Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Chinese Models & Cloned Phones
Chinese Models & Cloned Phones All China Phone Platforms like (MTK, Spreadtrum.. etc.) Cloned Nokia Nokla & Motorola . etc. Phones are included
Old 06-19-2008, 18:07   #1 (permalink)
gopalhot's Avatar
Member: 149032
Thanks Meter: 3,808
How To Find Rx .tx Signles .
1. find Gnd pin (it's required step, you can't continue until you will know Gnd pin location)
2. find Charge pins (it's optional step, just to save your time during future research)
3. find +Battery pins (it's optional step, just to save your time during future research)
4. connect cable Gnd to phone Gnd
5. try to connect cable Rx/Tx wires to all phone contacts one by one (except Gnd, Charge, +Battery pins) and try to read flash from phone
6. if flash read procedure can start this means that pinout found Ok and you can make other operations
HOW TO FIND RX .TX SIGNLES .
It is tasted and also you can test it.
1 step is, we need to find GND from phone.
2 step is, we should power on phone (operation with dead phone:
phone must be 100% dead by software)and take multimater put it to voltage.
3 multimeter (-) line put it GND and with (+) line check each connectors
, and usually Tx= 1.8v or 2.8v and Rx=1.7v or 2.7v
(it will be change by processor but strongly 1.7v or 2.8v not 3v or 4v)
This way is too easy and you will save a more time.
For example!
You have got new brand China miracle phone with USB cable. It has got
12 pin. You must find (Infinity team give good Idea 1.2.3 punkts):
1) GND usually it has got 2 GND. (now we have got 10 pins)
2) We will uncheck USB + and USB- (VSS) just with checking by USB cable (now we have 8 pins)
3) By USB cable we also uncheck V bat+, ac adaptor + polarization (now we have 7 pins)
4) Now from this 7 pins you will find 1 or 3 not used pins (last operation we have 3 or 6 pins to find Rx Tx signals)
5) Now at last operation you should use good multimeter just to find Rx Tx with 1.7v-2.7v or 1.8v-2.8v
6) WHEN PHONE IS POWERD OFF TX AND GND WITH MULTIMETER MAKING BEEEEEP
(DIOD TEST OPERATION), WHEN PHONE POWERED ON IT WILL SHOW LIKE DIOD
RESISTANS 600-700 OHM BETWIN TX AND GND.
I think I have give for every body more information’s. Just try to
find. If you find 2-3 phone signals and you will be profi mobile Tx and
Rx signals finder.
Some times you will not find with this method some phones, but why we have forum?
I'm not saying it is 100% solution but I'm saying it is TESTED solution.
I'll make some guide or FAQ by pic. if I have a free time!
This instruction will helpful for people who working in GSM repairing industry minimum 3-5 years.
*** OFFTOP. I have some friends who don't know what is it Tx and Rx
signals, and why we using device. For siemens A35,C55 and C62 they
using 3 kind of cable (because they thinking that for each brand we
must use by one by cable).
The Following 4 Users Say Thank You to gopalhot For This Useful Post:
Old 06-24-2008, 12:04   #2 (permalink)
rk19801's Avatar
Member: 238252
Thanks Meter: 81
thanks mate for youer help................
Old 06-24-2008, 12:19   #3 (permalink)
goherabbas's Avatar
Member: 1311812
Sonork: 1659061
Thanks Meter: 116
thankss but the best way to find pinouts yuo parchase infinity box pin finder adapter its best
Old 01-12-2011, 20:07   #4 (permalink)
Member: 472378
Sonork: 100.1597506
Thanks Meter: 292
spider man is also great pinfinder box
Old 03-09-2011, 07:05   #5 (permalink)
Member: 1409087
Thanks Meter: 3
For example!
Rx signals finder.
friend how to find 2pin rx tx
[email protected]
Old 03-10-2011, 08:28   #6 (permalink)
MTK-BOX's Avatar
Member: 788782
Sonork: 100.1610033
Thanks Meter: 1,035
Super Doctor 1.510 Tool,read the mobile port voltage,we can easy find the RX and TX,like MTK 6253 RX=2.8V,and TX=1.4V,and MTK other CPU RX=2.8,and TX=0.4 or 0.8
Old 03-10-2011, 09:35   #7 (permalink)
Moderator
...:::::NP™:::::...'s Avatar
Member: 1162626
Sonork: 100.1591727 QQ:2337938173
Thanks Meter: 11,110
Hello Mate Do You Write in English Language I Think More People Don't Understood Hindi Language.
How to find RX TX pins at chinesse phones with Infinity ka2 Chinese Models & Cloned Phones 0 02-17-2009 17:48
how to find rx tx with fin finder Sony-Ericsson-J132 fraz12345 Infinity-Box 1 02-05-2009 15:22
how to find rx tx zeeshan tayyab Chinese Models & Cloned Phones 1 09-01-2008 07:11
how to find rx tx zeeshan tayyab Chinese Models & Cloned Phones 4 08-17-2008 09:53
HOW TO FIND RX/TX WITH ipHONE ON PAD?? frooze_angel PadFinder box 11 07-21-2008 11:46
Page generated in 0.18565 seconds with 9 queries
