Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > HTC > HTC Android based
HTC Android based General HTC Android phones discussion, firmwares, solution, root, help
Old 06-23-2015, 13:11   #76 (permalink)
sm-shahzada's Avatar
Member: 2130293
Sonork: 100.1637594
Thanks Meter: 68
Unhappy
i download 2 files but when i unzip file give error
crc fials what problem i also use 7zip and winrar
how can solve this problem ??
Old 06-23-2015, 14:07   #77 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,373
I checked vit 7zip its extracted vit out any issues try n othr pc
The Following User Says Thank You to jamesjerss For This Useful Post:
Old 06-23-2015, 14:27   #78 (permalink)
Member: 59030
Thanks Meter: 165
Originally Posted by matador5550 View Post
hi how should i flash this rom? my device is desire 820s
i hold volume + and connect the usb cable but pc not recognize my device
If it's an MTK flash chip phone and using SP Flashtool to flash, copy firmware files to where the SP Flashtool file is and select scatter loading file. I was told to select Download Only from the drop down tab. Press Download button..With turn-off phone plug in USB. It should start flashing.
Old 06-23-2015, 14:35   #79 (permalink)
Member: 59030
Thanks Meter: 165
Originally Posted by jamesjerss View Post
You made a mistake not flash file prob do not selct download +frmat Only use download option. Read ful flash frm othr device nd flash if basedband cme normal repair imei den
Sent from my XT1068 using Tapatalk
I tried to find full backup flash file for this model but couldn't find it. Does anyone have this file?
Old 06-24-2015, 09:27   #80 (permalink)
Member: 59030
Thanks Meter: 165
Hi jamesjerss..I still need help with the HTC D816h v 1.13.709.001 that now has no baseband and no imei after flashing. I'm desperate because I've been trying to fix it for 2 months now and after finding your post, I've hoped that you can help. Thanks
Old 06-24-2015, 11:28   #81 (permalink)
Member: 59030
Thanks Meter: 165
Edit: I finally managed to find the same working phone now. Can you please tell me how to read full flash? what address should I choose to get full flash?
Old 06-24-2015, 14:15   #82 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,373
Use droid tools or try vit supported professional tools
The Following 2 Users Say Thank You to jamesjerss For This Useful Post:
Old 06-28-2015, 07:33   #83 (permalink)
sunilkumar70791's Avatar
Member: 1432329
Sonork: 100.1615863
Thanks Meter: 1,626
HI,
@jamesjerss
PLESE UPLOAD HTC -D310W INDIAN VER FILE
Last edited by ..::Nokian CareŽ::..; 06-29-2015 at 21:35. Reason: Contact info removed
The Following User Says Thank You to sunilkumar70791 For This Useful Post:
Old 06-29-2015, 17:39   #84 (permalink)
Member: 2418768
jamesjerss, how can I backup my current SYSTEM ROM on HTC Desire 820s with a 64bit CPU MTK 6752? MTK droid tools fails to even get the scatter files.
Old 06-30-2015, 07:34   #85 (permalink)
Member: 1837438
Sonork: unknown
Thanks Meter: 659
Originally Posted by raja.m View Post
hi bro
htc desire 310 d310h Single SIM 4GB flash file need it
thanks in advance
You Can Download Desire 310 Rom From Here
br,
Habeeb Kambrath
Old 06-30-2015, 08:34   #86 (permalink)
ReyTech's Avatar
Member: 135945
Thanks Meter: 85
You may need asian region firmware or read ful backup frm other device nd flash
hi! can u sare the tutorial how to do that! whats the full length address and how to make scatter file etc!
WVR
REytech.
Old 06-30-2015, 09:56   #87 (permalink)
Member: 1837438
Sonork: unknown
Thanks Meter: 659
WVR
REytech.
If You Have Working Handset;
Insert A Blank MMC&restart Into Recovery Mode then Select "Backup&Restore"
Not To Make Scatter File From This Method
Br,
Habeeb Kambrath
Old 07-01-2015, 14:55   #88 (permalink)
saifjaan009's Avatar
Member: 2340225
Sonork: 100.1662389
Thanks Meter: 367
Arrow HTC DESIRE 620G Install Arabi
Htc desire 620G Arabi Install Very Easy Just Root On IRoot and install Region Changer on PlayStore
Best Regards
Saif Ur Rahman
The Following 4 Users Say Thank You to saifjaan009 For This Useful Post:
Old 07-02-2015, 13:55   #89 (permalink)
Member: 210589
Sonork: 100.1624235
Thanks Meter: 21
Htc desire 526+ dual sim mtk 65xx file required my problem is hang on htc logo
Old 07-02-2015, 15:37   #90 (permalink)
Member: 962829
Thanks Meter: 51
bro how to get download mode on HTC_D820TS
Page generated in 0.25263 seconds with 10 queries
