Old 03-10-2017, 18:39   #1 (permalink)
Member: 2525697
Thanks Meter: 4
iPhone 4 network issues
Hello Members, I have received a iPhone 4 and it has not network connector how can I tap.
The Following User Says Thank You to duncanzes For This Useful Post:
Old 03-11-2017, 21:37   #2 (permalink)
Member: 2694441
Same problem please...
The Following User Says Thank You to nafisnuril For This Useful Post:
Old 04-03-2017, 09:28   #3 (permalink)
Member: 2702633
I had this issue aswell and i went to a shop and they started up the phone with a computor and helped me to install everything to get it working. Go to your closest mobileshop and they can prolly help you out. Good luck with it!
The Following User Says Thank You to MobileChris For This Useful Post:
Old 04-09-2017, 20:15   #4 (permalink)
IM_
Member: 2704989
Thanks Meter: 4
you need to full flash to solve IMEI problem
chk on icloud statue.. using IMEI at any iphone info web
if Find my iphone is : locked be sure that u have icloudand password
connect your phone to ur computer and restore it from itunes
* don't restore iOS devices if find my iphone statue is locked without having icloud id and password
The Following 2 Users Say Thank You to IM_ For This Useful Post:
Old 04-17-2017, 05:32   #5 (permalink)
Member: 2707522
nice shearing thanks
The Following User Says Thank You to Qasim.rajput For This Useful Post:
Old 05-05-2017, 13:13   #6 (permalink)
Member: 2710747
iDoctor reparation iphone
Network problem is considered to be one of the most common problems that occur in smart phones. Normally there are three type of network issues such as low Signal, No Signal and signal keeps on dropping. Remove and reinsert SIM card can be simple solution for this. If the above method doesn’t work then restart your iPhone and you update your software properly.
Old 05-29-2017, 17:19   #7 (permalink)
Member: 2398204
Any one done fix network after bypass?
Old 05-30-2017, 10:23   #8 (permalink)
Moderator
loca|host's Avatar
Member: 363451
Sonork: 100.1577895
Thanks Meter: 834
It's impossible ( no wildcard_record.plist = no network ) .
__________________
Regards,
Mehdi
Page generated in 0.19392 seconds with 8 queries
