Chinese Models & Cloned Phones All China Phone Platforms like (MTK, Spreadtrum.. etc.) Cloned Nokia Nokla & Motorola . etc. Phones are included |
07-13-2008, 16:16 | #1 (permalink) |
Freak Poster Join Date: Feb 2006 Location: china-NanJing Age: 41
Member: 233259 Status: Offline Thanks Meter: 283 | Spreadtrum Baseband and Rf Chipsets features .. Spreadtrum Baseband and Rf Chipsets Features only in this thread . (1)INFORMATION About Spreadtrum Baseband and Rf chipsets. Image Attachment: 1.jpg (13-7-2008 22:43, 58.3 K) |
The Following User Says Thank You to zhanglei5556 For This Useful Post: |
07-13-2008, 16:20 | #2 (permalink) |
Member: 233259 Status: Offline Thanks Meter: 283 | Spreadtrum Baseband Chipsets 3G Family (1)SC8800D (2)SC8800H (1)Spreadtrum Baseband Chipset Sc8800D Spreadtrum’s SC8800D is a single TD-SCDMA/GSM/GPRS dual modebaseband chip, which is the world's first TD-SCDMA dual-mode chip providinganalog, digital and power management, plus multimedia application functions ona single chip. SC8800D offers automatic handover between TD-SCDMA and GSMnetworks, with up to 384 kbps downlink transmission data rates, and multimediafeatures for the 3G market. The SC8800D features a highly integrated chipset thatenhances reliability, reduces production costs and helps customers develop newproducts and bring them to market faster. sc8800D Baseband Chip Diagram Image Attachment: 2.jpg (13-7-2008 22:44, 120.04 K) SC8800D Key features Core Description ▪ ARM926EJ-S® core, clock speeds up to 100MHz Data Transmit Capability ▪ PS uplink 128kbps/ downlink 384kbps Multimedia Support For ▪ Build-in MP3 player ▪ 64-polyphonic melody (MIDI based) LCD Display Features ▪ Built-in LCD Controller ▪ Support for dual color LCD display modules ▪ Support up to 262 K TFT/OLED display modules ▪ Support up to 240x320 resolution size LCD display modules Memory I/F Support For ▪ Memory interfaces (SDRAM, NAND, NOR) ▪ Built-in NAND flash controller ▪ NAND booting ▪ NAND+SDRAM multi-chip packaging (MCP) Peripheral I/F Support For ▪ MMC and SD card interfaces ▪ 3 UART interfaces, with transmission speeds up to 1.152 Mbps ▪ IrDA with transmissions speeds up to 115kbps ▪ SPI interfaces ▪ I²C interfaces ▪ I²S interfaces ▪ GPIO interfaces ▪ 1.8/3.0 SIM interface ▪ JTAG interface for test and in-circuit emulation ▪ Real-Time Clock (RTC) synchronization Analog I/F Features ▪ Wide range RF interface support for IF/NZIF/ZIF architectures ▪ Power management with Low Drop Output (LDO) regulators on chip Firmware Support For ▪ GSM/GPRS standards (release V8.2.0 12/1999), GSM850/GSM900/DCS1800/PCS1900 ▪ GPRS Multi-Slot Class 10 ▪ TD-SCDMA standards (3GPP release 5), 2010~2025MHz ▪ FR, EFR, AMR ▪ Voice recording ▪ A5/1 and A5/2 encryption algorithms Other Features ▪ Operating ambient temperature range: -25 to +65 degrees centigrade ▪ Extremely low-power design, 3.0V for I/O, 1.8V for core ▪ 13×13mm² 289-ball LFBGA package Last edited by zhanglei5556; 07-13-2008 at 16:29. |
07-13-2008, 16:30 | #3 (permalink) |
Member: 233259 Status: Offline Thanks Meter: 283 | (2)Spreadtrum SC8800H 3G FAMILY. Spreadtrum’s SC8800H is a singleHSDPA/TD-SCDMA/GSM/GPRS/EDGE dual-mode baseband chip, supports HSDPA technologyand integrates mutimedia processors. SC8800H chipset solution delivers enhancedperformance, high quality multimedia functions and high speed data transmissionrates for enabling handset manufacturers and operators to offer powerful 3Gapplications. The SC8800H features a highly integrated chipset thatenhances reliability, reduces production costs and helps customers develop newproducts and bring them to market faster. SC8800H Baseband Chip Diagram. SC8800H Key Features