04-19-2012, 08:43 | #1 (permalink) |
No Life Poster Join Date: Oct 2002 Location: Pakistan Age: 45
Member: 16520 Status: Offline Sonork: 1580837 Thanks Meter: 90 | Removing Cydia??? is there any way to remove cydia without flashing/upgrading in iphone 4 5.0.1????? or erase iphone having cydia in the phone |
04-19-2012, 09:53 | #4 (permalink) |
No Life Poster Join Date: Dec 2006 Location: UAE
Member: 420857 Status: Offline Sonork: 100.1576793 Thanks Meter: 1,734 | Settings > General > Reset > Erase All Content and Settings remember to do a backup via itunes first … there’s no going back from a wipe! the same process works for ipad, iphone and ipod touch. make sure your ipad is plugged into a power source while erasing. dB |
04-20-2012, 11:36 | #7 (permalink) |
Insane Poster Join Date: Sep 2006
Member: 351871 Status: Offline Thanks Meter: 3 | its very simple to remove cydia application from all iphone os. 1pen cydia on your iphone. 2:goto manage tab. 3:select packages from list. 4:a new list will appear with all aplication on the screen. 5:select c alpabet from left tap/scroll side.(you want to remove cydia.so c stands for cydia.) 6:you will see a name of application cydia installer. 7:select cydia installer.then click on modify.it will ask do you want to upgrade or remove it. 8:select remove. after all turn off your phone.and next time when it will be turn on cydia will not available on your device.completly removed. Note: you can search cydia installer by using search method on cydia application if you dont want to perform above steps to find cydia installer. |
The Following User Says Thank You to pakbird For This Useful Post: |
04-20-2012, 11:50 | #8 (permalink) |
Moderator Join Date: Oct 2006 Location: Tunisia Age: 41
Member: 363451 Status: Offline Sonork: 100.1577895 Thanks Meter: 834 | install Cydelete , go to Settings then remove "Cydia Protection" now you may remove Cydia from springboard like any usual apps . |
The Following User Says Thank You to loca|host For This Useful Post: |
04-20-2012, 12:14 | #9 (permalink) | ||
No Life Poster Join Date: Oct 2005 Location: ALGERIA™ Age: 45
Member: 192681 Status: Offline Sonork: 100.106870 Thanks Meter: 5,082 | Quote:
this can remove only Cydia , but I think AWAIS need to UnJailibreak the iPhone without restore . How to Unjailbreak/Disable Cydia Apps Easily [Without Restoring] How to unjailbreak or remove cydia from your iphone or ipod touch | ||
04-21-2012, 17:16 | #10 (permalink) |
Freak Poster Join Date: Sep 2004 Age: 54
Member: 81291 Status: Offline Thanks Meter: 4 | Now I got IPad2 v5.01 stuck on apple logo after do erase all content setting. I already restore on ios 5.1, but when verification it got error 3194. What should I do now? |
sp lock 1,2,3,4 removed | spterminator | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 10 | 08-09-2010 10:20 |
Problems removing the GID lock with new SIM's | MrProdent | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 10 | 02-17-2004 00:00 |
How do I remove a network provider lock? | james.bond007 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 03-02-2000 22:59 |
My site was removed here is the new one! | Bert | GSM Mobile Links | 1 | 02-29-2000 17:31 |
£20 only NOKIA 51xx/61xx sp locks 1,2,3,4 removed | spterminator | Main Sales Section | 0 | 08-08-1999 05:08 |
