Old 04-21-2010, 12:00   #1 (permalink)
Stylo_GSM's Avatar
Member: 177235
Sonork: 111568
Thanks Meter: 138
iphone 3g display problem
hi,
i got a iphone 3g which is white screen which black faint stripes lines across the screen, i change screen and touch , same problem.
what could be the fault?
Old 04-22-2010, 19:42   #2 (permalink)
Member: 1252950
Thanks Meter: 2
Originally Posted by Stylo_GSM View Post
hi,
Hi everybody!
At first thanks to all iphone pros here in this forum! Really good work!
I have the same problem (iPhone 3G) and we checked everything on this phone really everything even x-rayed it in a factory that does SMD. We cannot find any damage on the logicboard. I heated with hot air station because of Wifi Problem and after this no more "real" picture on the display.
If I try restore on itunes I get error 1604. Changed lcd and whole display no help.
Does anyone know what else I can do? Thanks!
Old 04-26-2010, 19:06   #3 (permalink)
Member: 1252950
Thanks Meter: 2
Nobody an idea?
Thanks for any advice
best regards from germany
Old 04-26-2010, 21:22   #4 (permalink)
Member: 977901
Thanks Meter: 12
First of all i would change the Dockconnector and try to sync with iTunes.
It looks like a problem with the connector.
Did you've connected all connectors?
try using only the LCD cable without Touch- and sensor-cable.
worst case, you've damaged the mainboard while soldering the wifi connection.
Don't know if you can see a broken connection with x-ray?
I would try to desolder/solder the LCD connector on the board,
if you already heated the board it dosn't matter.
good luck
Old 04-26-2010, 21:38   #5 (permalink)
Member: 1252950
Thanks Meter: 2
changing dockconnector and the sync/restore I have done before. No success...
Thank you! I will try the rest and post results
Old 04-26-2010, 21:40   #6 (permalink)
Burnt Cobba's Avatar
Member: 11325
Thanks Meter: 266
Originally Posted by colonia View Post
Nobody an idea?
If you just reflowed PMB2525 and got this then logically the problem is around it. My first guess is that you overheated this IC itself. Really strange as the display IC is on the other side of the board... literally opposite. Does it get hot when left powered on as it is? Check that IC and feel it and see if it gets abnormally hot.A short near the GPS IC could be present (or this IC itself). As it is the phone is not booting up. Showing the lines and white display means nothing except that its in a critical condition.
Anyway
1. Did you clean this IC before or you just heated it directly?
2. Did you notice any solder balls after finished the reflow... just beside the IC? If yes that is a very serious one. In this case you ll have to pull it out, reball it and place it back
3. Assuming you overheated it and none of the above worked check on the other side of the board where there is the long module which is the one of wifi and bluetooth module. If there is the need replace the whole thing. The problem is somewhere there.
Sorry mate for writing all this but its hard to do guess work like this. Its like imagining something remotely.
Come back with results and more diagnosis.
Old 06-25-2010, 15:45   #7 (permalink)
Member: 1009659
Thanks Meter: 2
hi, i have the same problem. after changed the fpc nr. 3 on the board, now the display ist white with stripes. i changed teh connector, but the problem is still there..
also tried a new firmware, now the display ist already black..
Old 07-06-2010, 08:10   #8 (permalink)
Member: 936319
i have also same problem how can solve this problem many times i change tha lcd but no luck.i clean and resolder the lcd conector in board..any idea mate how to fix this problem
Old 07-06-2010, 08:28   #9 (permalink)
richello baring's Avatar
Member: 244407
Thanks Meter: 56
try to change the components beside the display ic.
Old 03-27-2011, 23:23   #10 (permalink)
i am the master's Avatar
Member: 996052
Thanks Meter: 35
i phone 3gs display problem
hello every one i got the same problem with my i phone 3gs 16gb black
well, i change the lcd connector and the lcd and done the restore aswell
nothing work at the moment
but i am still working on it as soon i workout something i will let you know guys thanks
Old 03-28-2011, 09:22   #11 (permalink)
Member: 1374074
Sonork: 100.1591605
Thanks Meter: 92
bro its might be a battery problem.
Old 04-10-2011, 00:01   #12 (permalink)
Member: 996052
Thanks Meter: 35
it allways happens when you overheat i phone pcb 1st of all it wil not show you any display at all on the screen but if you heat up pcb from battery side on display ic it might show you little bit display with lines but not proper solution available yet hopefully very soon
Old 04-10-2011, 00:13   #13 (permalink)
Member: 996052
Thanks Meter: 35
i phone display problem
hi,
hello guys,
i had same problem with my iphone 3g 8gb black
i change the lcd but no luck.
and then i change the lcd connector but still no luck.
but luckly i saw some resistor was broken on the other side of the board
next to camera connector i did't hade any resistor so i left one and i made jumper on one so this is how i solve my problem good luck to all of you
(Malik Rashid)
Old 11-13-2011, 22:48   #14 (permalink)
Member: 455842
Thanks Meter: 97
mine problem is somtime lines and some time display 100% ok ....and my set is water damge.......but connector is in good condition ......
6150 Lock Problem Zeljko Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 10-16-2013 08:16
GId1 problem old_man Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 10-18-2006 15:21
6110 5.47 sw unlock problem gsms Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 11-21-1999 19:43
HELP: Problem with 5110 Xabi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-16-1999 00:44
Page generated in 0.23507 seconds with 10 queries
