Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > HTC > HTC Android based
HTC Android based General HTC Android phones discussion, firmwares, solution, root, help
Old 06-08-2015, 20:54   #61 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,373
Originally Posted by missed.call View Post
any solution for this problem pleas
Post yur device detail nd prob detail
Old 06-09-2015, 16:26   #62 (permalink)
Member: 2342793
Sonork: geratkhmer
Hi mr jam .which we can check type cpu ?
Old 06-10-2015, 09:12   #63 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,373
read info using any supported htc tools or google it yur device specification
Sent from my XT1068 using Tapatalk
Old 06-11-2015, 18:39   #64 (permalink)
Member: 2403445
Fixed
Originally Posted by jamesjerss View Post
Your device dual sim or single? post model id yu can find it frm yur back pannel
modelid should b lik tis 0PLxxx
Sorry, i see ur answer now, i fix the bootloop, but using the stock image for my model from IR-File and the SP Flash Tool in this xda thread
(Ups, i cant post link, :-D)
The model is 0PF1100 (that is the US Version, just 512/4G), i have the 1.02.661.2 version, but in my country i cant download and OTA (here the internet access by phone is forbidden, just wired connections and behind a proxy), if u have one, let me know
Old 06-17-2015, 08:39   #65 (permalink)
Member: 2411227
Need htc 526g+ dual sim 16gb frim ware
Old 06-19-2015, 16:45   #66 (permalink)
Member: 2144251
Thanks Meter: 4
After flash d516h .. Unfortunately app error occur .. while opening browser.. google apps.... any solution pls
Sent from my irisX8 using Tapatalk
Old 06-19-2015, 18:01   #67 (permalink)
saifjaan009's Avatar
Member: 2340225
Sonork: 100.1662389
Thanks Meter: 367
Full Hard reset and after see
The Following User Says Thank You to saifjaan009 For This Useful Post:
Old 06-21-2015, 15:15   #68 (permalink)
ali_imran's Avatar
Member: 481609
Sonork: 100.1659889
Thanks Meter: 367
Unhappy
try this file frm ir-key
HTC_616_D616h_0.80.708.001_SW_G98518A2_V003_M10_HT C_V3DUG_ASIA_MP_T03.zip
or try custom rom there patched boot.img also available
i try to both file but sill reboot set
Old 06-22-2015, 20:14   #69 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,373
Other file uploaded check tat file nd post result
Old 06-23-2015, 10:42   #70 (permalink)
Member: 59030
Thanks Meter: 165
I used this flashtool to flash an HTC D816h that has front camera problem. After flashing the camera works again but now phone has no baseband and no imei. Can anyone tell me how to fix this problem? Thanks
Old 06-23-2015, 10:52   #71 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,373
You may need asian region firmware or read ful backup frm other device nd flash
The Following User Says Thank You to jamesjerss For This Useful Post:
Old 06-23-2015, 11:03   #72 (permalink)
Member: 59030
Thanks Meter: 165
Thanks for the quick reply..The firmware in the phone is 1.13.709.001. I found the same firmware on the net and can flash but if I tried different firmware, it won't allow to flash. Maybe I didn't select the proper file to flash. I select download+format, is that correct way? Do you have detail method how to flash it properly?
The Following User Says Thank You to citifone For This Useful Post:
Old 06-23-2015, 11:23   #73 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,373
You made a mistake not flash file prob do not selct download +frmat Only use download option. Read ful flash frm othr device nd flash if basedband cme normal repair imei den
Old 06-23-2015, 11:49   #74 (permalink)
Member: 2414762
Thanks Meter: 47
hi how should i flash this rom? my device is desire 820s
i hold volume + and connect the usb cable but pc not recognize my device
Old 06-23-2015, 12:11   #75 (permalink)
Member: 1314938
Sonork: 100.1672340
Thanks Meter: 5,373
Run flash tool
Load scatter file
Press download
power off yur device
Connter usb
if mob not detected check drivers
The Following 3 Users Say Thank You to jamesjerss For This Useful Post:
Page generated in 0.24878 seconds with 10 queries
