03-02-2009, 16:46 | #2 (permalink) |
Junior Member Join Date: Nov 2006 Location: mexico chilangolandia
Member: 401792 Status: Offline Thanks Meter: 3 | check this... you have write this file 071219_DB2020_CROD_CID_49___51_to_CID52_Red.gdfs you find in folder setool scripts in misc and select user signed mode |
The Following User Says Thank You to leinadblack For This Useful Post: |
03-02-2009, 16:49 | #3 (permalink) |
Freak Poster Join Date: Apr 2006 Location: P A K I S T A N (RWP)
Member: 267787 Status: Offline Thanks Meter: 71 | Select Db2020 whitch u want to cahnge CID 49 to 52 Select on Misc Files (DB2020_CID49_51_to_CID52_OLD) On setting Select only Signed Mode and last Click on Write SCRIPT if not success Use this (DB2020_CID49_51_to_CID52) (Files u can find in main exe. in Script Folder ) Use only USB Interface Br. Anees-ur-rehman |
The Following User Says Thank You to Anees-ur-rehman For This Useful Post: |
03-10-2009, 04:44 | #5 (permalink) |
No Life Poster Join Date: Apr 2008 Location: karachi .. Age: 38
Member: 749969 Status: Offline Sonork: 100.1581886 Thanks Meter: 771 | i think old file is much better work (DB2020_CID49_51_to_CID52_OLD) |
The Following User Says Thank You to MYUNLOCKING For This Useful Post: |
03-10-2009, 05:00 | #6 (permalink) |
Junior Member Join Date: Mar 2009 Location: Mexico
Member: 990921 Status: Offline Sonork: cel_unlock_2009 Thanks Meter: 0 | up db2020 you have to get the soft XS, just conect your phone and the program is going to ask if you want to up and put yes and it would work it`s realy easy dont forget say thaks |
03-11-2009, 17:13 | #9 (permalink) |
Member: 990921 Status: Offline Sonork: cel_unlock_2009 Thanks Meter: 0 | I underestand but i just give solution, i don`t have any problem to use it, everybody decide what to use Think that just is a solution no use if you don`t want. |
pls how to change from cid 49 to 52 w580 | TALIAT | SETool2 | 12 | 01-22-2014 15:46 |
how to write script to change k530i cid 49 to cid 52 with setool | med26 | Sony Ericsson | 2 | 03-19-2010 09:08 |
PLS I NEED STEP BY STEP PROCEDURE HOW TO CHANGE K800i CID 49 TO 52 | ojs | Cruiser Suite | 1 | 03-31-2008 12:03 |
How to unlock DB2020 CID 49 and CID 51 for FREE with MT box SE | SoftMobile | MT-BOX | 30 | 02-25-2008 21:10 |
้how to convert w850 cid 49 to cid 52 | t2520 | Universalbox | 2 | 06-15-2007 19:32 |
