07-13-2012, 11:34 | #1 (permalink) |
Freak Poster Join Date: Jul 2008 Location: portugal
Member: 812540 Status: Offline Sonork: 100.1590091 Thanks Meter: 128 | i have lost my creadets but my phone is not unlocked thanks SERVER CREDITS LEFT/USED: 17/13 CARD COUNTERS: FLASH 119, UNLOCK 216 Elapsed: 3 secs. SIGNED MODE (USING SERVER) CFG:100000000000 ChipID: F100, EMP protocol: 0401 PHONE DOMAIN: "RETAIL" PHONE CID: 0081 OTP LOCKED: 1 CID: 81 PAF: 1 IMEI: 01269400731226 CERT: RED LDR: 2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS: SYSTEM FLASH SIGNATURE AUTH LDR: 2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS: SYSTEM FLASH GDFS FILESYSTEM TA USERCODE RESET TO "0000" Unlock DONE Elapsed: 16 secs. SIGNED MODE (USING SERVER) CFG:100010000000 ChipID: F100, EMP protocol: 0401 PHONE DOMAIN: "RETAIL" PHONE CID: 0081 OTP LOCKED: 1 CID: 81 PAF: 1 IMEI: 01269400731226 CERT: RED LDR: 2010-03-02 18:05 1212-4656_DB3350_CS_LOADER_ACC_SDRAM_R2A096 LDR CAPS: SYSTEM FLASH SIGNATURE AUTH LDR: 2010-03-02 18:06 1212-4655_DB3350_CS_LOADER_APP_SDRAM_R2A096 LDR CAPS: SYSTEM FLASH GDFS FILESYSTEM TA Executing CSCA-based unlock. Checking for signature ... Waiting for calculation process ... RESPONSE: "SUCCESS" [1038] server error:remote dongle not available Unlock FAILED Elapsed: 14 secs. SIGNED MODE (USING SERVER) CFG:100010000000 SERVER CREDITS LEFT/USED: 14/16 CARD COUNTERS: FLASH 119, UNLOCK 217 Elapsed: 2 secs. SIGNED MODE (USING SERVER) CFG:100010000000 SERVER CREDITS LEFT/USED: 14/16 |
07-13-2012, 11:48 | #3 (permalink) |
Product Manager Join Date: Sep 2009 Location: Pakistan Age: 36
Member: 1118710 Status: Offline Sonork: 100.1604414 Thanks Meter: 4,970 | CID 80 & 81 try this Method.. If ur Logs Deduct Once Time then no need any logs to unlock ur set you MUST flash r7cXXX firmware version to be able unlock w20 phone with CSCA method. 1. Select Proper Model From List & Go to Setting Option 2. Select Sign Mode 3. Perform Full Unlock Instead User Code Reset 4. Disable Flash Mode Activation For Semc A2 Phones 5. Press Unlock 6. when you will get message "unlock done" - do not remove cable or battery, wait until phone automatically power on, otherwise you will get 5 locks and need to repeat procedure. |
The Following User Says Thank You to Danish Shafiq For This Useful Post: |
07-13-2012, 11:49 | #4 (permalink) |
No Life Poster Join Date: Jun 2010 Age: 14
Member: 1315677 Status: Offline Thanks Meter: 1,440 | Hazel tick 1+5+6 and press unlock follow setool directive at the end "unlock done" let the phone fully restarts by itself (don't remove the cable or the battery) |
The Following User Says Thank You to :Aishur: For This Useful Post: |
Help: Forgot my 6110 user lock code!! | GByte9 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 02-26-2016 14:52 |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
