03-22-2010, 13:17 | #47 (permalink) |
No Life Poster Join Date: Jun 2006 Location: ..::SL3 Unlock Source::.. Age: 38
Member: 293662 Status: Offline Sonork: 100.1622609 Thanks Meter: 317 | W595 Unlock done ..... RUNNING v 1.01/UNI CARD SERIAL 00134356 USBFLASH DRIVER VERSION 02.02.00.05 CFG:000000000000 ChipID:C900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,52,1,35750002577835] OTP LOCKED:1 CID:52 PAF:1 IMEI:35750002577835 CERT:BROWN LDR:2009-06-26 15:52 CXC1250777_DB31XX_PRODUCTION_LOADER_ACC_SDRAM_R2A0 82 LDR CAPS:SYSTEM FLASH SIGNATURE LDR:2009-06-26 15:49 CXC1250779_DB31XX_EXPLORER_LOADER_APP_SDRAM_R2A082 LDR CAPS:SYSTEM FLASH GDFS FILESYSTEM TA Unlock FINISHED Elapsed: 18 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") CFG:110000000000 ChipID:C900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,52,1,35750002577835] OTP LOCKED:1 CID:52 PAF:1 IMEI:35750002577835 CERT:BROWN LDR:2009-06-26 15:53 CXC1250778_DB31XX_PRODUCTION_LOADER_APP_SDRAM_R2A0 82 DEVICE KEY:FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF (0) LDR:2009-04-21 18:17 CXC1250781_DB31XX_RESET_LOADER_ACC_SDRAM_R2A081 LDR:2009-04-21 18:18 CXC1250782_DB31XX_RESET_LOADER_APP_SDRAM_R2A081 GOT SEED:FA609D5234807C7425B0128D P96 AUTH PASSED RESETTING SECURITY TO FACTORY STATE... RESTARTING... ChipID:C900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,52,1,35750002577835] OTP LOCKED:1 CID:52 PAF:1 IMEI:35750002577835 CERT:BROWN LDR:2009-06-26 15:52 CXC1250777_DB31XX_PRODUCTION_LOADER_ACC_SDRAM_R2A0 82 LDR:2009-06-26 15:53 CXC1250778_DB31XX_PRODUCTION_LOADER_APP_SDRAM_R2A0 82 WRITING SEMCBOOT... PREPARING SECURITY... WRITING CLEAR SIMLOCK UNITS... ALL UNLOCK/LOCK CODES SET TO "65240566" CHANGING DOMAIN TO "CURRENT" SIGNING... DEVICE KEY RESTORED Unlock FINISHED Elapsed: 37 secs. |
03-22-2010, 13:26 | #48 (permalink) |
Member: 293662 Status: Offline Sonork: 100.1622609 Thanks Meter: 317 | Red Blink w580 RUNNING v 1.01/UNI CARD SERIAL 00134356 USBFLASH DRIVER VERSION 02.02.00.05 CFG:100000000000 Speed:921600 FLASH ID: 897E OTP: LOCKED:1 CID:51 PAF:1 IMEI:35243002356016 CERT:N/A FLASH CID:52 COLOR:RED PROCEDURE WAS STOPPED BY USER can't get packet start. setGDFS_params failed failed to setup GDFS Elapsed: 14 secs. RUNNING v 1.01/UNI CARD SERIAL 00134356 USBFLASH DRIVER VERSION 02.02.00.05 CFG:100000000000 RESET MODE STARTED ChipID:9900,EMP protocol:0301 Speed:921600 RESET:070703 1106 NPACXC1250329_DB2020_CERTRESETLOADER_P3AA FLASH ID: 897E GOT SEED:BE1CE62C2380AE602500EB56 P96 AUTH PASSED OTP: LOCKED:1 CID:51 PAF:1 IMEI:35243002356016 CERT:N/A PHONE SUCCESSFULLY RESET TO DEVELOPER STATE Elapsed: 5 secs. RUNNING v 1.01/UNI CARD SERIAL 00134356 USBFLASH DRIVER VERSION 02.02.00.05 CFG:100000000000 ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35243002356016 CERT:N/A FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID: 897E writing "D:\se-tool\v1.0\gdfs_in_ssw_format\db2020\W580_GDFS_SSW. ssw" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 640 Will flash 32 blocks... Setting up GDFS... OTP WRITE NOT EXECUTED WRITING CLEAR SIMLOCK UNITS... ALL UNLOCK/LOCK CODES SET TO "54383454" SIGNING... Elapsed: 43 secs. RUNNING v 1.01/UNI CARD SERIAL 00134356 USBFLASH DRIVER VERSION 02.02.00.05 CFG:100000000000 ChipID:9900,EMP protocol:0301 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35243002356016 CERT:N/A FLASH CID:49 COLOR:BROWN LDR:060721 1021 DB2020_SERVICE_LOADER FLASH ID: 897E writing "D:\se-tool\v1.0\eroms\db2020\DB2020EROM_CNV_RED52_BROWN_ CID49_DB2020.ssw" CURRENT FLASH FILE CID:49 SSW uses full hash, hash len is: 40 Will flash 2 blocks... Setting up GDFS... OTP WRITE NOT EXECUTED WRITING CLEAR SIMLOCK UNITS... ALL UNLOCK/LOCK CODES SET TO "26214262" SIGNING... Elapsed: 11 secs. CFG:000000000000 ChipID:9900,EMP protocol:0301 Speed:921600 FLASH ID: 897E OTP: LOCKED:1 CID:51 PAF:1 IMEI:35243002356016 CERT:N/A FLASH CID:52 COLOR:RED Model (from GDFS):W580i Brand:CTI Movil MAPP CXC article: R6BC002 prgCXC1123362_GENERIC_LA MAPP CXC version: R6BC002 Language Package: AMERICA_2 CDA article: CDA102774/69 CDA version: R5A Default article: cxc1123364 Default version: R6BC002 PROVIDER: 000-00 SIMLOCKS NOT DETECTED RESTORATION FILE NOT PRESENT "R6BC002_CXC1123362_GENERIC_LA" YOU MUST PERFORM FULL FLASHING WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED Elapsed: 3 secs. |
03-23-2010, 09:23 | #50 (permalink) | |
Member: 293662 Status: Offline Sonork: 100.1622609 Thanks Meter: 317 | Red Blink W850 repair done free............... Quote:
03-24-2010, 08:17 | #52 (permalink) |
Member: 293662 Status: Offline Sonork: 100.1622609 Thanks Meter: 317 | G502 Unlock Done ... SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") CFG:110000000000 ChipID:C900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,52,1,35461002855989] OTP LOCKED:1 CID:52 PAF:1 IMEI:35461002855989 CERT:RED LDR:2009-06-26 15:53 CXC1250778_DB31XX_PRODUCTION_LOADER_APP_SDRAM_R2A0 82 DEVICE KEY:C310B83B5A110EC161C61F05AA43D2D7 (0) LDR:2009-04-21 18:17 CXC1250781_DB31XX_RESET_LOADER_ACC_SDRAM_R2A081 LDR:2009-04-21 18:18 CXC1250782_DB31XX_RESET_LOADER_APP_SDRAM_R2A081 GOT SEED:1B246BDE348032692550FBD0 P96 AUTH PASSED RESETTING SECURITY TO FACTORY STATE... RESTARTING... ChipID:C900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,52,1,35461002855989] OTP LOCKED:1 CID:52 PAF:1 IMEI:35461002855989 CERT:BROWN LDR:2009-06-26 15:52 CXC1250777_DB31XX_PRODUCTION_LOADER_ACC_SDRAM_R2A0 82 LDR:2009-06-26 15:53 CXC1250778_DB31XX_PRODUCTION_LOADER_APP_SDRAM_R2A0 82 WRITING SEMCBOOT... PREPARING SECURITY... WRITING CLEAR SIMLOCK UNITS... ALL UNLOCK/LOCK CODES SET TO "47473287" CHANGING DOMAIN TO "CURRENT" SIGNING... DEVICE KEY RESTORED Unlock FINISHED Elapsed: 32 secs. |
03-24-2010, 08:18 | #53 (permalink) |
