Go Back   GSM-Forum > Non GSM/Mobile Related Forums > Game Consoles & Mp3/4 , HD players
Game Consoles & Mp3/4 , HD players Repairing and servicing Mp4, Mp3 devices, HD players.. you may also find here any threads related to Game Consoles devices like Wii, PlayStation, Xbox, Nintendo .. etc
Old 06-17-2008, 10:34   #1 (permalink)
Mohsin-*'s Avatar
Member: 417298
Sonork: 100.1578269
Thanks Meter: 18,268
How to: Update the firmware for your MP3/MP4 player
Here is Step by Step Process for Updating Fw for ur mp3/mp4 players etc
Now days Alot of them Present in market..With Different Fw inside....This is the basic manual for upgrading FW...
WARNING:
Always BACKUP the existing firmware of your player before attempting to update the firmware on your player.
Updating your player with the wrong or incorrect firmware will result in a DEAD PLAYER and it not booting up
at all! Always be sure that you use the correct firmware for your player only.Install first MP3_Player_Utilities_4.10
( kadalasan kasama sa Mp3/Mp4 pag binili )
or get it here: http://rapidshare.com/files/43393187..._4.10.rar.html
UseUSB Cable ( kasama din sa package )
1.Now click on [Start] --> [Programs] --> [MP3 Player Utilities 3.68]
(or whatever version you have installed) --> "MP3 Player Upgrade Tool"
2.Click on the "Select new firmware file" button.
3.Choose your new firmware file (.bin or .fw) and click on the [Open] button.
4.Now click on the "Begin upgrading" button.
5.You will now see a progress bar and a message saying "Writing the firmware data to the device".
6.During updating, your computer will look like it's 'hung' for a few seconds, don't worry,
just let it do it's thing and wait for the "Upgrade is success" message like the one below.
ps..This is not mine work....All credit to Orignal Poster (found by Google)
The Following 6 Users Say Thank You to Mohsin-* For This Useful Post:
Old 06-17-2008, 10:35   #2 (permalink)
Mohsin-*'s Avatar
Member: 417298
Sonork: 100.1578269
Mp3 Mp4 players FW here
Full Version 3.5.37 firmware for 1.5 LCD
http://rapidshare.com/files/47060457...5_LCD.rar.html
3.5.37 Chines Mp3 like nano
http://rapidshare.com/files/47060168..._nano.rar.html
Firmware-E60_n2_v3.2-1G_FM (9.0.43 FULL)
http://rapidshare.com/files/47061636...FULL_.rar.html
Full Firmware version 3.2.13
http://rapidshare.com/files/47061241....2.13.rar.html
Full Version 3.5.37 firmware for 1.8 LCD
http://rapidshare.com/files/47060820...ut_FM.rar.html
Firmware-T21 v3.3-1G+FM (9.0.43 Full)
http://rapidshare.com/files/47061859...Full_.rar.html
Full Merged 3.5.37 ( Upgrade from 3.535 to 3.5.37 )
http://rapidshare.com/files/47062246....37__.rar.html
T29_3.5.37
http://rapidshare.com/files/47063479....5.37.rar.html
Full Version 9.0.43 for 1.8 LCD CTW500
http://rapidshare.com/files/47064084...TW500.rar.html
The Following 2 Users Say Thank You to Mohsin-* For This Useful Post:
Old 06-17-2008, 10:36   #3 (permalink)
Mohsin-*'s Avatar
Member: 417298
Sonork: 100.1578269
Basic guide for Recovery of mp3/mp4
Here is a Basic guide for Recovery of mp3/mp4 player Might be Helpfull courtesy of s1mp3 orgnization thankx to them
So these r the steps to be Made in recovery
1. Identify the player : Discover you board ID
2. Dissassemble the s1mp3
3. Install drivers and make windows detect the player
4. Install a compatible upgrade program
5. Put device on recovery mode (short-circuit)
6. Find the apropriate firmware for your mp3 player
7. Help! I still can't recover my player!
If you killed your player, you'll need a firmware that works with your player's hardware. To know with Firmware file will work on your player, you must get the board ID. It's the only safe way to identify your player. Chip numbers, external look, models or brand names can't unequely identify a hardware set.
To get the board ID, you must disassemble your player. If you don't know how to disassemble your mp3 player, read on.
