HTC Android based General HTC Android phones discussion, firmwares, solution, root, help |
08-10-2014, 22:46 | #1 (permalink) |
No Life Poster Join Date: May 2010 Location: India,Tamilnadu-Nagercoil Age: 37
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | All about HTC Gold card maker+Root Tutorial+Official rom flashing+ important notes Goldcard making tutorial * Download & install adb fastbood driver Here(no need to Download crap android SDK) * If you install this Driver yu can launch adb command from anywhere * Download this simplegoldcard maker * Take a memory card nd format usng FAT32. * Enable usb debugging n yur mobile * Connect it to the pc * Run the SimpleGoldCard * Now do like **** given n the pictures * Click here to download yur goldcard image fileclick me * after got goldcard img follw the picture below * Put yur gold card memmory to yur mobile * Download nd flash any official RUU on yur mobile vit out errors. procedure 2 get cid using command * Enable usb debugging * connect it to yur pc * Run cmd the type[ adb devices ] press enter * if yur mob is cnnted correctly yu sud see lik below given n the picture * Then type [adb shell] press enter * Type [cat /sys/class/mmc_host/mmc1/mmc1:*/cid ] press enter (low end mobiles must hav memory card inserted) above doest work tye this [ cat /sys/class/mmc_host/mmc0/mmc0:*/cid ] press enter picture below * After get the CID go to this site to generate yur gold card image filePress me * Note this is not reversed CID its Normal Cid so enter the CID into normal CID box picture below * after generate the goldcard img use simple goldcard maker tool to create gold card folow above procedure I made this Thread more easier for newbies Njoy Rooting + Bootloader unlocking &Custom recovery * Make sure your phone is at least 60% charged. * Register for an account at HTCdev. * Enable USB debugging in your phone's Developer options. * Un-check "Fast boot" on your phone by going to Settings -> Battery Manager. * Install ADB and Fastboot on your computer. Download here * Make sure to back up all of your app data using either ADB or HTC Sync, because you will be wiping your phone. * Install the HTC One M8 drivers on your computer (if you have HTC Sync installed, then you already have them). 1st Unlock Your Bootloader Step 1: Enter Fastboot Mode Place your device into fastboot mode by plugging in your HTC One to your computer, then powering it down by holding both the Power and Volume Down buttons until you see the screen below. Step 2: Run cmd command there enter below given command nd press enter Code: fastboot oem get_identifier_token Step 3: Copy the Token Now copy the code you get, but do not include the first (bootloader) portions.To copy the token right click on it select mark den press ctrl+v n yur keyboard to copy the token. [IMG]http://3.bp.********.com/-p0H7eeeWTU4/UN3iKiq5XtI/AAAAAAAAAEs/LLnyw9FxDqs/s1600/fastboot.bmp[/IMG] Step 4: Log into HTCdev Go to HTCdev and log in to your account. Step 5: Get Your Code Emailed to You Select Unlock Bootloader and then Get Started. From the drop-down menu, select HTC One (M8) (or just HTC One for the older M7 model, if that's what you're unlocking), then click on Begin Unlock Bootloader. Agree to the terms and conditions and click Proceed to Unlock. On the next page, scroll all the way down and click on Proceed to Step 5. Now paste the identifier token you copied in Step 3 into its corresponding box near the bottom (called My Device Identifier Token) and click Submit. Step 6: Download the Unlock Code The Unlock Code will be emailed to you, so once you receive the email, download the attachment and place it on your Desktop. Step 7: open command window from where yu saved the file image below [IMG]http://2.bp.