02-18-2014, 08:10 | #18 (permalink) |
No Life Poster Join Date: Mar 2006
Member: 240043 Status: Offline Thanks Meter: 78 | this is so hard job 1.-first uninstall all drivers blackberry ( i use finally revoininstaler pro for delete all keys and register ) 2.-then install lgtool 232 the support say he next step is install libusb-win32 but i think is not necesary because in the next step the program install automatic the libusb win 32 and make conflict 3.-then install lgtool bb support 4.-in the device manager check you have instaled libusbwin32 this libusb show blackberry smartphone 5.-if you see this device with triangle yellow use the aplication winusb inf, next, select blackberry, the program ask for location you save a file , save this file, then restart your pc 6.-check again if your blackberry is instaled good, if the triangle yellow is present update manually your drivers and search the file you are created in the step 5 |
