03-22-2010, 15:22 | #1 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Karachi,Pakistan Age: 34
Member: 701004 Status: Offline Sonork: 1626436:danish Thanks Meter: 116 | K800 (3g)Insert correst usim help Have a good all of you ? |
03-23-2010, 08:29 | #6 (permalink) |
Member: 701004 Status: Offline Sonork: 1626436:danish Thanks Meter: 116 | v0.915059/UNI CARD SERIAL: 00049526 Loaded 51 flash descriptors SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110000000000 ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35731501978973 CERT:N/A FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID:897E LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader GDFS startup executed loader FILESYSTEM startup executed INSERT SIM CARD, FULLY TURN PHONE ON GO TO GAMES MENU AND RUN EXECUTOR AFTER PHONE TURNS OFF OR HANGS REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK FINALLY PRESS "READY" |
03-23-2010, 08:42 | #9 (permalink) |
No Life Poster Join Date: Nov 2008 Location: RVIII
Member: 890926 Status: Offline Thanks Meter: 2,053 | Power on phone without simcard, Download driver here...Sony Ericsson - Emma |
03-23-2010, 08:54 | #10 (permalink) |
Member: 701004 Status: Offline Sonork: 1626436:danish Thanks Meter: 116 | I did download the driver but then i hold "c" then semc usb driver need but when i try to install it's show can't install driver this hardwere.thx |
03-23-2010, 09:57 | #12 (permalink) |
Member: 701004 Status: Offline Sonork: 1626436:danish Thanks Meter: 116 | v0.915034/UNI CARD SERIAL: 00049526 Loaded 51 flash descriptors ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 Flash ID check:897E Flash props sent ok OTP: LOCKED:1 CID:51 PAF:1 IMEI:35731501978973 CERT:RED FLASH CID:52 COLOR:RED Model (from GDFS):K800i Brand:Generic MAPP CXC article: R8BA024 prgCXC1250210_GENERIC_WI MAPP CXC version: R8BA024 Language Package:EUROPE_5 CDA article: CDA102511/2 CDA version: R2A Default article: cxc1250490 Default version: R8BA024 PROVIDER: 000-00 Network LOCKED RESTORATION FILE NOT PRESENT "R8BA024_CXC1250210_GENERIC_WI" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE SECURITY UNITS BACKUP CREATED. Elapsed: 7 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED. ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35731501978973 CERT:RED FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:897E Flash props sent ok LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed DISCONNECT PHONE NOW INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PROCEDURE WAS STOPPED BY USER Can't find attached phone with IMEI 35731501978973 Elapsed: 83 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED. ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35731501978973 CERT:RED FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:061201 1314 HANCXC1329129_DB2020_FLASHLOADER_R2A005 Flash ID check:897E Flash props sent ok LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader startup: executed loader GDFS startup: executed loader filesystem startup: executed loader unlock: executed DISCONNECT PHONE NOW INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM8 SIM CARD NOT PRESENT IN PHONE OR PIN NOT ENTERED. Elapsed: 220 secs. |
03-23-2010, 10:08 | #14 (permalink) |
No Life Poster Join Date: Jan 2010 Location: Sydney Age: 37
Member: 1205146 Status: Offline Thanks Meter: 879 | you need test sim card or original sim card to unlock this phone. without that no u can't unlock it . even with Setool , Crusier, Ub.. u need sim card. This sim card we talking about/ LITTLE MASTER |
k800 unlocking problem pl help me | ruvanw1979 | Cruiser Suite | 3 | 02-15-2008 10:05 |
k800 cid 49 imei help me please | gessebsb | Universalbox | 2 | 10-17-2007 00:50 |
K800 Flash problem, Plz Help! | Saff | Sony Ericsson | 0 | 09-09-2007 23:42 |
K800 wrong ocde!!! Please help! | KUBAT1 | Cruiser Suite | 4 | 07-25-2007 17:16 |
k800 unlocking error plz help | falak | Universalbox | 5 | 01-18-2007 14:48 |