Core Description ▪ ARM926EJ-S® core, speeds up to 200MHz Data Transmit Capability ▪ PS uplink 128kbps/ downlink 384kbps ▪ HSDPA transmission rates up to 1.6Mbps Multimedia Support For ▪ Embedded 5 mega-pixel digital camera controllers, capable of direct connection to digital CMOS image sensors ▪ Built-in ISP, support to handle Bayer RGB image data, support AF function ▪ High CD-Quality music playback, support MP3/AAC/AAC+/WMA ▪ MPEG4 encode for QCIF @15 fps, decode for QVGA @ 30fps ▪ 64-polyphonic melody (MIDI based) ▪ Stereo ▪ JEPG accelerator ▪ NTSC/PAL TV-Out LCD Display Features ▪ Built-in LCD Controller ▪ Support for dual color LCD display modules ▪ Support up to 262 K TFT display modules ▪ Support up to 240x320 resolution size LCD display modules Memory I/F Support For ▪ Memory interfaces(SDRAM, NAND, NOR) ▪ Built-in NAND flash controller, support 8bit/16bit NAND flash ▪ NAND booting ▪ NAND+SDRAM MCP ▪ Built-in DDR controller up to 16/32 DDR ▪ Built-in SDRAM controller up to 100MH Peripheral I/F Support For ▪ Built-in USB2.0 ▪ MMC and SD card interfaces ▪ 3 UART interfaces, with transmission speeds up to 920kbp ▪ PCM audio interface ▪ IrDA with transmissions speeds up to 115kbps ▪ SPI interfaces ▪ I²C interfaces ▪ I²S interfaces ▪ GPIO interfaces ▪ Bluetooth/WLAN/A-GPS/FM interfaces ▪ 2 SIM/USIM interface ▪ JTAG interface for test and in-circuit emulation ▪ Real-Time Clock (RTC) synchronization ▪ 2 SDIO interfaces Analog I/F Features ▪ Wide range RF interface support for IF/NZIF/ZIF architectures ▪ Power management with Low Drop Output (LDO) regulators on chip ▪ Built-in high precision AFC DAC, support crystal-based RF solutions Firmware Support For ▪ GSM/GPRS standards (release V8.2.0 12/1999), GSM900/DCS1800/PCS1900 ▪ EGPRS Class10 ▪ TD-SCDMA standards (3GPP release 5), 2010~2025MHz ▪ FR, EFR, AMR ▪ Voice recording ▪ A5/1 and A5/2 encryption algorithms Other Features ▪ Operating ambient temperature range: -25 to +65 degrees centigrade ▪ Extremely low-power design, 3.0V for I/O, 1.8V for core ▪ 14×14mm² 349-ball LFBGA package |
07-13-2008, 16:33 | #4 (permalink) |
Member: 233259 Status: Offline Thanks Meter: 283 | Spreadtrum Baseband Chipsets 2G Family. (1)SC6600D (2)SC6600H (3)SC6600I (4)SC6600R (5)SC6800D Spreadtrum Baseband Chipset SC6600D 2G Family. Spreadtrum’s SC6600D is a single chip GSM/GPRS basebandproviding cost-effective solutions for entry-level multimedia GSM/GPRS phonedesigns. It has an integrated multimedia processor with quad-band GSM/GPRSbaseband, as well as built-in power management circuits on one chip. The SC6600D features a highly integrated chipset thatenhances reliability and reduces production costs, while enabling customers todevelop new, differentiated products and bring these entry-level phones tomarket faster. SC6600D Baseband Chipset Diagram. SC6600D Key Features. Core Description ▪ ARM7TDMI® core, with clock speeds up to 78MHz Multimedia Support For ▪ Built-in MP3 ▪ 64-polyphonic melody (MIDI based) ▪ Stereo output LCD Display Features ▪ Built-in LCD Controller ▪ Support for dual color LCD display modules ▪ Support up to 262 K TFT/OLED display modules ▪ Support up to 176X244 resolution size LCD display modules Memory I/F Support For ▪ Memory interfaces (pSPAM, Burst pSRAM ,NOR) Peripheral I/F Support For ▪ MMC and SD card interfaces ▪ 3 UART interfaces, with transmission speeds up to 1.152 Mbps ▪ IrDA with transmissions speeds up to 115kbps, 1.152Mbps ▪ SPI interfaces ▪ I²C interfaces ▪ I²S interfaces ▪ GPIO interfaces ▪ Support Bluetooth/WLAN/A-GPS interface ▪ 1.8/3.0 SIM interface ▪ 8-channel DMAs ▪ JTAG interface for test and in-circuit emulation ▪ Real-Time Clock (RTC) synchronization Analog I/F Features ▪ Wide range RF interface support for IF/NZIF/ZIF architectures ▪ Power management with Low Drop Output (LDO) regulators on chip Firmware Support For ▪ GSM/GPRS standards (release V8.2.0 12/1999), GSM850/GSM900/DCS1800/PCS1900 ▪ GPRS Multi-Slot Class 10 ▪ PTT (Push to Talk) functions ▪ FR, EFR ▪ Voice recording ▪ A5/1 and A5/2 encryption algorithms Other Features ▪ Operating ambient temperature range: -25 to +65 degrees centigrade ▪ Extremely low-power design, 3.0V for I/O, 1.8V for core ▪ 12×12mm² 180-ball LFBGA package |
