Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > SETool2
Old 11-29-2011, 11:26   #1 (permalink)
Member: 323481
Thanks Meter: 43
LT18i unlock done by setool using testpoint
DETACH USB CABLE FROM PHONE
REMOVE BATTERY FROM PHONE
ATTACH TESTPOINT
PRESS "READY", THEN ATTACH USB CABLE TO PHONE
PROCEDURE WAS STOPPED BY USER
FAILED TO SETUP PHONE
Unlock FAILED
Elapsed: 64 secs.
SIGNED MODE (USING SERVER)
ALTERNATIVE SECURITY BYPASS ENABLED
CFG:110010000010
ATTACH TESTPOINT
PROCESSING ...
REMOVE TESTPOINT NOW, THEN PRESS "READY"
PLEASE ATTACH TURNED OFF PHONE NOW
PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ...
RUNNING S1_LOADER VER "R4A069"
LOADER AID: 0001
FLASH ID: "002C/00B3"
LOADER VERSION: "r4A069"
PHONE IMEI : 35850604242826
Checking for signature ...
Waiting for calculation process ...
RESPONSE: "SUCCESS" [1256]
WRITING SEMCBOOT ...
Unlock DONE
Procedure:
1.
prepare for testpoint operation.
check testpoints location for your phone model in dist\docs\s1_qualcomm_uart_cables or use GPG cable set
open testpoints for access
if you do not have GPG cable set, get some needle with wire, connect it to phone gnd ( battery minus ) or to usb cable shield, etc.
2.
select proper phone model.
select COM as interface.
on settings check signed mode, use alternative security bypass, do full unlock instead usercode reset, use testpoint (gnd type)
fill login/password and check if account valid.
press unlock
when prompted, execute steps in EXACT order:
  1. remove cable from phone,
  2. remove battery from phone,
  3. attach testpoint ( turn on switch on cable set )
  4. insert cable to phone, HOLDING TESTPOINT ( cable set switch in "on" position )
  5. press "ready"
  6. when prompted detach testpoint
  7. press "ready"
  8. install drivers from dist\drivers\USBFlash_driver\ ( if asked )
phone will be unlocked.
The Following 3 Users Say Thank You to kosta25 For This Useful Post:
Old 11-29-2011, 13:19   #2 (permalink)
dilshad_noori's Avatar
Member: 1293519
Sonork: 100.1596500
Thanks Meter: 169
ATTACH TESTPOINT
Unlock FAILED
Elapsed: 64 secs.
CFG:110010000010
ATTACH TESTPOINT
PROCESSING ...
LOADER AID: 0001
Unlock DONE
Procedure:
1.
2.
press unlock
  5. press "ready"
  7. press "ready"
Good Info.....................
Old 12-27-2011, 15:22   #3 (permalink)
Member: 1612905
how to unlock without setol sony ericsson KT18i
Old 07-28-2012, 15:19   #4 (permalink)
Member: 152547
Sonork: 100.1586021
Thanks Meter: 143
CFG:110010000010
ATTACH TESTPOINT
PROCESSING ...
llbug: write error: "The device does not recognize the command"
llbug: blk write fail.fatal
qcSendPacket: can't send packet.
Unlock FAILED
Elapsed: 64 secs.
CFG:110010000010
ATTACH TESTPOINT
PROCESSING ...
qcReceivePacket: can't get packet start.
Unlock FAILED
Elapsed: 180 secs.
Old 07-28-2012, 18:07   #5 (permalink)
koperta4512's Avatar
Member: 1704846
Sonork: 1617108
Thanks Meter: 117
HOW TO WORK WITH SEMC PDA PHONES - Page 2
The Following User Says Thank You to koperta4512 For This Useful Post:
Old 07-30-2012, 12:37   #6 (permalink)
Member: 643752
Thanks Meter: 10
where can find s1_qualcomm_uart_cables or use GPG cable??i only have E20.X10.E16.E10 GPG cable,but not use in LT18i
Old 07-30-2012, 18:17   #7 (permalink)
Member: 1704846
Sonork: 1617108
Thanks Meter: 117
Because the cable is not needed, go to youtube and find how to unlock phone via SETool.
Old 10-06-2012, 10:40   #8 (permalink)
dampealdany's Avatar
Member: 1308889
Sonork: 100.1608156
Thanks Meter: 266
can you show us the picture with the test point please, and i hear that this model LT18i canīt be unlocked, models made in 2012 can not be unlock. thx for some aclarations pls
Old 11-11-2012, 11:21   #9 (permalink)
.::Indian::.'s Avatar
Member: 37015
Thanks Meter: 67
CARD COUNTERS: FLASH 174, UNLOCK 54
Elapsed: 2 secs.