********.com/-eiI8JPnsAvc/UCtCVlXvEoI/AAAAAAAABi8/i3AL5EJwVEo/s1600/Open+Command+Window+here.jpg[/IMG] Step 8: Enter the command below given nd press enter Code: fastboot flash unlocktoken Unlock_code.bin Step 8: Confirm on Your HTC One Your phone will now prompt you to unlock your bootloader, so using the Volume Up button, select Yes and confirm your unlock with the Power button. Your phone will now reboot and your bootloader will be unlocked! After the reboot, you will need to set up your device again as if it were new. After getting set up, make sure to re-enable USB debugging and plug it back into your computer.Un-check "Fast boot" on your phone by going to Settings -> Battery Manager. Now flash custom recovery to yur mobile. if yu hav international or other carrier mobile search latest TWRP or CMW recovery img file for yur mobile nd save to the desktop.nd rename the file as recovery Put yur mobile into fastboot mode by pressing Power and Volume Down buttons den power button to select fastboot mode.connect to the pc shift+right click to launch the command window there give the below given command nd press enter Code: fastboot flash recovery recovery.img Reboot yur device Download super su from here nd place to yur phone memory put yur mobile into recovery flash supersu.zip yu re done rooting. Last edited by jamesjerss; 11-28-2014 at 00:03. |
The Following 5 Users Say Thank You to jamesjerss For This Useful Post: |
08-10-2014, 22:51 | #2 (permalink) |
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | Imp Notes : * if yu are unlocked yur bootloader yu can not flash yur mobile using official ROMS. * To update vit official Rom yu hav to relock yur bootloader nd update yu mobile relock command below do it on fastboot mode Code: fastboot oem lock * If yu have unlocked rooted nd custom recovery installed in yur mobile yu can flash custom roms nd other rom zip files using it. * To update original Rom after relocked in fastboot mode check yur cid use **** command Code: fastboot getvar cid * Yur cid must b lik this example: cid: HTC__044 * if get the cid yu can search correct rom for yur model vit this cid for examble se picr below. official roms vist here * if yu unable to find the correct rom for ur cid yu can upadte yur mob by 2 methods 1st is goldcard method 2nd s-off yur mob nd update vit any rom. * Gold card method 1st post * For s-off method yu hav to unlock yur bootloader nd root yur mobile den search for s-off locking tool for yur hboot version.once if yu s-off yur mobile yu can flash any official rom but before update yu hav to agin relock the bootloader. * CID change benefits if yur on s-off change yur cid as super cid Normal cid HTC__044 super cid 111111 yu can edit cid by some tools yu can search it for yu model via google. * Once yu get the super cid yu can flash any rom any time but yu can not downgrade if yu need to downgrade yu hav to s-off yur mob.one more thing wen yur mob on s-off yu can oly flash other official rom once aftr update yur s-off become s-ON. if yu hav change yur cid to super cid no need to wrry about it. Easy Way to find yur Correct firmware for yur model * put yur mob into fastboot mode nd cnnt it to the pc * Run cmd command type fastboot getvar all nd press enter * After get full details about yur mobile follw the below givn image Code: All cid codes Cid id and oparetors all htc SuperCID 11111111 AirTel-India ???????? Asia-HK-CHT HTC__622 ATT CWS__001 BM BM___001 Bouygues-Telecom BOUYG201 Brightstar-PTB BSTAR502 Brightstar-SPA BSTAR301 Chunghwa-Taiwan CHT__601 CT HTCCN702 CU HTCCN703 DCM DOCOM801 DOPOD DOPOD701 Era T-MOB009 Fastweb-IT FASTW401 GOOGLE GOOGL001 H3G-DAN H3G__F05 H3G-Italy H3G__402 H3G-ROI H3G__003 H3G-SWE H3G__G04 H3G-UK H3G__001 HTC-Asia-SEA HTC__037 HTC-Asia-SEA-WWE HTC__044 HTC-Australia HTC__023 HTC-BE