07-13-2008, 16:36 | #5 (permalink) |
Member: 233259 Status: Offline Thanks Meter: 283 | (2)Spreadtrum Baseband Chipset SC6600H 2G Family. Spreadtrum’s SC6600H GSM/GPRS multimedia baseband chipprovides a highly cost-effective solution for developers of high performance,entry-level GSM/GPRS music phone designs. SC6600H enables high quality musicfunctionality to be integrated into new generation handsets. The SC6600H features a highly integrated chipset thatenhances reliability and reduces production costs, while enabling customers todevelop new, differentiated products and bring them to the mainstream marketfaster. SC6600H Baseband Chipset Diagram. SC6600H Key Features. Core Description ▪ ARM7TDMI® core, with clock speeds up to 78MHz Multimedia Support For ▪ High CD-Quality music playback, supporting MP3/AAC/AAC+, plus built-in >=90dB SNR audio DAC ▪ 64-polyphonic melody (MIDI based) ▪ Stereo output LCD Display Features ▪ Built-in LCD Controller ▪ Support for dual color LCD display modules ▪ Support up to 262K TFT/OLED display modules ▪ Support up to 240x320 resolution size LCD display modules ▪ Real time display speed >=30fps with QVGA MMI Memory I/F Support For ▪ Memory interfaces (NAND, NOR, SRAM, pSRAM, Burst pSRAM) ▪ Built-in NAND controller ▪ NAND booting Peripheral I/F Support For ▪ USB1.1 interfaces ▪ MMC and SD card interfaces ▪ 4 UART interfaces, with transmission speeds up to 1.152 Mbps ▪ PCM audio interface ▪ IrDA with transmissions speeds up to 115kbps, 1.152Mbps ▪ SPI interfaces ▪ I²C interfaces ▪ I²S interfaces ▪ GPIO interfaces ▪ Bluetooth/WLAN/A-GPS interfaces ▪ 1.8/3.0 SIM interface ▪ 8-channel DMAs ▪ JTAG interface for test and in-circuit emulation ▪ Real-Time Clock (RTC) synchronization Analog I/F Features ▪ Wide range RF interface support for IF/NZIF/ZIF architectures ▪ Power management with Low Drop Output (LDO) regulators on chip ▪ Built-in high precision AFC DAC, supporting crystal-based RF solutions Firmware Support For ▪ GSM/GPRS standards (release V8.2.0 12/1999), GSM850/GSM900/DCS1800/PCS1900 ▪ GPRS Multi-Slot Class 10 ▪ PTT (Push to Talk) functions ▪ HR,FR, EFR, AMR ▪ Voice recording ▪ A5/1 and A5/2 encryption algorithms Other Features ▪ Operating ambient temperature range: -25 to +65 degrees centigrade ▪ Extremely low-power design, 3.0V for I/O, 1.8V for core ▪ 12×12mm² 240-ball LFBGA package |
07-13-2008, 16:38 | #6 (permalink) |
Member: 233259 Status: Offline Thanks Meter: 283 | (3)Spreadtrum Baseband Chipset SC6600I 2G Family. Spreadtrum’s SC6600I GSM/GPRS baseband chip provides anEntry-level multimedia GSM/GPRS handset solution for developers of GSM/GPRSmultimedia phone designs. SC6600I enables music, video and camera functions tobe integrated into handsets for the mainstream market. The SC6600I features a highly integrated chipset thatenhances reliability and reduces production costs, while enabling customers todevelop new, differentiated products and bring them to the mainstream marketfaster. SC6600I BaseBand Chipset Diagram. SC6600I Key Features. Core Description ▪ ARM7TDMI® core, speeds up to 78MHz Multimedia Support For ▪ Embedded 0.3 mega-pixel