Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > HTC > HTC Android based
HTC Android based General HTC Android phones discussion, firmwares, solution, root, help
Old 05-30-2015, 16:47   #1 (permalink)
Member: 946381
Thanks Meter: 150
help me to unlock htc one m7 sprint locked
details of my phone as below
C:\android>fastboot getvar all
INFOversion: 0.5
INFOversion-bootloader: 1.57.0000
INFOversion-baseband: 2.03.30.0428
INFOversion-cpld: None
INFOversion-microp: None
INFOversion-main: 5.03.651.3
INFOversion-misc: PVT SHIP S-OFF
INFOserialno: FA36SS906985
INFOimei: 990001469451041
INFOmeid: 99000146945104
INFOproduct: m7_wls
INFOplatform: HBOOT-8064
INFOmodelid: PN0720000
INFOcidnum: 11111111
INFObattery-status: good
INFObattery-voltage: 3855mV
INFOpartition-layout: Generic
INFOsecurity: off
INFObuild-mode: SHIP
INFOboot-mode: FASTBOOT
INFOcommitno-bootloader: dirty-1f512bb6
INFOhbootpreupdate: 11
INFOgencheckpt: 0
all: Done!
finished. total time: 0.078s
i saw one method to unlock in below link
http://forum.gsmhosting.com/vbb/f842...-done-1928786/
on FOR DEODEXED ROMS
1. first unlock bootloader reach on google
2. ROOTED with kimgo or vroot or another tool
3. Use the modified HtcOMADM_SPCS [MOD] SIM UNLOCK for 4.3 | Sprint HTC One | XDA Forums flash in recovery
4. Download
Android Terminal Emulator 1.0.65Android Terminal Emulator (Android) - Télécharger
. Type "su" (excluding quotation marks) and grant it superuser permission
Type "am start com.redbend.vdmc/com.htc.omadm.test.TestMainActivity" (excluding quotation marks)
You will get menu on your HTC
In that menu, select "API", then scroll down 'till almost end and select "simlock"
Reboot the phone and hopefully it would accept GSM SIM
Enter *#*#4636#*#* in your dialer
In the phone information section(the first one) set preferred network type to something that is GSM specific: "WCDMA Preferred", for example. The phone will switch to GSM mode
can i unlock as in above procedure
help me-i saw some guys have problems in above procedure
help me
Old 05-30-2015, 19:30   #2 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 12,343
Read all this my procedure here:
http://forum.gsmhosting.com/vbb/f842...off-s-1908356/
S-OFF today can get only with "SunShine.Apk" , (payment option), or by Java Card.
But i've tested also with S-ON Sprint with you Hboot and have gain Unlocked with Teminal Emulator or more good with Deodex Sense based Rom and Apk unlocker, (most complicate of to be S-OFF), try and see if are able to gain you Unlock Sprint M7
allumts
Old 06-07-2015, 08:13   #3 (permalink)
Member: 946381
Thanks Meter: 150
final step error as below
C:\>cd android
C:\android>adbshell
'adbshell' is not recognized as an internal or external command,
operable program or batch file.
C:\android>adb shell
shell@m7wls:/ $ su
su
root@m7wls:/ #
* daemon not running. starting it now *
* daemon started successfully *
shell@m7wls:/ $ su
su
root@m7wls:/ # am start com.redbend.vdmc/com.htc.omadm.test.TestMainActivity
Starting: Intent { act=android.intent.action.MAIN cat=[android.intent.category.L
AUNCHER] cmp=com.redbend.vdmc/com.htc.omadm.test.TestMainActivity }
Error type 3
Error: Activity class {com.redbend.vdmc/com.htc.omadm.test.TestMainActivity} doe
s not exist.
root@m7wls:/ #
why above error
help me
Old 06-07-2015, 08:23   #4 (permalink)
Rahul_Bhutani's Avatar
Member: 1713856
Sonork: Uninstalled
Thanks Meter: 4,500
the error above is about apk is not replaced or maybe you not set permission ?
if you done everything correctly better downgrade it to 1.54.651.X and do it again.
Old 06-07-2015, 13:59   #5 (permalink)
Member: 946381
Thanks Meter: 150
that error solved-now last step simlock option not open is my problem-i think it due to not downgrade hboot -logs as below
C:\>cd android
error: device not found
shell@m7wls:/ $ su
su
root@m7wls:/ #
help me to downgrade hboot.
first time go to do hboot downgrade-help
Old 06-08-2015, 05:23   #6 (permalink)
Member: 4627
Sonork: 57528:debeliamark
Thanks Meter: 1,034
C:\>cd android
shell@m7wls:/ $ su
su
root@m7wls:/ #
Flash first HtcOMADM_SPCS.zip as is writen here to be possible to execute terminal commands ...
Old 06-08-2015, 08:56   #7 (permalink)
allumts's Avatar
Member: 1564612
@Zone3,
read here:
http://forum.gsmhosting.com/vbb/10884422-post26.html
and install Apk., (if you are in Original Sense Rom) or .Zip, (if you are in DEODEX ROM), and since you are just S-OFF downgrade this install 4.3 Sense then after phone is unlocked you can upgrade with any other more high SENSE ROM, if you install one NO-SENSE or SENSE BASED ROM you turn back to lost you unlock...it's all
allumts
Page generated in 0.17714 seconds with 8 queries