CFG:110010000010
ATTACH TESTPOINT
PROCESSING ...
Unlock FAILED
Elapsed: 107 secs.
how can solve this error?
Old 11-11-2012, 12:25   #10 (permalink)
:Aishur:'s Avatar
Member: 1315677
Thanks Meter: 1,439
new security (99.99%) if erom >=r9xxxx and YearwWeek >=12w14
read post #12 HOW TO WORK WITH SEMC PDA PHONES - Page 2
Old 06-24-2013, 15:19   #11 (permalink)
Member: 320108
Thanks Meter: 18
ATTACH TESTPOINT
Unlock FAILED
Elapsed: 64 secs.
CFG:110010000010
this log is not for LT18i and its misleading
ATTACH TESTPOINT
PROCESSING ...
LOADER AID: 0001
Unlock DONE
Procedure:
1.
2.
press unlock
  5. press "ready"
  7. press "ready"
this log is misleading and its not for LT18i
Old 05-28-2016, 19:55   #12 (permalink)
Kwesi_Roy_GH's Avatar
Member: 2575234
Thanks Meter: 1,134
28/05/2016 17:20:21 RUNNING v 1.1404/01.15/UNI
28/05/2016 17:20:21 CARD SERIAL 00236xxx
28/05/2016 17:20:21 USBFLASH DRIVER VERSION 03.00.00.00
28/05/2016 17:26:12 SIGNED MODE (USING SERVER)
28/05/2016 17:26:12 ALTERNATIVE SECURITY BYPASS ENABLED
28/05/2016 17:26:12 CFG:110010000000
28/05/2016 17:26:12
28/05/2016 17:26:12 DETACH USB CABLE FROM PHONE
28/05/2016 17:26:12 REMOVE BATTERY FROM PHONE
28/05/2016 17:26:12 ATTACH TESTPOINT
28/05/2016 17:26:12 PRESS "READY", THEN ATTACH USB CABLE TO PHONE
28/05/2016 17:26:12
28/05/2016 17:28:03 PROCESSING ...
28/05/2016 17:28:04 REMOVE TESTPOINT NOW, THEN PRESS "READY"
28/05/2016 17:28:04
28/05/2016 17:28:12 PLEASE ATTACH TURNED OFF PHONE NOW
28/05/2016 17:28:12 PRESS AND HOLD "BACK" OR "VOLUME DOWN" BUTTON ...
28/05/2016 17:28:14
28/05/2016 17:28:14 RUNNING S1_LOADER VER "R4A069"
28/05/2016 17:28:14
28/05/2016 17:28:14 EROM_AID : 0001
28/05/2016 17:28:14 LOADER_AID : 0001
28/05/2016 17:28:14 HWCONF_AID : 0001
28/05/2016 17:28:14 ACTIVE_LOADER_AID : 0001
28/05/2016 17:28:14
28/05/2016 17:28:18 DEVICE ID: 18A5E74DCEEED365ED81393AC49DBCD1B171D1F7
28/05/2016 17:28:18 FLASH ID: "002C/00B3"
28/05/2016 17:28:18 LOADER VERSION: "r4A069"
28/05/2016 17:28:18
28/05/2016 17:28:18 PHONE IMEI : 35850604218325
28/05/2016 17:28:20 Checking for signature ...
28/05/2016 17:28:21 WRITING SEMCBOOT ...
28/05/2016 17:28:22 Unlock DONE
28/05/2016 17:28:22 Elapsed: 130 secs.
The Following User Says Thank You to Kwesi_Roy_GH For This Useful Post:
Old 09-12-2016, 15:48   #13 (permalink)
Member: 2257138
Thanks Meter: 11
how to connect the test point , please diagram
Old 09-12-2016, 20:42   #14 (permalink)
Member: 1704846
Sonork: 1617108
Thanks Meter: 117
http://www.x10unlocked.com/images/te...SE_LT18_TP.jpg
Old 04-27-2017, 09:27   #15 (permalink)
snmobilecenter's Avatar
Member: 983663
Sonork: 100.1623270
Thanks Meter: 551
ATTACH TESTPOINT
will use DLOAD protocol ...
0806010100900000
0D1450424C5F446F776E6C6F6164657256455231
030006
030006
030006
PROCESSING ...
IF TESTPOINT DONE OK,THIS IS NOT SUPPORTED MCU REVISION
Unlock FAILED
Elapsed: 30 seconds
Not done
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
$50 Reward for unlocking my 6150!!! TheDon Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 03-23-2015 14:21
Page generated in 0.26798 seconds with 9 queries