digital camera controllers, capable of direct connection to digital CMOS image sensors ▪ Built-in MP3 players ▪ Support MPEG4 176×144@25fps ▪ 64-polyphonic melody (MIDI based) LCD Display Features ▪ Built-in LCD Controller ▪ Support for dual color LCD display modules ▪ Support up to 262 K TFT/OLED display modules ▪ Support up to 240x320 resolution size LCD display modules Memory I/F Support For ▪ Memory interfaces (SDRAM, NAND, NOR) ▪ Built-in NAND flash controller ▪ NAND booting ▪ NAND+SDRAM MCP, with SDRAM speeds up to 72 MHz Peripheral I/F Support For ▪ USB1.1 interfaces ▪ MMC and SD card interfaces ▪ 4 UART interfaces, with transmission speeds up to 1.152 Mbps ▪ PCM audio interface ▪ IrDA with transmissions speeds up to 115kbps, 1.152Mbps ▪ SPI interfaces ▪ I²C interfaces ▪ I²S interfaces ▪ GPIO interfaces ▪ Bluetooth/WLAN/A-GPS interfaces ▪ 1.8/3.0 SIM interface ▪ 8-channel DMAs ▪ JTAG interface for test and in-circuit emulation ▪ Real-Time Clock (RTC) synchronization Analog I/F Features ▪ Wide range RF interface support for IF/NZIF/ZIF architectures ▪ Power management with Low Drop Output (LDO) regulators on chip Firmware Support For ▪ GSM/GPRS standards (release V8.2.0 12/1999), GSM850/GSM900/DCS1800/PCS1900 ▪ GPRS Multi-Slot Class 10 ▪ PTT (Push to Talk) functions ▪ FR, EFR, AMR ▪ Voice recording and voice recognition ▪ A5/1 and A5/2 encryption algorithms Other Features ▪ Operating ambient temperature range: -25 to +65 degrees centigrade ▪ Extremely low-power design, 3.0V for I/O, 1.8V for core ▪ 12×12mm² 265-ball LFBGA package |
07-13-2008, 16:39 | #7 (permalink) |
Member: 233259 Status: Offline Thanks Meter: 283 | (4)Spreadtrum Baseband Chipset SC6600R 2G Family. Spreadtrum's SC6600R GSM/GPRS multimedia baseband chipprovides a highly cost-effective solution for developers of GSM/GPRS multimediaphone designs. The SC6600R enables quality music, video and camerafunctionalities to be integrated into new generation handsets, allowing handsetmanufacturers to bring multimedia functions previously reserved for high-endfeature phones to mainstream handsets. The SC6600R features a highly integrated chipset thatenhances reliability and reduces production costs, while enabling customers todevelop new, differentiated products and bring them to market faster. SC6600R Baseband Chipset Diagram. SC6600R Key Features. Core Description ▪ ARM7TDMI® core, speeds up to 78MHz Multimedia Support For ▪ Embedded 2 mega-pixel digital camera controllers, capable of direct connection to digital CMOS image sensors ▪ High CD-Quality music playback, support MP3/AAC/AAC+,built-in >=90dB SNR audio DAC ▪ Support MPEG4 QVGA @30fps video playback, with AAC-LC audio playback in real time ▪ 64-polyphonic melody (MIDI based) ▪ Stereo output LCD Display Features ▪ Built-in LCD Controller ▪ Support for dual color LCD display modules ▪ Support up to 262 K TFT/OLED display modules ▪ Support up to 240×320 resolution size LCD display modules ▪ Real time display speed >=30fps with QVGA MMI Memory I/F Support For ▪ Memory interfaces (SDRAM, NAND, NOR, pSRAM, Burst pSRAM) ▪ Built-in NAND flash controller ▪ NAND booting ▪ NAND+SDRAM multi-chip packaging (MCP) Peripheral I/F Support For ▪ USB1.1 interfaces ▪ MMC and SD card interfaces ▪ 4 UART interfaces, with transmission speeds up to 1.152 Mbps ▪ PCM audio interface ▪ IrDA with transmissions speeds up to 115kbps, 1.152Mbps ▪ SPI interfaces ▪ I²C interfaces ▪ I²S interfaces ▪ GPIO interfaces ▪ Bluetooth/WLAN/A-GPS interfaces ▪ 1.8/3.0 SIM interface ▪ 8-channel DMAs ▪ JTAG interface for test and in-circuit emulation ▪ Real-Time Clock (RTC) synchronization Analog I/F Features ▪ Wide range RF interface support for