HTC Android based General HTC Android phones discussion, firmwares, solution, root, help |
08-14-2014, 11:58 | #1 (permalink) |
Freak Poster Join Date: Apr 2008 Location: gsmworld
Member: 757297 Status: Offline Thanks Meter: 36 | htc one mini stuck on htc logo after update with custum help plz Last edited by lifegood8; 08-14-2014 at 12:02. Reason: miss sum line |
08-14-2014, 13:10 | #2 (permalink) |
No Life Poster Join Date: May 2010 Location: India,Tamilnadu-Nagercoil Age: 37
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | Post Details & cid version Htc Driver must b installed Install this driver adb&fastboot Download put yur mobile n fastboot mode cnnt to the pc Run cmd commnd type below given commnd press enter copy the details post here fastboot getvar all |
08-14-2014, 14:55 | #3 (permalink) |
Member: 757297 Status: Offline Thanks Meter: 36 | C:\Fastboot>fastboot getvar all INFOversion: 0.5 INFOversion-bootloader: 2.22.0000 INFOversion-baseband: 1.28.40e.00.24 INFOversion-cpld: None INFOversion-microp: None INFOversion-main: 4.09.707.3 INFOversion-misc: PVT SHIP S-ON INFOserialno: INFOimei: INFOmeid: INFOproduct: m4_u INFOplatform: HBOOT-8930 INFOmodelid: PO5810000 INFOcidnum: HTC__044 INFObattery-status: good INFObattery-voltage: 4313mV INFOpartition-layout: Generic INFOsecurity: on INFObuild-mode: SHIP INFOboot-mode: FASTBOOT INFOcommitno-bootloader: dirty-0e1af350 |
08-14-2014, 16:11 | #4 (permalink) |
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | 1. Unlock Bootloader Tutorial here scroll down nd read 2. Recover : TWRP 2.7.0.5 3. ROM :m4kk_4.4.2_3.10.401.4_root-odex.zip 4. USB Stick 5. USB OTG Instruction 1. Unlock device with Unlock Bootloader Unlock Bootloader 2. Download ROM and Copy to Flash Drive Rom download here http://mega.co.nz/#!5dV1nYKK!fXLZAtrOkvAC4OECqze9r1fLD3pnqi5Jw8n6eoQ mXo4"][COLOR="Yellow"]M4_4.4.2_3.10.401.4_Odex.zip 3.Flash recovery TWRP 2.7.0.5 Download TWRP 2.7.0.5 Update 29/04/2014 Push your device to recovery mode by Hold " power + Volume Down" select fastboot mode run cmd command from where saved the file (shift + right click to launch command) fastboot flash recovery TWRP 2.7.0.5.img Go to recovery mode in your device , then plug in USB Flash drive with USB OTC and connect to your device Select Advance >> Mount USB OTG , select Install located to ROM in Flash drive Then just flash ROM m4kk_4.4.2_3.10.401.4_root-odex.zip Wait for moment until Successfully[/LIST] Done and reboot your device !!!!!! Source:xda OTG USB Last edited by jamesjerss; 08-14-2014 at 22:08. |
The Following User Says Thank You to jamesjerss For This Useful Post: |
08-14-2014, 16:40 | #5 (permalink) |
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | other link Download here M4_4.4.2_3.10.401.4_Odex.zip Last edited by jamesjerss; 08-14-2014 at 22:06. |