Member: 293662 Status: Offline Sonork: 100.1622609 Thanks Meter: 317 | W205 free Unlock SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED CFG:110000000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... EROM "R5A038" AID: 0001 SOFTWARE AID: 0001 SIMLOCK STATE: "NOT_TAMPERED" LOADER AID: 0002 FLASH ID: "00EC/3002" LOADER VERSION: "R3A011" PHONE IMEI:35809203833957 GOT SEED:E94B745D88018031C20087A7 P96 AUTH PASSED Searching... SIMLOCK CHECK FOUND Writing... Unlock DONE |
03-27-2010, 09:52 | #54 (permalink) |
Member: 293662 Status: Offline Sonork: 100.1622609 Thanks Meter: 317 | Tm506 Unlock Successfull select model Z780 Loaded 51 flash descriptors SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") CFG:110000000000 ChipID:C900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,52,1,35507602499961] OTP LOCKED:1 CID:52 PAF:1 IMEI:355076 CERT:RED LDR:2009-06-26 15:47 CXC1250843_DB31XX_CS_LOADER_ACC_SDRAM_R2A082 LDR:2009-06-26 15:48 CXC1250780_DB31XX_CS_LOADER_APP_SDRAM_R2A082 Model (from GDFS):TM506 MAPP CXC article: R3DA030 prg12033655_TMOUS_BL MAPP CXC version: R3DA030 Language Package: TMO-US CDA article: 1207-2630 CDA version: R31A Default article: 1203-3659 Default version: R3DA030 PROVIDER: MULTIPLE Network LOCKED Elapsed: 15 secs. SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED PLEASE CONNECT PHONE IN EMP BOOTROM MODE (HOLD "2+5") CFG:110000000000 ChipID:C900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,52,1,35507602499961] OTP LOCKED:1 CID:52 PAF:1 IMEI:35507 CERT:RED LDR:2009-06-26 15:53 CXC1250778_DB31XX_PRODUCTION_LOADER_APP_SDRAM_R2A0 82 DEVICE KEY:5C26D0A15CE7C44A42567CAC62459B9B (0) LDR:2009-04-21 18:17 CXC1250781_DB31XX_RESET_LOADER_ACC_SDRAM_R2A081 LDR:2009-04-21 18:18 CXC1250782_DB31XX_RESET_LOADER_APP_SDRAM_R2A081 GOT SEED:909AD15C3480046B25900F7A P96 AUTH PASSED RESETTING SECURITY TO FACTORY STATE... RESTARTING... ChipID:C900,EMP protocol:0401 BOOTROM MODE DETECTED OTP DBG: [1,52,1,35507602499961] OTP LOCKED:1 CID:52 PAF:1 IMEI:35507602499961 CERT:BROWN LDR:2009-06-26 15:52 CXC1250777_DB31XX_PRODUCTION_LOADER_ACC_SDRAM_R2A0 82 LDR:2009-06-26 15:53 CXC1250778_DB31XX_PRODUCTION_LOADER_APP_SDRAM_R2A0 82 WRITING SEMCBOOT... PREPARING SECURITY... WRITING CLEAR SIMLOCK UNITS... ALL UNLOCK/LOCK CODES SET TO "53002414" CHANGING DOMAIN TO "CURRENT" SIGNING... DEVICE KEY RESTORED Unlock FINISHED Elapsed: 33 secs. |
03-27-2010, 14:50 | #55 (permalink) |
Freak Poster Join Date: Nov 2008 Location: Bangladesh Age: 39
Member: 908875 Status: Offline Thanks Meter: 30 | SATIO unlock succes go setting tick 1 SIGNED MODE (USING SERVER) tick 6 PERFORM ''FULL UNLOCK'' INSTEAD OF ''USERCODE RESET'' SIGNED MODE (USING SERVER) CFG:100000000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "GREEN" BUTTON... EROM "R6A032" AID: 0001 SOFTWARE AID: 0001 SIMLOCK STATE: "NOT_TAMPERED" LOADER AID: 0002 FLASH ID: "00EC/0040" LOADER VERSION: "R4A012" PHONE IMEI:3568100.......... USERLOCK