Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > MRT - Mobile repair tool
Old 02-14-2019, 11:22   #1 (permalink)
equinoks's Avatar
Member: 21508
Thanks Meter: 186
flashing meizu M710H.. Trying Connect to Service verification data... Fail
i got this error while trying flash Meizu M5c (M710H):
Disconnect Mobile...
Re-Put the Mobile Bettery...
Then Connect your Phone to Computer again....
Please Make sure Mobile better has Power...
>>> Searching Mobile Port...
Get Mobile Port is: COM49
>>> Device driver identification:
MediaTek USB Port
>>> Mobile Has Connect...
CPU_NAME: MT6735
>>> Reading Mobile Hardware Info...Success
HW_Inf: 8A00 SW_Inf: CB00
>>> Initialization Mobile ...
>>> Sending Auth File To Mobile...Success
Fail
I tried select Metal (cdma) but same thing.. any trick?
The Following User Says Thank You to equinoks For This Useful Post:
Old 02-14-2019, 14:52   #2 (permalink)
.::ARD::.'s Avatar
Member: 1705891
Sonork: 100.1604564
Thanks Meter: 8,139
Try repeat operation without press any key
The Following User Says Thank You to .::ARD::. For This Useful Post:
Old 02-14-2019, 16:56   #3 (permalink)
equinoks's Avatar
Member: 21508
Thanks Meter: 186
I tried without pressing any key but didn't work.. by the way the phone id dead. maybe server issue??
Old 02-15-2019, 04:55   #4 (permalink)
Member: 2697457
Thanks Meter: 14
search google, you can find some guide can flash M5c with SP flashtool, I tried and all OK
The Following User Says Thank You to p4ndahp3 For This Useful Post:
Old 02-15-2019, 05:00   #5 (permalink)
.::ARD::.'s Avatar
Member: 1705891
Sonork: 100.1604564
Thanks Meter: 8,139
Try this file
https://mega.nz/#F!4OoDEDBZ!RuQPBiJA...y7F_w!cLZ0iajS
Old 02-15-2019, 12:31   #6 (permalink)
equinoks's Avatar
Member: 21508
Thanks Meter: 186
Thank you but this is the file i'm using already to flash..
@p4ndahp3
I tried with some flashtools but got error, can you share the one you used please ?
thank you!
Old 02-15-2019, 12:33   #7 (permalink)
.::ARD::.'s Avatar
Member: 1705891
Sonork: 100.1604564
Thanks Meter: 8,139
Post mrt screenshot if u don't mind
Old 02-15-2019, 12:33   #8 (permalink)
Member: 2556882
Thanks Meter: 24
its a mtk6755 cpu bro not mtk6737
The Following User Says Thank You to ikhan89 For This Useful Post:
Old 02-15-2019, 13:51   #9 (permalink)
equinoks's Avatar
Member: 21508
Thanks Meter: 186
Here is screenshot
@ikhan89
there's version with MT6737M
when i read with CM2 i got these infos:
Wait for phone...
Phone found! [ 6 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6737
BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00
BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x07000000
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
BootLdrSS : LOCKED with SLA
Processing DA stage
Sending and initialize DA ...
[DA_ERROR] : DONE
Boot Error!
thank you!
Old 02-15-2019, 14:37   #10 (permalink)
.::ARD::.'s Avatar
Member: 1705891
Sonork: 100.1604564
Thanks Meter: 8,139
Select metal ( cdma )
Old 02-15-2019, 15:15   #11 (permalink)
equinoks's Avatar
Member: 21508
Thanks Meter: 186
i selected but exactly same error
Page generated in 0.19223 seconds with 9 queries