Find a clear table / desk to work on, make sure the floor is not to messy. It'll be a LOT easier to find back those tiny little screws / plastic buttons that tend to fall out exactly the wrong way
Stick a screwdriver/knife/needle between the USB plug and the bottom plastic part (the one that holds the battery) . Any gap large enough to fit a sharp edge in will do.
Lever the bottom plastic of the rest of the player. It's not welded or glued tight, so it'll come of easily. Be forceful, but gentle, if necessary. Don't worry if you hear plastic "snapping" it's just the clips coming loose, you are not breaking anything.
In the four corners of the PCB (the printboard with all the chips) you'll find four screws, find a screwdriver that fits, and unscrew them. Put the screws in a container! Anything will do, from an egg holder to tupperware to an ashtray, just don't loose the screws!! You can now lift off the main PCB. Be carefull, as the LCD connector cable (brown flat cable) is quite fragile. Don't break it!
You can now safely remove the chrome/silver/shiny ring from the player. Note how it fits under the main PCB, and how the LCD connector cable goes through it. This bit is a bit tricky to reassemble later, so if you remember how everything was in the first place, It'll be easier to put it back together.
You can now see the back of the LCD board. there should be two screws in it. Again, take your screwdriver and unscrew them. Put these screws in a (different) container! Again, Don't lose the screws! You need them. Put them in a different container to make sure you don't mix them up with the four "main PCB screws", as that will cause trouble when you put the player back together. After all that, you can take the LCD board from the front of the case. Remember, the brown LCD connector cable is fragile, don't break it!
Congratulations, you have now disassembled your S1MP3 player! To reassemble it, just follow this guide in reverse order. Extra attention to see if the buttons are well fit on the case, for not to force then while closing the case.
First, uninstall the "mp3 player tools" you have installed previously. Install the 1.46 version available at the Tools.
Unplug the player and remove/uninstall all the drivers related to USB at the device manager. (Control Panel > System > Hardware tab > Device Manager). Here is a screenshot.
Now, click "scan for hardware changes" button. Finally after the USB drivers are installed, plug in your player.
If you have problems with drivers, they may be obtained at the place you've installed the MP3 player utilities(Program Files/MP3 Player Utilities/) At folders "Windows98Drv", and "Dissipate/drivers".
If you follow all this steps and windows still can't recognize it, you may try to push ALL the buttons while connecting it to the USB hub. Try every button, and keep the button hold. You may also try to plug it on another computer. Also, make sure driver signing is not set to "block"(screenshot).
If nothing works, don't get desperate, you can still try to short-circuit the memory chip to make it run the "recovery mode"(ADFU server).
Skip this step if the updater program is working correctly on your machine.
Firstly, make sure you have done the previous steps, and disable any anti virus/anti spywares.
Try to plug your device with and without the batteries, and see if holding the buttons solves the update program start errors.
If you are still getting errors like "UNKNOW FLASH TYPE", "FLASH NOT RESPONDING", "DEVICE NOT DETECTED", "DEVICE IS BUSY", etc, you should uninstall you current updater program and try other versions.
If you still can't make it work, you can try to short-circuit the memory chip to make it run the "recovery mode"(ADFU server).
Why/how does it work : On boot time, the BREC (bootloader, written on ATJ2085) checks if the FWIMAGE (with is on the NAND flash) is damaged. If it is, it enters on the recovery mode (ADFU SERVER). If you get a dead device, the invalid/incompatible FWIMAGE present at the NAND flash could not be detected as corrupt or incompatible, because all of it headers are valid. To make the ATJ2085 run the recovery mode, (so we can override the broken FWIMAGE and write code) we short-circuit the memory chip during startup to simulate a broken fwimage header. Off course, if you have a device with the damaged BREC code, there is no way for us to write code on the device, so it's really gone to heaven ... [IMG]http://www.************.com/forum/images/smilies/smile.gif[/IMG]
Recognize the memory chip, near the ATJ2085 chip. It's usually a samsung chip, and it's the biggest silicon on the board.We have seen players with 2 memory chips, too. If you have one of those, you have to short the memory chip nearest to the ATJ2085.
Now, without the batteries, with a flat screwdriver, touch 2 or more of any of the 8 IO legs of the memory chip. Then, KEEP the screwdriver shorting the pins, and connect the player to the USB.
Keep trying this procedure until you are successful. You may need to do this procedure lots of time before getting a successful short. When you are successful, windows will recognize your s1mp3 as an ADFU server device (you may check it on the system tray) and then, when you start the firmware update program, you'll be warned that the device is on recovery mode, and you will finally be allowed to flash a (FULL) compatible firmware file. If you try to flash a dump, you will get an error message.