RESET TO "0000" Elapsed: 19 secs. SIGNED MODE (USING SERVER) CFG:100001000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "GREEN" BUTTON... EROM "R6A032" AID: 0001 SOFTWARE AID: 0001 SIMLOCK STATE: "NOT_TAMPERED" LOADER AID: 0002 FLASH ID: "00EC/0040" LOADER VERSION: "R4A012" PHONE IMEI:3568100.......... MINOR ERROR "MISC_ERROR (No_such_unit_(0x0004))" IN "MISC_CLASS" Checking for signature... Waiting for calculation process... RESPONSE: "SUCCESS" [1048] GOT SEED:EA59BC6F80CA713520DE48DFAD6BA770 OMAP P96 AUTH PASSED GOT SEED:4822CDE26F80CA713520DE48BC5F2B96 CCPU P96 AUTH PASSED Unlock DONE Elapsed: 21 secs. |
The Following User Says Thank You to OYES AHMED For This Useful Post: |
03-27-2010, 14:52 | #56 (permalink) |
Member: 908875 Status: Offline Thanks Meter: 30 | W660 Unlock Success............... SIGNED MODE (USING SERVER) ALTERNATIVE SECURITY BYPASS ENABLED PRELOADER SECURITY BYPASS ENABLED CFG:111111000000 ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 OTP: LOCKED:1 CID:51 PAF:1 IMEI:35715501579850 CERT:RED FLASH CID:52 COLOR:RED PATCH:061205 1523 HANCXC9876543210_DB2020_MEM_PATCHER_R2A006 0 LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015 FLASH ID:897E LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013 loader GDFS startup executed loader FILESYSTEM startup executed DISCONNECT PHONE NOW INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN INSTALL PHONE MODEM DRIVERS IF NEEDED SEARCHING FOR PHONE, "STOP" TO ABORT PHONE FOUND AT COM124 PHONE READY TO PROCEED EXECUTOR STARTED REMOVE CABLE FROM PHONE REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK FINALLY PRESS "READY" ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0052 Speed:921600 STARTING BOOTLOADER... INT LDRB2020_PRELOADER_FOR_SETOOL2 LDRB2020 LOADER FOR SETOOL2 FLASH ID:897E FOUND VERSION "R8BB001_CXC1250446_GENERIC_FY" can't open file "E:\DIVICE SOFT\SE Tool\v0.915062\rest\R8BB001_CXC1250446_GENERIC_FY" writing "D:\SE-TOOL- Flash\w660\R8BB001_1250446_GENERIC_FY.ssw" CURRENT FLASH FILE CID:52 SSW uses full hash, hash len is: 9200 Will flash 460 blocks... writing "D:\SE-TOOL- Flash\w660\R8BB001_FS_MEDITERR_FY_RED_CID52.ssw" CURRENT FLASH FILE CID:52 SSW uses full hash, hash len is: 3780 Will flash 189 blocks... USERCODE RESET TO "0000" Searching... Firmware SIMLOCK check determined. LDR:060426 1726 HANCXC1329133_DB2020_FILESYSTEMLOADER_P5G loader GDFS startup executed loader FILESYSTEM startup executed using GENERIC phone customization tpa/preset/custom/C3_PCA_G3v2.cer tpa/preset/custom/CONTENT_DOWNLOAD_HOOK_2.itm tpa/preset/custom/customize.xml tpa/preset/custom/DESKTOP_HOOK_2.itm tpa/preset/custom/Entrust.net Root Certificate.cer tpa/preset/custom/Entrust.net_WTLS_Root_Certificate.wcrt tpa/preset/custom/FM_PICTURES_HOOK_3.itm tpa/preset/custom/FM_SOUNDS_HOOK_3.itm tpa/preset/custom/FM_THEMES_HOOK_3.itm tpa/preset/custom/FM_VIDEOS_HOOK_3.itm