07-17-2011, 13:06 | #1 (permalink) |
Junior Member Join Date: Sep 2010
Member: 1388663 Status: Offline Thanks Meter: 2 | W800i Dead after unlock ALTERNATIVE SECURITY BYPASS ENABLED CFG:110010000000 ChipID:9900,EMP protocol:0301 PHONE STATE: "RETAIL" FLASH CID: 0053 Speed:115200 LDR:071130 1150 NPACXC1250330_DB2020_PRODUCTIONIDLOADER_P3M FLASH ID: 897E OTP LOCKED:1 CID:51 PAF:1 IMEI:35476902492173 CERT:RED ACTIVE CID:53 COLOR:RED no ack during gdfs_readvar ! SCRC READ FAILURE Elapsed: 7 secs. |
07-17-2011, 18:20 | #3 (permalink) |
No Life Poster Join Date: Feb 2008
Member: 696136 Status: Offline Thanks Meter: 210 | If phone does not turn on after flash or if stop during flash procedure than u must perform "reset" procedure, this procedure will also unlock your phone and user must do same procedure as follows. CID 50,51,52,53 that is so-called reset procedure. 1. go to emptyboard tab 2. select proper model 3. on settings, check "signed mode" 4. press recovery 5. after succeful recovery 6. on settings uncheck all 7. add to firmware area propergdfs in ssw format 8. add to firmware area proper EROM (EROM CID >= OTP CID) 9. press flash 10. if needed,reflash phone on usual semc tab with needed settings. Last edited by mobile mart; 07-17-2011 at 18:26. |
07-17-2011, 18:35 | #4 (permalink) |
No Life Poster Join Date: Sep 2007 Location: EARTH Age: 42
Member: 582682 Status: Offline Sonork: 100.1607124 Thanks Meter: 136 | bro it is not w800 it has cid 36,49 not cid 53 chek it will be w880 if it than flash with cid53 tik on setting tab use server customise perfom full unlock after flash than write flash your set will be ok but not unlock try again to unlock. |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
FAQ about unlock n0kia | man0n | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 11-29-2010 19:06 |
