Old 11-18-2011, 23:56   #1 (permalink)
SVH
SVH's Avatar
Member: 9889
Thanks Meter: 50
Iphone4 queston
I have Iphone4 factory unlocked
sw 4.3.5
bb 04.10.01
phone freeze on apple logo
i can jailbreak it but after power on/off phone freeze again
if i update phone to ver 5.0 or 5.01 will it work normally , mean untethered?
and can i jailbreak it for add Cydia?
Thanx
The Following User Says Thank You to SVH For This Useful Post:
Old 11-19-2011, 04:35   #2 (permalink)
darksman's Avatar
Member: 849979
Sonork: 100.1603463
Thanks Meter: 923
Yes you can as the tethered JB
unlockdark.com
Old 11-19-2011, 08:46   #3 (permalink)
taleb_amine8's Avatar
Member: 223552
Thanks Meter: 63
sw 4.3.5
bb 04.10.01
Thanx
to use your phone on untethered methode you should use originale firmware without jailbreak it.
or restore it to IOS 5 and use it with semitethered.
for this install costum firmware 5.0 prepared with sn0wbrease to save your baseband after that boot tethered and go to cydia and add this source "http://thebigboss.org/semitether" and install it
for more detail http://forum.gsmhosting.com/vbb/f456...eased-1368026/
Old 11-19-2011, 08:56   #4 (permalink)
Member: 1674143
Thanks Meter: 20
this may not solve the problem
Old 11-19-2011, 10:46   #5 (permalink)
Member: 204359
Thanks Meter: 2
Iphone4 factory unlocked? or not?
Old 11-19-2011, 11:48   #6 (permalink)
SVH
SVH's Avatar
Member: 9889
Thanks Meter: 50
Generally i need from this phone:
1. when i power off/on phone must normal power
2. i need Cydia installed
so i need untethered Iphone4 with Cydia
should i need make jailbreak for it?
Old 11-19-2011, 18:35   #7 (permalink)
Member: 223552
Thanks Meter: 63
WHAT IS YOU IOS VERSION?????
IF YOU HAVE IOS 4.3.3 OR LOWER YOU CAN JAILBREAK IT USING REDSN0W rc16 OR HIGHER
OR YOU MAKE A TETHERED JAILBREAK WITCH MEAN YOU NEED TO CONNECT IT TO PC AND USE JUST BOOT WITH REDSN0W JOR EXAMPLE EVRY TIME YOU SHUT IT DOWN.
Old 11-21-2011, 00:33   #8 (permalink)
SVH
SVH's Avatar
Member: 9889
Thanks Meter: 50
guys, pls put your eyes on the top of my post!
there all info about my iPhone
so if i have sw ver 4.3.5 and jailbreak is tethered, it means no solution jet?
and if i will update sw to ver 5.0 or 5.01 is there posibility to add cydia without jailbreaking?
Old 11-22-2011, 08:47   #9 (permalink)
Member: 223552
Thanks Meter: 63
NO YOU CAN DO TETHRED JAILBREAK IN 5.0 AFTER THAT GO TO CYDIA>MANAGE>SOURCE>EDIT AND ADD "http://thebigboss.org/semitether" AND INSTALL IT AND YOU WILL HAVE SEMITETHRED JAILBROKEN IPHONE FOR MORE INFORMATION http://forum.gsmhosting.com/vbb/f456...eased-1368026/
can we unlock iphone4 ? Cake iPhone 4 / iPhone 4S 1 06-29-2010 15:52
Apple launched iPhone4 road_hunter420 iPhone 4 / iPhone 4S 1 06-09-2010 07:58
plz my 2310 sets imi queston mark plz help meeeeeeeee faheemkhan MT-BOX 0 03-10-2009 15:09
Queston about FLASHes Dront Infineon C16X M51 & ARM7 M52 BASED 0 03-14-2002 14:49
Page generated in 0.25161 seconds with 9 queries