HTC__E41 HTC-Czech HTC__C24 HTC-Denmark HTC__F08 HTC-Dutch HTC__E11 HTC-EastEurope HTC__032 HTC-ELL HTC__N34 HTC-FRA HTC__203 HTC-FRA-Bouygues HTC__247 HTC-GCC HTC__J15 HTC-GER HTC__102 HTC-India HTC__038 HTC-ITA HTC__405 HTC-Nor HTC__Y13 HTC-Norway HTC__H10 HTC-Poland HTC__B25 HTC-PTG HTC__506 HTC-Russia HTC__A07 HTC-Singapore ???????? HTC-SPA HTC__304 HTC-Sweden HTC__G09 HTC-Turkey HTC__M27 HTC-WWE HTC__001 Hutch-Australia HUTCH001 O2-DE O2___102 O2-UK O2___001 Open-Channel HTCCN701 Optus-Australia OPTUS001 ORANGE-AT ORANG113 ORANGE-BE ORANG012 ORANGE-CH-FRA ORANG203 ORANGE-CH-GER ORANG104 ORANGE-ES ORANG309 ORANGE-French ORANG202 ORANGE-PL ORANGB10 ORANGE-PO ORANG008 ORANGE-SK ORANG006 ORANGE-UK ORANG001 Rogers ROGER001 SMC-Voda-HK SMCVD001 StarHub-Singapore ???????? TELEF-Spain TELEF301 Telstra TELST001 TELUS TELUS001 TIM-Italy TIM__401 TMA T-MOB102 TMCZ T-MOB004 TMD T-MOB101 TMH T-MOB007 TMHR T-MOB006 TMMK T-MOBL11 TMNL T-MOB003 TMSK T-MOB008 TMUK T-MOB005 TMUS T-MOB010 TWM-TW HTC__621 VIRGIN-UK VIRGI001 VODA-Africa-South HTC__016 VODA-Australia VODAP021 VODA-Germany VODAP102 VODA-Greece VODAP006 VODA-Ireland VODAP019 VODA-Italy VODAP405 VODA-Mobilkom VODAP120 VODA-Netherland VODAPE17 VODA-New-Zealand VODAP022 VODA-Portugal VODAPD18 VODA-Proximus VODAP024 VODA-SA VODAP026 VODA-SFR VODAP203 VODA-Spain VODAP304 VODA-Swisscom-DE VODAP110 VODA-Swisscom-FR VODAP212 VODA-Swisscom-IT VODAP416 VODA-Swisscom-WWE VODAP015 VODA-TR VODAPM27 VODA-UK VODAP001 |
The Following 2 Users Say Thank You to jamesjerss For This Useful Post: |
08-10-2014, 22:58 | #3 (permalink) |
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | IF yu are unable to find right RUU for yur HTC follow this procedure to flash yur mob Run the RUU executable as you normally would, but don't proceed to the second step i.e. when a second window appears, do nothing. Do not proceed, just ignore it for now, but don't close the window.
The Following 8 Users Say Thank You to jamesjerss For This Useful Post: |
12-29-2014, 18:51 | #4 (permalink) |
Junior Member Join Date: Dec 2014
Member: 2319179 Status: Offline Sonork: [email protected] Thanks Meter: 0 | I have a htc m7wls device there it stnke ROMs you formate but stopped work please help |
01-09-2015, 00:38 | #5 (permalink) |
Freak Poster Join Date: Nov 2005
Member: 195855 Status: Offline Thanks Meter: 26 | Adding your CID to the PGIMG.zipThis is only required if the RUU you have is not for your CID and you don't have SuperCID. Check your cid by referring to 2.1 in this guide. Double click the PG58IMG.zip file to open it. Double click android-info.txt to open in notepad. Add your CID to the end of the file uising the ones already in there as an example. Make sure there are no spaces in or after your CID Press Ctrl +S and then close the window. You will now see a pop up window. Click yes to modify the archive. U mean to say that just edit cid for example if it htc_044 then i delete 44 n in the place of 44 i add my cid 38 FOR Example org txt: modelid: PB9920000 cidnum: HTC__044 mainver: 2.13.707.1 hbootpreupdate:3 DelCache: 1 AFTER EDIT TXT :modelid: PB9920000 cidnum: HTC__038 mainver: 2.13.707.1 hbootpreupdate:3 DelCache: 1 i m bit confused here so plz help me to correct it if i m wrong.Then i can flash cid 044 rom on cid 038 after edit it ???..........thanks Last edited by seny85; 01-09-2015 at 00:46. |
01-14-2015, 07:57 | #6 (permalink) |
No Life Poster Join Date: Aug 2007 Location: on forum
Member: 566122 Status: Offline Thanks Meter: 322 | i got htc holiday for S.off,,,but phone is just going on RECOVERY H BOOT and FASTBOOT only ,,,,how can i make gold card on this situation ? because all of tutorial shows must need USB DEBUGGING ,,,,and set must ON on normal window ,,, if have any solution ,,,plz must inform me ,,, |
