02-14-2009, 09:12 | #2 (permalink) |
No Life Poster Join Date: Nov 2004 Location: Capetown
Member: 91045 Status: Offline Thanks Meter: 8,696 | Identify First and check presence of Bypass and rest package Then Check at settings TAB Use server Enable Altbypass Enable preloader ByPass Press Unlock and follow Instruction on screen |
02-14-2009, 09:24 | #4 (permalink) |
Junior Member Join Date: Apr 2006
Member: 267007 Status: Offline Thanks Meter: 2 | thanks freid but when i do all the instriction i have this, tell me what's th peoblem v0.915018/UNI CARD SERIAL: 00032334 Loaded 51 flash descriptors ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:921600 Flash ID check:2019 Flash props sent ok OTP: LOCKED:1 CID:51 PAF:1 IMEI:3561xxxxxxxxxxxxxx CERT:N/A FLASH CID:53 COLOR:RED Model:K770i Brand:Generic MAPP CXC article: R8BA024 prg1201-7601_VODAFONE_VI MAPP CXC version: R8BA024 Language Package:VFE_LIVE_2 CDA article: 1202-3377 CDA version: R2A Default article: 1201-7603 Default version: R8BA024 PROVIDER: 234-15 Network LOCKED RESTORATION FILE PRESENT FOR DETECTED FIRMWARE BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE Elapsed: 33 secs. SIGNED MODE (USING SERVER). ALTERNATIVE SECURITY BYPASS ENABLED. PRELOADER SECURITY BYPASS ENABLED. ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:3561xxxxxxxxxxx CERT:N/A FLASH CID:53 COLOR:RED PATCH:071120 1355 HANCXC9876543210_DB2020_MEM_PATCHER_R2A012 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 Flash ID check:2019 Flash props sent ok LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed DISCONNECT PHONE NOW INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM22 PHONE READY TO PROCEED EXECUTOR STARTED REMOVE CABLE FROM PHONE REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK THEN PRESS "READY" ChipID:9900,EMP protocol:0301 BOOTROM MODE DETECTED Speed:921600 Trying to launch embedded bootloader... embedded flashloader not responds ! Elapsed: 300 secs. |
02-14-2009, 10:30 | #6 (permalink) | |
No Life Poster Join Date: Feb 2008 Location: pakistan Age: 43
Member: 705991 Status: Offline Thanks Meter: 115 | Quote:
Use server Enable Altbypass and then check | |
HELP how to unlock iphone 3.1 | laksh007 | iPhone 2 / iPhone 3G / iPhone 3GS | 7 | 03-31-2010 03:22 |
how to unlock LG GR 500 with setool help | Master Software | SETool2 | 2 | 02-17-2010 16:36 |
help how to unlock Cb630 for free??? | D2MURA | LG | 2 | 12-10-2009 09:49 |
how to unlock Sony ericssion s302 with setool | unlock & flash | SE Power Clip & Turbo Unlocker | 7 | 03-19-2009 18:09 |
