Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Chinese Models & Cloned Phones
Chinese Models & Cloned Phones All China Phone Platforms like (MTK, Spreadtrum.. etc.) Cloned Nokia Nokla & Motorola . etc. Phones are included
Old 11-08-2016, 08:10   #1 (permalink)
Member: 532257
Sonork: 1624266
Thanks Meter: 64
i9082 daed after flash plz help
miracel bin file scater file errer
log here
all log all deatail here same file tested writabel need plz
______________________________
MT657x ANDROID NFB File:
None Table
The File Information:
LCSH15CU_PCB01_GPRS_MT6575_S01.MAUI_11AMD_W11_50_S P_V30_P2.BIN_FLNPF38F5060M0Y3DG
Definition Applied
1. Power Off Phone , Remove Battery, Insert Battery Back
2. Insert USB cable. In some cases Required Hold BootKey
3. Use Miracle Boot Key In cases Boot key not Find
4. Battery Should be Charged more then 50%
Waiting for USB Port...
Set MTK USB Port (COM39)
Please Hold "ON" to connect with the phone...
Connected to Phone.
CPU: MT6575 SW: E201 Ver: CB00
Downloading Boot8 ...
EMMC Size: 0x00E9000000
Flash Type: EMMC
INT/EXT RAM Size: 0x20000/0x0
Set MediaTek DA USB VCOM Port (COM42)
>>EMMC File, EXIT
cm2 read flash ok but writing time sonthing wrong erer
MT6575___GT-I9082__GT-I9082__4.2.2__ALPS.JB.MP.V1.16
Created by Infinity-Box (c) Chinese Miracle II (c) 2016
Device Model : GT-I9082
Device CPU : MT6575
Device IntName : GT-I9082
Device Version : 4.2.2
Device Compile : 5/29/2015 9:40:43 AM
Device Project : ALPS.JB.MP.V1.16
Device ExtInfo : GT-I9082
Supported BootLoader HW :
FlashID [0] CID : 1501004E4A5330304D , Name : NJS00M , Vendor : 15 , [SAMSUNG]
FlashID [1] CID : 90014A2058494E5948 , Name : XINYH , Vendor : 90 , [HYNIX]
FlashID [2] CID : 1501004E355530304D , Name : N5U00M , Vendor : 15 , [SAMSUNG]
FlashID [3] CID : 7001004D4D43303447 , Name : MMC04G , Vendor : 70 , [KINGSTON]
FlashID [4] CID : 110100303034473930 , Name : 004G90 , Vendor : 11 , [TOSHIBA]
FlashID [5] CID : 90014A483447316404 , Name : H4G1d , Vendor : 90 , [HYNIX]
FlashID [6] CID : 45010053454D303447 , Name : SEM04G , Vendor : 45 , [SANDISK]
FlashID [7] CID : FE014E503058585858 , Name : P0XXXX , Vendor : FE , [MICRON]
FlashID [8] CID : 1501004E35575A4D42 , Name : N5WZMB , Vendor : 15 , [SAMSUNG]
FlashID [9] CID : FE014E50314A353441 , Name : P1J54A , Vendor : FE , [MICRON]
Device Memory Details ( installed ) :
RAM : [DRAM_NOT_INIT]
ROM : eMMC 4 GiB
Manufacturer : [SAMSUNG]
plz help me boss
Old 11-08-2016, 08:46   #2 (permalink)
Member: 532257
Sonork: 1624266
Thanks Meter: 64
Device CPU : MT6575
Ready to Flash!
Operation : Flash [ v1.58 ]
======= Flash
Wait for phone...
Phone found! [ 39 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6575
BB_CPU_NME : [MediaTek] MT6575|MT6577_S00
BB_CPU_EXT : 0xCB00 , 0x8A00 , 0xE201
Processing BROM stage
i2c Init : 00000000
SpeedSet : 0000
VChrgSet : 0x28 , BatStat : 0x02
WD Disable stat : 0x0000
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
Processing DA stage
Sending and initialize DA ...
Running DA ver.3.2 on BBID : 0x84
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_INF : [SAMSUNG] , M00U5
[eMMC] : FLASH_CID : 1501004E355530304D0204F7324B2111
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00020000
[eMMC] : FLASH_LEN : 0x00000000E9000000
[eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB]
DEV RID : 0xB5A9BA64C2CC0767961B8DD5CBB4A9B6
INT RAM : 0x00020000
EXT RAM : 0x00000000 [DRAM_NOT_INIT]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6575 , Project : MTK6575 , Storage : eMMC
Setting : AFF verify : Enabled
Setting : HW verify : Enabled
Switching to HSUSB
HSUSB Init Ok
DRAM not initialized , will try init now
DRAM init passed , 0x20000000
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : Old Dedvice , skip BatteryLevel check
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000000600000-0x0000000000060000
Erase : 0x0000000000D80000-0x0000000069E64000
Flash Pre-Erase Done, time used : 00:00:00
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader_hexing75_jb.bin
Preloader Sent , Init passed
PartCount : FFFFFFFF
PartErr : Not initialized , will update PMT now ...
Repartition Done!
Use FLN Mode
Processing : Flash Write
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Flash now : RECOVERY
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : EBR2
Image Flash Ok
Flash now : ANDROID
Write Error , code 0x001! Something went wrong!
Operation Failed
Elapsed: 00:01:05
Reconnect Power/Cable!
with cm2 orignal read file same errer
try all erase somthing other but same
Old 11-08-2016, 08:57   #3 (permalink)
Registered User
Member: 2506300
Thanks Meter: 345
Use SP tool Select Scatter Use Format all+Download
Old 11-08-2016, 11:22   #4 (permalink)
Member: 532257
Sonork: 1624266
Thanks Meter: 64
Wait for phone...
Device boot not done
Check Drivers
Try again
Boot Error!
Operation Failed
Elapsed: 00:00:29
Operation : Flash Erase [ v1.58 ]
Wait for phone...
Phone found! [ 39 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6575
i2c Init : 00000000
SpeedSet : 0000
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Erase Flash now ...
Keep Preloader alive
Flash erase done
Done!
Elapsed: 00:00:13
try cm2 erse but same
Old 11-08-2016, 11:56   #5 (permalink)
Member: 532257
Sonork: 1624266
Thanks Meter: 64
Card found : S/N : CDFF8E76 , v0134
Wait for phone...
Phone found! [ 39 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6575
i2c Init : 00000000
SpeedSet : 0000
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Erase Flash now ...
Flash erase done
Done!
Elapsed: 00:00:10
Scatter Load Ok , BaseBand : MT6575 , Project : MTK6575 , Storage : eMMC
Files found : 12 , Set to Flash : 11
Device CPU : MT6575
Ready to Flash!
======= Flash
Wait for phone...
Phone found! [ 39 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6575
i2c Init : 00000000
SpeedSet : 0000
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Switching to HSUSB
HSUSB Init Ok
Repartition Done!
Use FLN Mode
Flash now : MBR
Image Flash Ok
Flash now : EBR1
Image Flash Ok
Flash now : UBOOT
Image Flash Ok
Flash now : BOOTIMG
Image Flash Ok
Image Flash Ok
Flash now : SEC_RO
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : EBR2
Image Flash Ok
Flash now : ANDROID
Operation Failed
Elapsed: 00:00:46
Old 11-08-2016, 12:20   #6 (permalink)
Member: 532257
Sonork: 1624266
Thanks Meter: 64
with sptool errer pic here
sptool flash erer - Pic Tub Club - Free Image Hosting
Page generated in 0.23051 seconds with 8 queries
