03-30-2010, 01:24 | #1 (permalink) |
No Life Poster Join Date: May 2005
Member: 148833 Status: Offline Thanks Meter: 25 | I uesd to use Cruiser..Hi SETOOL-Team:How to unlock k550im cid52 ? step by step |
The Following User Says Thank You to beneto For This Useful Post: |
03-30-2010, 01:52 | #2 (permalink) | |
Freak Poster Join Date: Jul 2009 Location: Inside SoftwaŽe
Member: 1084363 Status: Offline Thanks Meter: 109 | Quote:
@beneto, you are almost 5 years here in GSm City.. but you dont even know how to unlock that kind of phone.. and one more thing please try to make a little bit more clear you are new in Setool but you are asking support for cruiser..???? | |
03-30-2010, 08:49 | #4 (permalink) | |
No Life Poster Join Date: Jan 2008 Location: Kabul Afghanistan
Member: 687312 Status: Offline Thanks Meter: 290 | Quote:
Mate here is complete Vedio Tutorial of SEtool you can learn all from this Tutorial . 4shared.com - online file sharing and storage - download VIDIO TUTORIAL SE TOOL SOLUTION ALL IN ONE exe.rar WBR Last edited by NawabN Sahoo; 03-30-2010 at 08:58. Reason: mistyping | |
The Following User Says Thank You to NawabN Sahoo For This Useful Post: |
03-30-2010, 19:34 | #5 (permalink) |
Member: 148833 Status: Offline Thanks Meter: 25 | Where is the problem with 5years ??? I should know eveything & every box on GSM.Hosting ?!?Please,if you have something to share,you will be thanked if not you'll be thanked as well.Till now no one has given an exact answer to my question ? |
03-30-2010, 20:06 | #6 (permalink) |
Member: 687312 Status: Offline Thanks Meter: 290 | Mate you could do easily according video tutorial anyway follow these steps: 1_ Choose your model and select usb as interface 2_Go to setting tab and tick mark on Sign mode and Full unlock instead of usercode 3_ Come back SonyEricsson tab press Unlock\Repair button and press C button of phone and inser usb cable 4-Now software will ask you to remove cable and insert a test sim or its original simcard and turn on phone in normal mode and inserst cable 5_ PC will asl driver and you must install driver from your models sign mode drivers folder(you can download it from support) 6_when drivers installed after some process software will ask you again to removethe cable and attach turn off phone by pressing C. It was step by step unlocking process. WBR |
03-30-2010, 23:50 | #8 (permalink) |
Member: 148833 Status: Offline Thanks Meter: 25 | Manner of how to unlock a handset on Video tutorial are very old they belongs to 0.914013 versionas the settings are very different from that of 1.01 !?!?..Mr.NawabN has well explained the procedure and ought to be thanked for that but this procedure is not correct for k550im !? I do so and now my handset has no network !?!?!? |
03-31-2010, 00:50 | #9 (permalink) | |
No Life Poster Join Date: Oct 2002 Location: PARIS
Member: 16856 Status: Offline Sonork: 1582037 Thanks Meter: 441 | Quote:
Use Setool2 V1.xx version Don't add your login details ! Go to Empty fill tab set model "K550" Go to settings and tick Signed Mode Go to Empty fill tab press Recovery Connect phone to USB Hold 2+5 keys Click ADD and set a K550 GDFS.SSW from SETOOL\GDFS folder Connect phone to USB Hold 2+5 keys Press Flash Click Remove and repeat the operation with Erom (DB2020 CID53) Connect phone to USB Hold 2+5 keys Press Flash Phone is Full Unlocked for Free and working again ! 100% Tested & Working, this is not cruiser section BR Max_B | |
05-08-2010, 13:08 | #10 (permalink) | |
No Life Poster Join Date: May 2009 Location: here and there!!
Member: 1039966 Status: Offline Thanks Meter: 148 | Phone say sim card not correct Quote:
but then i put the sim card and dont accepted one diferent sim card and the origibnal too now dont acepted any sim card, wht i do? | |
Guide: How to Activate SETOOL Step by Step | shahzaadbutt | SETool2 | 66 | 06-15-2023 11:12 |
How to unlock k550im cid52 ? | beneto | Cruiser Suite | 2 | 03-31-2010 09:14 |
how to use cruiser with SE A1 Java Unlocker plz help | amanhalwara | Cruiser Suite | 3 | 05-07-2009 02:30 |
Step by Step how to Unlock BB5 Phone Using BB5BOX By Raskal | Ron2pet | BB5BOX | 12 | 09-21-2007 09:54 |
step by step method to unlock swith setool with credit | a2b2t | Sony Ericsson | 6 | 07-25-2007 05:51 |
