12-14-2008, 17:41 | #1 (permalink) |
Freak Poster Join Date: Oct 2004 Location: Tunisia
Member: 88177 Status: Offline Sonork: 1594092 Thanks Meter: 71 | Can't unlock k530i; Help i have k530 to unloc, i installed the rest file un i proceed to unlock it. The log : 14/12/2008 17:25:28 v0.914034/UNI 14/12/2008 17:25:28 CARD SERIAL: 00072807 14/12/2008 17:25:28 Loaded 51 flash descriptors 14/12/2008 17:27:33 PRELOADER SECURITY BYPASS ENABLED. 14/12/2008 17:27:37 ChipID:9900,EMP protocol:0301 14/12/2008 17:27:38 14/12/2008 17:27:38 PHONE IS RED RETAIL PRODUCT 14/12/2008 17:27:38 FLASH CID detected:52 14/12/2008 17:27:38 Speed:921600 14/12/2008 17:27:38 Trying to launch embedded bootloader... 14/12/2008 17:28:06 embedded flashloader not responds ! 14/12/2008 17:28:06 PROCEDURE WAS STOPPED BY USER 14/12/2008 17:28:06 Elapsed: 33 secs. 14/12/2008 17:28:21 PRELOADER SECURITY BYPASS ENABLED. 14/12/2008 17:28:31 ChipID:9900,EMP protocol:0301 14/12/2008 17:28:32 14/12/2008 17:28:32 PHONE IS RED RETAIL PRODUCT 14/12/2008 17:28:32 FLASH CID detected:52 14/12/2008 17:28:32 Speed:921600 14/12/2008 17:28:32 Flash ID check:897E 14/12/2008 17:28:32 Flash props sent ok 14/12/2008 17:28:32 OTP LOCKED:1 CID:51 PAF:1 IMEI:35901901197515 CERT:RED 14/12/2008 17:28:32 FLASH CID:52 COLOR:RED 14/12/2008 17:28:34 14/12/2008 17:28:34 Model:K530i 14/12/2008 17:28:34 MAPP CXC article: R6CA001 prgCXC1250981_ORANGE_NC 14/12/2008 17:28:34 MAPP CXC version: R6CA001 14/12/2008 17:28:34 Language Package:ORANGE_GEN 14/12/2008 17:28:34 CDA article: CDA102823/43 14/12/2008 17:28:34 CDA version: R9A 14/12/2008 17:28:34 Default article: cxc1250959 14/12/2008 17:28:34 Default version: R6CA001 14/12/2008 17:28:34 PROVIDER: 208-01 14/12/2008 17:28:34 Network LOCKED 14/12/2008 17:28:34 14/12/2008 17:28:34 RESTORATION FILE PRESENT FOR DETECTED FIRMWARE 14/12/2008 17:28:34 14/12/2008 17:28:34 BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE 14/12/2008 17:28:34 14/12/2008 17:28:34 SECURITY UNITS BACKUP CREATED. 14/12/2008 17:28:34 Elapsed: 13 secs. 14/12/2008 17:28:46 PRELOADER SECURITY BYPASS ENABLED. 14/12/2008 17:28:50 ChipID:9900,EMP protocol:0301 14/12/2008 17:28:51 14/12/2008 17:28:51 PHONE IS RED RETAIL PRODUCT 14/12/2008 17:28:51 FLASH CID detected:52 14/12/2008 17:28:51 Speed:921600 14/12/2008 17:28:51 Trying to launch embedded bootloader... 14/12/2008 17:29:26 embedded flashloader not responds ! 14/12/2008 17:29:26 Elapsed: 40 secs. 14/12/2008 17:30:29 SIGNED MODE (USING SERVER). 14/12/2008 17:30:29 ALTERNATIVE SECURITY BYPASS ENABLED. 14/12/2008 17:30:34 ChipID:9900,EMP protocol:0301 14/12/2008 17:30:34 14/12/2008 17:30:34 PHONE IS RED RETAIL PRODUCT 14/12/2008 17:30:34 FLASH CID detected:52 14/12/2008 17:30:34 Speed:921600 14/12/2008 17:30:34 OTP LOCKED:1 CID:51 PAF:1 IMEI:35901901197515 CERT:RED 14/12/2008 17:30:34 FLASH CID:52 COLOR:RED 14/12/2008 17:30:35 PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 14/12/2008 17:30:36 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 14/12/2008 17:30:36 Flash ID check:897E 14/12/2008 17:30:36 Flash props sent ok 14/12/2008 17:30:38 LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 14/12/2008 17:30:38 loader startup: executed 14/12/2008 17:30:50 loader GDFS startup: executed 14/12/2008 17:32:38 wrong response, break. 14/12/2008 17:32:38 loader fs startup failed, that is fatal 14/12/2008 17:32:38 PROCEDURE WAS STOPPED BY USER 14/12/2008 17:32:38 Elapsed: 129 secs. 14/12/2008 17:35:24 SIGNED MODE (USING SERVER). 14/12/2008 17:35:24 ALTERNATIVE SECURITY BYPASS ENABLED. 14/12/2008 17:35:27 phone pre-boot failed,possible RECOVERY needed. 14/12/2008 17:35:27 PROCEDURE WAS STOPPED BY USER 14/12/2008 17:35:28 Elapsed: 3 secs. 14/12/2008 17:35:31 SIGNED MODE (USING SERVER). 14/12/2008 17:35:31 ALTERNATIVE SECURITY BYPASS ENABLED. 14/12/2008 17:35:45 ChipID:9900,EMP protocol:0301 14/12/2008 17:35:46 14/12/2008 17:35:46 PHONE IS RED RETAIL PRODUCT 14/12/2008 17:35:46 FLASH CID detected:52 14/12/2008 17:35:46 Speed:921600 14/12/2008 17:35:46 OTP LOCKED:1 CID:51 PAF:1 IMEI:35901901197515 CERT:RED 14/12/2008 17:35:46 FLASH CID:52 COLOR:RED 14/12/2008 17:35:47 PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 14/12/2008 17:35:47 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 14/12/2008 17:35:47 Flash ID check:897E 14/12/2008 17:35:47 Flash props sent ok 14/12/2008 17:35:49 LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 14/12/2008 17:35:49 loader startup: executed 14/12/2008 17:36:02 loader GDFS startup: executed 14/12/2008 17:39:02 wrong response, break. 14/12/2008 17:39:02 loader fs startup failed, that is fatal 14/12/2008 17:39:02 Elapsed: 211 secs. now when i pwoer on the phone i have o,ly blue screan * * help |
12-15-2008, 10:35 | #8 (permalink) |
Banned Join Date: Jul 2006 Location: dword ptr [ebp-1C], edx
Member: 322417 Status: Offline Thanks Meter: 940 | Hard is to get TP Procedure is simple Sw ask for First stage connect 1-TP procedure continue then SW ask For second thats All Problem is too unhidden TP thats All (but no one can hlp u at that u should do by ur self) Regards |
Can't unlock vs7 help??? | LENNYOMAR | Infinity-Box | 4 | 09-26-2007 17:10 |
Can't unlock A920. Help, please. | chris_ua | Motorola P2K (USB-Smart) | 3 | 05-31-2006 09:12 |
e616v I can't unlock it. Help!!! | oce | NEC | 6 | 04-05-2005 11:25 |
can't unlock z1010...HELP SOS | tommaso | FuriouS II | 10 | 12-10-2004 13:42 |
Can't unlock C25 - HELP NEEDED!!! | Chawek | x1x to x45/x50 | 2 | 05-28-2002 17:43 |