IF/NZIF/ZIF architectures ▪ Power management with Low Drop Output (LDO) regulators on chip ▪ Built-in high precision AFC DAC, support crystal-based RF solutions Firmware Support For ▪ GSM/GPRS standards (release V8.2.0 12/1999), GSM850/GSM900/DCS1800/PCS1900 ▪ GPRS Multi-Slot Class 10 ▪ PTT (Push to Talk) functions ▪ HR,FR, EFR, AMR ▪ Voice recording ▪ A5/1 and A5/2 encryption algorithms Other Features ▪ Operating ambient temperature range: -25 to +65 degrees centigrade ▪ Extremely low-power design, 3.0V for I/O, 1.8V for core ▪ 12×12mm²257-ball LFBGA package |
07-13-2008, 16:40 | #8 (permalink) |
Member: 233259 Status: Offline Thanks Meter: 283 | (5)Spreadtrum Baseband Chipset Sc6800D 2G Family. Spreadtrum's SC6800D is specifically designed formid-to-high end multimedia phone product applications, providing enhancedperformance for processing intense multimedia applications. SC6800D offersTV-Out functionality allowing the customers to play video and games on TV.SC6800D enhances the capability of process provides more flexible solution forhandset manufacturers to support more applications The SC6800D features a highly integrated chipset thatenhances reliability, reduces production costs and helps customers develop newproducts and bring them to market faster. SC6800D Baseband Chipset Diagram. SC6800D Key Features. Core Description ▪ ARM9EJ-S® core, with clock speeds up to 192MHz Multimedia Support For ▪ Built-in MPEG-4, 2D Graphics, JAVA accelerator ▪ Built-in 5M pixel digital camera controllers, capable of direct connection to digital CMOS image sensors ▪ Built-in ISP, support to handle Bayer RGB image data, support AF function ▪ MIDI/MP3/AAC/AAC+/WMA audio formats ▪ MPEG4/H.263 video format, with playback up to 3Mbps bit rate ▪ TV-Out, PAL/NSTC ▪ 3D surrounding LCD Display Features ▪ Build-in LCD controller, support RGB and MCU interfaces ▪ Support for dual color LCD display modules ▪ Support up to 262 K TFT LCD display modules ▪ Support up to 240x320 resolution size LCD display module Memory I/F Support For ▪ Memory interfaces (SDRAM, NAND, NOR) ▪ Built-in NAND flash controller ▪ NAND booting ▪ NAND+SDRAM MCPs, with SDRAM speeds up to 96 MHz Peripheral I/F Support For ▪ USB1.1 interfaces ▪ MMC and SD card interfaces ▪ 4 UART interfaces, with transmission speeds up to 1.152 Mbps ▪ PCM audio interface ▪ IrDA with transmissions speeds up to 115kbps, 1.152Mbps ▪ SPI interfaces ▪ I²C interfaces ▪ I²S interfaces ▪ GPIO interfaces ▪ 1.8/3.0 SIM interface ▪ 24-channel DMAs ▪ JTAG interface for test Analog I/F Features ▪ Wide range RF interface support for IF/NZIF/ZIF architectures ▪ Power management with Low Drop Output (LDO) regulators on chip Firmware Support For ▪ GSM/GPRS standards (release V8.2.0 12/1999),GSM850/900/DCS1800/PCS1900 ▪ GPRS Multi-Slot Class 10 ▪ FR, EFR, AMR ▪ Voice recording ▪ A5/1 and A5/2 encryption algorithms Other Features ▪ Operating ambient temperature range: -25 to +65 degrees centigrade ▪ Extremely low-power design, 3.0V for I/O, 1.8V for core ▪ 12×12mm²300-ball LFBGA package |
07-13-2008, 16:42 | #9 (permalink) |
Member: 233259 Status: Offline Thanks Meter: 283 | Spreadtrum RF Chipsets QS3000 3G Family. Sampling today, Quorum's QS3000 represents the industry'smost highly integrated single-chip radio transceiver for combined 3G HSDPA andGSM-EDGE (HEDGE) applications.Implemented on a single die, this low-power bulkCMOS device not only supports Quad-Band EDGE, but also supports Tri-band WCDMA,including HSDPA without the need for area and cost-consuming external LNAs ortransmit SAW filters. QS3000 Functional Block Diagram. QS3000 Key Features. l Standard analog I-Q interface for GSM and WCDMA basehands, including 