tpa/preset/custom/GAMES_HOOK_3.itm tpa/preset/custom/GTE_CyberTrust_Root.cer tpa/preset/custom/GTE_Cybe_Trust_Root_WTLS.wcrt tpa/preset/custom/Root.cer tpa/preset/custom/SEMC_E2E_Root_CA.crt tpa/preset/custom/SETT_RINGTONE_HOOK_3.itm tpa/preset/custom/ThawtePremium.der tpa/preset/custom/ThawteServerCA.cer tpa/preset/custom/Utiroot.cer tpa/preset/custom/VeriSignClass3Root.cer tpa/preset/custom/Verisign_Class_3_CA_WTLS.wcrt Phone detached Elapsed: 498 secs. |
03-28-2010, 09:49 | #57 (permalink) |
No Life Poster Join Date: Jan 2010 Location: Bangladesh Age: 34
Member: 1217931 Status: Offline Sonork: 100.1604251 Thanks Meter: 267 | ....::::t303 unlock done free::::..... PLEASE ATTACH TURNED OFF PHONE NOW PRESS "POWER ON" BUTTON SHORTLY... EROM "R5A038" AID: 0001 SOFTWARE AID: 0001 SIMLOCK STATE: "NOT_TAMPERED" LOADER AID: 0002 FLASH ID: "0089/8904" LOADER VERSION: "R3A011" PHONE IMEI:35379003011885 GOT SEED:94901AAF8700602AC200778A P96 AUTH PASSED Searching... SIMLOCK CHECK FOUND Writing... Unlock DONE Elapsed: 52 secs. |
03-28-2010, 16:28 | #59 (permalink) |
Member: 293662 Status: Offline Sonork: 100.1622609 Thanks Meter: 317 | U5 VIVAZ Unlock done 1 credits RUNNING v 1.01/UNI SIGNED MODE (USING SERVER) CFG:100001000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "GREEN" BUTTON... EROM "R8A017" AID: 0001 SOFTWARE AID: 0001 SIMLOCK STATE: "NOT_TAMPERED" LOADER AID: 0002 FLASH ID: "00EC/0040" LOADER VERSION: "R4A012" PHONE IMEI:35938703080567 MINOR ERROR "MISC_ERROR (No_such_unit_(0x0004))" IN "MISC_CLASS" Checking for signature... Waiting for calculation process... RESPONSE: "SUCCESS" [1048] GOT SEED:95C5B26F80DB7B3570AB1354 OMAP P96 AUTH PASSED GOT SEED:B9E2F8DA6F80DB7B3570AB13 CCPU P96 AUTH PASSED Unlock DONE Elapsed: 39 secs. |
03-28-2010, 16:30 | #60 (permalink) |
Member: 293662 Status: Offline Sonork: 100.1622609 Thanks Meter: 317 | Agin U5 VIVAZ Unlock done 1 credits RUNNING v 1.01/UNI SIGNED MODE (USING SERVER) CFG:100001000000 PLEASE ATTACH TURNED OFF PHONE NOW PRESS AND HOLD "GREEN" BUTTON... EROM "R8A017" AID: 0001 SOFTWARE AID: 0001 SIMLOCK STATE: "NOT_TAMPERED" LOADER AID: 0002 FLASH ID: "00EC/0040" LOADER VERSION: "R4A012" PHONE IMEI:35938703094752 MINOR ERROR "MISC_ERROR (No_such_unit_(0x0004))" IN "MISC_CLASS" Checking for signature... Waiting for calculation process... RESPONSE: "SUCCESS" [1048] GOT SEED:971A186F80DB7B350022170F OMAP P96 AUTH PASSED GOT SEED:CFD491816F80DB7B35002217 CCPU P96 AUTH PASSED Unlock DONE Elapsed: 31 secs. |
Post Here Sucessfully Flashing / Unlocking / Version 1.09 | Chennairam | Fast Dongle Solution | 8 | 01-24-2010 06:38 |
.:: POST Here Successfull Unlock :. | DaWizard | UST Pro II | 2 | 06-19-2009 18:27 |
Post here successfull unlocked by 103 and thanx to zulea | zahid_gsm | Nokia Base Band 5 ( BB-5 ) | 4 | 04-01-2009 19:10 |
Post Here successfull Unlock [SL_2] | The_Dj | Trash | 0 | 03-10-2009 00:26 |
