02-04-2010, 19:43 | #3 (permalink) | |
No Life Poster Join Date: Jun 2007 Location: SPAIN
Member: 532853 Status: Offline Thanks Meter: 610 | Quote:
select gt500 tick only signed mode clik unlock conect it to boot mode( volum up and atach cable) after unlock got to suport download propery firmware gt505 (3 files) and flash the phone. that s all. unlocked many phone gt505. | |
The Following 8 Users Say Thank You to mamepap For This Useful Post: |
02-09-2010, 15:20 | #7 (permalink) | |
No Life Poster Join Date: Sep 2007 Location: Madrid, Spain
Member: 591052 Status: Offline Sonork: 100.1592747 Thanks Meter: 95 | Quote:
hi bro i have just done GT505 with same procedure but still phone is lock. after flash dont acept sim. wht should be the problem | |
02-10-2010, 15:52 | #8 (permalink) |
Insane Poster Join Date: Feb 2008 Location: FRANCE Age: 44
Member: 709142 Status: Offline Sonork: 100.114099 Thanks Meter: 17 | enter code lg gt505 okkkkk GT505 1. Turn phone on without simcard 2. Press telephone icon at bottom of screen to bring up the phone keypad 3. Enter 2945#*505# 4. A menu will pop up, select sim unlock 5. Enter your unlock code and press ok 6. The phone will then reboot and the unlock is complete Best Regards Aziz |
04-04-2010, 18:17 | #10 (permalink) |
No Life Poster Join Date: Oct 2007 Location: AROUND THE WORLD
Member: 617412 Status: Offline Thanks Meter: 177 | lg gt505successfully unlock with se tool RUNNING v1.0/UNI CARD SERIAL 00054621 USBFLASH DRIVER VERSION 02.02.00.05 SIGNED MODE (USING SERVER) CFG:100000000000 ChipID900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,54,0,35469503150402] OTP LOCKED:1 CID:54 PAF:0 IMEI:35469503150402 CERT:RED LDR:080805 1255 YTRCXC1723918_A2_DB3200_PRODUCTION_LOADER_ACC_SDRA M_P2B LDR CAPS:SYSTEM SIGNATURE LDR:080905 0936 YTRCXC1723919_1A2_DB3200_PRODUCTION_LOADER_APP_SDR AM_JEFF_CABS_P2D LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM WRITING CLEAR SIMLOCK UNITS... ALL UNLOCK/LOCK CODES SET TO "85041681" phone detached Elapsed: 18 secs. SIGNED MODE (USING SERVER) CFG:100000000000 ChipID900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,54,0,35469503150402] OTP LOCKED:1 CID:54 PAF:0 IMEI:35469503150402 CERT:RED LDR:080805 1255 YTRCXC1723918_A2_DB3200_PRODUCTION_LOADER_ACC_SDRA M_P2B LDR CAPS:SYSTEM SIGNATURE LDR:080905 0936 YTRCXC1723919_1A2_DB3200_PRODUCTION_LOADER_APP_SDR AM_JEFF_CABS_P2D LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM writing "D:\SONY ERICSSON FLASH\gt505v10b\BIN-GT505AT-00-V10b-VDF-PT-OCT-07-2009+0\cxc000000_APPLICATION_PHONE_SB_IAR-ARM-NAND.ssw" ALLOWED DOMAINS:BLUE BROWN RED MAXIMUM CID:54 Will flash 632 blocks... ssw file accepted writing "D:\SONY ERICSSON FLASH\gt505v10b\BIN-GT505AT-00-V10b-VDF-PT-OCT-07-2009+0\CXC_FS_CABS_LP_NAND_commercial.ssw" ALLOWED DOMAINS:BLUE BROWN RED MAXIMUM CID:54 Will flash 1410 blocks... ssw file accepted writing "D:\SONY ERICSSON FLASH\gt505v10b\BIN-GT505AT-00-V10b-VDF-PT-OCT-07-2009+0\CXC_LGPXO_SYS_CABS_LP_NAND_commercial.ssw" ALLOWED DOMAINS:BLUE BROWN RED MAXIMUM CID:54 Will flash 332 blocks... ssw file accepted Phone detached Elapsed: 619 secs. hi my friend IN SE TOOL BOX YOU CAN CHOOSE LG GT500 UNLOCK IT IN SIGN MODE. THEN YOUR PHONE IS DEAD . AFTER YOU CAN FLASH IT IN SIGN MODE YOUR PHONE WIL BE UNLOCKED. WITH USB NOKIA 5310 DONT USE ANY CODE OK WHEN YOU UNLOCK TO PHONE BEFORE FLASH READ THIS OK ALL UNLOCK CODE SETS ITS MEAN YOUR PHONE IS 10000000000% UNLOCK YOU CAN FLASH TOP MAN |
06-18-2010, 17:10 | #11 (permalink) |
No Life Poster Join Date: May 2006
Member: 275689 Status: Offline Thanks Meter: 64 | I jus unlocked and flashed my phone now. i added the 3 flash files and then choose SIGNED MODE and CUSTOMIZE PHONE AFTER FLASH from Setting tab and i flashed the phone. at the end of flashing it gave one error: MAXIMUM CID:54 Will flash 349 blocks... ssw file accepted using GENERIC phone customization tpa/preset/custom/CONTENT_DOWNLOAD_HOOK.itm [fsFileWrite] err:0004 fail Phone detached Elapsed: 768 secs. even though it gave this error, but still phone has come alive and is unlocked also. so why did it give this error? what did i do wrong? did i select the wrong options or something? |
06-19-2010, 09:53 | #13 (permalink) |
Member: 275689 Status: Offline Thanks Meter: 64 | Ah ok, so i should only tick SIGNED MODE. Well even though it gave an error, still it has flashed the phone ok and also unlocked it, and now the phone is alive. so i dont need to flash it again, do i? |
06-20-2010, 12:01 | #15 (permalink) | |
Freak Poster Join Date: Mar 2008 Location: Romania
Member: 730652 Status: Offline Thanks Meter: 74 | Quote:
I do this with two identical passages with signed mod only ! | |
HOW TO unlock SE v600i ??please help | xiongfuchen | SETool2 | 15 | 05-21-2013 08:10 |
HELP how to unlock iphone 3.1 | laksh007 | iPhone 2 / iPhone 3G / iPhone 3GS | 7 | 03-31-2010 03:22 |
how to unlock iphone 3.0 | louisgsm | iPhone 2 / iPhone 3G / iPhone 3GS | 10 | 03-29-2010 15:53 |
How to Unlock LG GT505? waiting for Answer from Support?????? [SOLVED] | malikzahidawan | FuriousGold | 4 | 09-29-2009 06:57 |
How to Unlock LG GT505? waiting for Answer from Support?????? | malikzahidawan | VygisToolbox | 1 | 09-23-2009 19:01 |