2 SPIs for individual control l Quad-band GSM/GPRS/EDGE and Tri-band WCDMA with HSDPA (and HSUPA ready) l Highly integrated true single-chip multi-mode, multi-band HEDGE transceiver l Available in 7mm × 7mm × 0.9mm, 100BGA package (RoHS compliant) l GSM and WCDMA transmit paths require no external (SAW) filtering l Supports compressed and non-compressed modes and HSDPA to Cat.10 l Supports Band I through Band VI, FOMA800 and PCS1700 l Fully integrated LNAs for all bands of operation l Completely integrated frequency synthesizer and VCO l All transmit output stages are single-ended and matched to 50Ω l 2.7V to 3.3V single supply voltage |
07-13-2008, 16:44 | #10 (permalink) |
Member: 233259 Status: Offline Thanks Meter: 283 | Spreadtrum RF Chipset QS500 2G Family. The Quorum QS500 series are single-chip radio transceiversfor Dual-band (QS500) and Quad-band (QS504) GSM/GPRS cellular applications. TheQS500 has been implemented in bulk CMOS and the design has been optimized tomeet the challenges of integrated handset design The QS500 represents the most integrated solution for multi-band GSMcellular applications. The receiver part of QS500 is a Zero-IF (direct) systemimplementation. The transmitter uses a self-contained linear architecture withminimal production calibration for GSM operation. The performance of thetransmit chain is such that no additional RF filters are required to meet thespecification for out-of-band emissions QS500 Functional Block Diagram. QS500 KEY Features. l Integrated transceiver radios fully supporting GSM/GPRS receive and transmit for voice and data applications l Quad-band operation (USGSM 850, EGSM900, DCS1900, and PCS1900) QS504 l Dual-band operation (EGSM900, DCS1800) -QS500 l Direct down-conversion receiver eliminates image reject and IF filters l Industries leading low receive current l Available in 6mm × 6mm × 0.9mm 40L QFN Package l Green, RoHS compliant l ZIF receive architectures supported l No extra off-chip RF filters required for GSM transmit l 2.7V to 3.3V single supply voltage |
07-13-2008, 16:46 | #11 (permalink) |
Member: 233259 Status: Offline Thanks Meter: 283 | Spreadtrum RF Chipset QS1000 2G Family. Based on Quorum’s SerenoTM platform architecture, the QS1000is a single-chip radio transceiver delivering superior performance in GSM/GPRSand EDGE applications. Manufactured in bulk CMOS process, Quorum’s uniqueintegrated radio technology enables high-performance radio transceivers formultiple standards with ultra low power (ULP) consumption. QS1000 Functional Block Diagram QS1000 Key Features. l Single-chip, Direct conversion, Quad-band GSM/GPRS EDGE transceiver l Available in 6mm × 6mm × 0.9mm, 40-QFN package (RoHS compliant) l Operates from 13MHz or 26 MHz system clock or external DCXO l Supports Class 12 GPRS/EDGE l 63mA receive current at -110dBm sensitivity l Tunes across all bands (for GSM basestations) l Linear transmit architecture l ZIF and NZIF receive architecture options l Extensive on-chip calibration l Supports standard analog IQ baseband interface l Simple, 3-wire programming l 2.7V to 3.3V single supply voltage l Extended temperature: -40oC to +85oC |
Post here all success downgrading baseband and all working without problem after that | tcdxb | iPhone 2 / iPhone 3G / iPhone 3GS | 2 | 04-20-2009 08:16 |
Energy management and RF calibration using Cruiser, possible? | virtue | Cruiser Suite | 4 | 11-03-2008 13:59 |
iToos T6 MP4 Player with 3.0 inch LCD and RF Wireless Transmit - 4GB (black) | IPMART | ipmart WebShop | 0 | 10-22-2008 08:00 |
iToos T6 MP4 Player with 3.0 inch LCD and RF Wireless Transmit - 4GB (blue) | IPMART | ipmart WebShop | 0 | 10-22-2008 08:00 |
