HOPE OTHERS HELP YOU WITH THIS Last edited by gdelacruz; 12-04-2010 at 04:22. Reason: add other info. |
12-04-2010, 04:21 | #85 (permalink) |
Member: 968593 Status: Offline Sonork: gdelacruz Thanks Meter: 0 | you can find the 4.1 custom firmware from other post for 3G, this is the hactivated version. cant upload right now.. have a little issue with my bandwidth. sorry guys. |
12-06-2010, 16:54 | #86 (permalink) |
Member: 1019531 Status: Offline Thanks Meter: 0 | I was able to get to 4.2.1! I used pwnage tool to create a custom FW with 4.2.1. I launched Pwnage tool (SIMPLE MODE)and selected iPhone1,2_4.2.1_8C148_Restore, when asked to upgrade iphone baseband to iphone select NO. Then select build. I have an AT&T sim so i selected YES to activate through itunes. After OS build i put iphone in DFU mode (blank screen). and restore with Itunes. I am going to jailbreak now and see how it goes. |
12-21-2010, 00:28 | #88 (permalink) |
Junior Member Join Date: Dec 2010
Member: 1473206 Status: Offline Thanks Meter: 0 | Help Please I tried jailbreaking my 3gs with the redsnow 0.9.6b6 and was successful till the point when it rebooted and cydia would not load. I updated the firmware to 6.15.0.0 and had checks in the ipad and cydia boxes. My problems really started when I tried to recover, i was using 4.2.1 and itunes 10.1. the recovery stalled at the end of the firmware upgrade section and is caught in a recovery loop. I can not get it out of this loop and load to any screens. I tried launching it tethered, i tried custom boot to 4.2.1 and even tried back to 4.1, both using DFU which i verified with recboot. Tinyumbrella will allow me to kick it out of the recovery cycle only till it goes through a reboot and starts the recovery loop again, on its own. Am I the only one who has this problem or can someone help please. |
01-02-2011, 02:00 | #89 (permalink) | |
Junior Member Join Date: Jan 2011
Member: 1482782 Status: Offline Thanks Meter: 0 | Quote:
musukaza/kazasho from malaysia | |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
8810 mbus-cable | zfrank | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-19-1999 13:12 |
