HTC Android based General HTC Android phones discussion, firmwares, solution, root, help |
05-30-2015, 16:47 | #1 (permalink) |
No Life Poster Join Date: Jan 2009
Member: 946381 Status: Offline Thanks Meter: 150 | help me to unlock htc one m7 sprint locked C:\android>fastboot getvar all INFOversion: 0.5 INFOversion-bootloader: 1.57.0000 INFOversion-baseband: 2.03.30.0428 INFOversion-cpld: None INFOversion-microp: None INFOversion-main: 5.03.651.3 INFOversion-misc: PVT SHIP S-OFF INFOserialno: FA36SS906985 INFOimei: 990001469451041 INFOmeid: 99000146945104 INFOproduct: m7_wls INFOplatform: HBOOT-8064 INFOmodelid: PN0720000 INFOcidnum: 11111111 INFObattery-status: good INFObattery-voltage: 3855mV INFOpartition-layout: Generic INFOsecurity: off INFObuild-mode: SHIP INFOboot-mode: FASTBOOT INFOcommitno-bootloader: dirty-1f512bb6 INFOhbootpreupdate: 11 INFOgencheckpt: 0 all: Done! finished. total time: 0.078s i saw one method to unlock in below link http://forum.gsmhosting.com/vbb/f842...-done-1928786/ on FOR DEODEXED ROMS 1. first unlock bootloader reach on google 2. ROOTED with kimgo or vroot or another tool 3. Use the modified HtcOMADM_SPCS [MOD] SIM UNLOCK for 4.3 | Sprint HTC One | XDA Forums flash in recovery 4. Download Android Terminal Emulator 1.0.65Android Terminal Emulator (Android) - Télécharger . Type "su" (excluding quotation marks) and grant it superuser permission Type "am start com.redbend.vdmc/com.htc.omadm.test.TestMainActivity" (excluding quotation marks) You will get menu on your HTC In that menu, select "API", then scroll down 'till almost end and select "simlock" Reboot the phone and hopefully it would accept GSM SIM Enter *#*#4636#*#* in your dialer In the phone information section(the first one) set preferred network type to something that is GSM specific: "WCDMA Preferred", for example. The phone will switch to GSM mode can i unlock as in above procedure help me-i saw some guys have problems in above procedure help me |
05-30-2015, 19:30 | #2 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Read all this my procedure here: http://forum.gsmhosting.com/vbb/f842...off-s-1908356/ S-OFF today can get only with "SunShine.Apk" , (payment option), or by Java Card. But i've tested also with S-ON Sprint with you Hboot and have gain Unlocked with Teminal Emulator or more good with Deodex Sense based Rom and Apk unlocker, (most complicate of to be S-OFF), try and see if are able to gain you Unlock Sprint M7 BR allumts |
06-07-2015, 08:13 | #3 (permalink) |
Member: 946381 Status: Offline Thanks Meter: 150 | final step error as below C:\>cd android C:\android>adbshell 'adbshell' is not recognized as an internal or external command, operable program or batch file. C:\android>adb shell shell@m7wls:/ $ su su root@m7wls:/ # C:\android>adb shell * daemon not running. starting it now * * daemon started successfully * shell@m7wls:/ $ su su root@m7wls:/ # am start com.redbend.vdmc/com.htc.omadm.test.TestMainActivity am start com.redbend.vdmc/com.htc.omadm.test.TestMainActivity Starting: Intent { act=android.intent.action.MAIN cat=[android.intent.category.L AUNCHER] cmp=com.redbend.vdmc/com.htc.omadm.test.TestMainActivity } Error type 3 Error: Activity class {com.redbend.vdmc/com.htc.omadm.test.TestMainActivity} doe s not exist. root@m7wls:/ # why above error help me |
06-07-2015, 08:23 | #4 (permalink) |
No Life Poster Join Date: Oct 2010 Location: India Age: 31
Member: 1713856 Status: Offline Sonork: Uninstalled Thanks Meter: 4,500 | the error above is about apk is not replaced or maybe you not set permission ? if you done everything correctly better downgrade it to 1.54.651.X and do it again. |
06-07-2015, 13:59 | #5 (permalink) | |
Member: 946381 Status: Offline Thanks Meter: 150 | Quote:
C:\>cd android C:\android>adb shell error: device not found C:\android>adb shell error: device not found C:\android>adb shell error: device not found C:\android>adb shell error: device not found C:\android>adb shell * daemon not running. starting it now * * daemon started successfully * shell@m7wls:/ $ su su root@m7wls:/ # am start com.redbend.vdmc/com.htc.omadm.test.TestMainActivity am start com.redbend.vdmc/com.htc.omadm.test.TestMainActivity Starting: Intent { act=android.intent.action.MAIN cat=[android.intent.category.L AUNCHER] cmp=com.redbend.vdmc/com.htc.omadm.test.TestMainActivity } root@m7wls:/ # help me to downgrade hboot. first time go to do hboot downgrade-help | |
06-08-2015, 05:23 | #6 (permalink) | |
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 56
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | Quote:
06-08-2015, 08:56 | #7 (permalink) |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | @Zone3, read here: http://forum.gsmhosting.com/vbb/10884422-post26.html and install Apk., (if you are in Original Sense Rom) or .Zip, (if you are in DEODEX ROM), and since you are just S-OFF downgrade this install 4.3 Sense then after phone is unlocked you can upgrade with any other more high SENSE ROM, if you install one NO-SENSE or SENSE BASED ROM you turn back to lost you unlock...it's all BR allumts |