If your device is not detected AT ALL, even doing this procedure, you got a permanently damanged S1mp3, probably because a corrupt firmware flash operation. The only hope is a hardware flash via ICE, see the ICE howto wiki article.
Now, let windows install the drivers. After this, you may flash any firmware to the player, after finding a compatible update program.
If you are on recovery (ADFU) mode, and the firmware for your board haven't worked, or if you are trying to flash a dump(incomplete firmware), one thing you might do is to flash another (random) firmware, until you get a working usb flash disk. Then, flash your player in the normal way, with your incomplete firmware(without doing any short-circuit). Incomplete DUMPS won't work on ADFU mode, remember that!
If you don't find your board there, them you will have to find it yourself, by attempt and error. We unhappily CAN'T help you hunting. (Google can.)
Note that this procedure is the same for ATJ2085, AMP2085 and ATJ2051 chips.
If you are getting a persistent error like "UNKNOW FLASH TYPE" after trying everything suggested here, it's likely that there is a bad solder on your memory chip or the memory chip itself is phisically dammanged. You might try to resolder it.
The most important is to keep hope, LOTS of people already recovered their players!
Old 06-17-2008, 13:06   #4 (permalink)
Easy Unlockers's Avatar
Member: 450337
Thanks Meter: 247
thank u ..,,,,,,,,,,,,,,,,,,
Old 06-17-2008, 17:29   #5 (permalink)
bogg7's Avatar
Member: 198113
Sonork: 100.161124
Thanks Meter: 95
can you upload again because the link not work
Old 06-18-2008, 10:14   #6 (permalink)
Mohsin-*'s Avatar
Member: 417298
Sonork: 100.1578269
check again link work fine
Old 06-18-2008, 12:23   #7 (permalink)
Mohsin-*'s Avatar
Member: 417298
Sonork: 100.1578269
here is new link
http://rapidshare.com/files/12330084..._4.10.rar.html
The Following User Says Thank You to Mohsin-* For This Useful Post:
Old 10-13-2008, 10:26   #8 (permalink)
Member: 867425
Thanks Meter: 5
mp4 blue lite no pc contact
Old 10-15-2008, 04:51   #9 (permalink)
sonumobilewala's Avatar
Member: 296651
Sonork: 100.1581376
Thanks Meter: 386
WARNING:
(or whatever version you have installed) --> "MP3 Player Upgrade Tool".
link not working plz give me other link
Old 10-15-2008, 06:45   #10 (permalink)
khansb's Avatar
Member: 89773
Thanks Meter: 4
T29_3.5.37
ALL Links Not Working
Old 10-15-2008, 08:30   #11 (permalink)
guru4gsm's Avatar
Member: 517316
Thanks Meter: 185
Bro goto http://mympxplayer.org/ and get All info about your Chinese Players..........
Br.
Old 06-03-2009, 18:51   #12 (permalink)
Member: 417682
Thanks Meter: 16
Sir i need usb cable driver for mp3/4player device plz help me
Old 06-03-2009, 19:09   #13 (permalink)
Member: 417682
Thanks Meter: 16
need help plz,
i have Digital Mp3 player but stil (starting)only if i connect Device with PC via USB cable
Device is showing, windows demade frist instal usb Drive but sir i dont have usb driver i dont no witch usb driver support this device plz help me
Old 01-21-2010, 06:27   #14 (permalink)
Member: 770229
Sonork: 29050
Thanks Meter: 101
thankx u advance for this
Old 03-29-2010, 10:50   #15 (permalink)
Member: 1272631
Smile
Maybe your motherboard is broken, you will have a try at other computer.
If you can not solve, you will take a message.
[ MP3 & Mp4 ] - How to: Update the firmware Amir-SkillZ Game Consoles & Mp3/4 , HD players 165 12-07-2015 09:37
Update the firmware for your MP3/MP4 player.and problam solved 1 day gopalhot Game Consoles & Mp3/4 , HD players 7 05-16-2013 12:14
How to update the firmware masterbox v.122 Gabiunlock Mastertools 8 03-16-2010 14:11
Update the firmware for your MP3/MP4 player.and problam solved 1 day gopalhot Chinese Models & Cloned Phones 12 06-10-2008 02:46
Page generated in 0.29194 seconds with 9 queries
