Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > MRT - Mobile repair tool
Old 01-14-2019, 05:10   #1 (permalink)
Member: 451521
Thanks Meter: 317
TestPoint_OPPPO F7 NEW Security_VEr26 MRT team
File Type: jpg 50434664_600110393764333_3998761522061901824_n.jpg (140.4 KB, 2561 views)
The Following 14 Users Say Thank You to Tom_ptm For This Useful Post:
Old 01-14-2019, 06:37   #2 (permalink)
Member: 2818707
Thanks Meter: 48
its good thanks but while format read mobile map data FAIL
The Following User Says Thank You to ravisah1983 For This Useful Post:
Old 01-14-2019, 07:00   #3 (permalink)
.::ARD::.'s Avatar
Member: 1705891
Sonork: 100.1604564
Thanks Meter: 8,139
If you failed mean your wrong in handling
Old 01-16-2019, 11:25   #4 (permalink)
C-Mobile's Avatar
Member: 64496
Thanks Meter: 76
Hi i have different board
Need testpoint for unlock
Phone name cph1819
Sent from my iPhone using Tapatalk
Old 02-01-2019, 05:43   #5 (permalink)
Member: 144565
Thanks Meter: 71
oppo f7 new board new testpoint
oppo f7 new board new testpoint A.26 version
tested 101%
The Following 7 Users Say Thank You to gioguanez For This Useful Post:
Old 02-13-2019, 14:45   #6 (permalink)
Member: 2647406
Thanks Meter: 52
connect to ground while running software?
Old 02-14-2019, 10:13   #7 (permalink)
Member: 1908176
question in procedure in testpoint must be connected the battery before insert the usb data cable? in vivo the battery must not connected before insert the usb data cable. oppo also same procedure?
Old 02-17-2019, 01:53   #8 (permalink)
Member: 2894924
Thanks Meter: 2
Oppo and Vivo are the same. No need to connect batteries to be processed. Because it uses USB as a voltage source.
Old 02-17-2019, 04:51   #9 (permalink)
Member: 1529452
Sonork: 100.1637909
Thanks Meter: 47
Disconnect Mobile...
Re-Put the Mobile Bettery...
Then Connect your Phone to Computer again....
Please Make sure Mobile better has Power...
>>> Searching Mobile Port...
Get Mobile Port is: COM17
>>> Device driver identification:
MediaTek USB Port
>>> Mobile Has Connect...
CPU_NAME: MT6771
>>> Reading Mobile Hardware Info...Success
HW_Inf: 8A00 SW_Inf: CA00
>>> Initialization Mobile ...>>> Sending Auth File To Mobile...Success
>>> Downloading Boot1 To Mobile Phone...Success
Mobile phone status:SYNC...
Mobile phone status swtich to :brom...Success
Make sure Mobile status has in :brom...
Init Mobile BOOT2 ...
=====================Flash Type(eMMC)==============
Flash Size: 0x0000000D0A303030 -> 53411M
Flash ID: 0x2031303035203030
Flash Name: UNKNOWN
Flash symbol: 05 000
>>> Reading Mobile Map Data...Fail
Old 02-17-2019, 04:55   #10 (permalink)
Member: 1529452
Sonork: 100.1637909
Thanks Meter: 47
MediaTek USB Port
CPU_NAME: MT6771
Flash Name: UNKNOWN
Same problem
Old 03-22-2019, 20:09   #11 (permalink)
sbata-team's Avatar
Member: 909860
Sonork: +212600693045
Thanks Meter: 120
hi ia have same prob any bady have a good solution plz share it thanks
Get Mobile Port is: COM43
MediaTek USB Port_V1632
CPU_NAME: MT6771
Flash Name: UNKNOWN
Old 03-23-2019, 07:23   #12 (permalink)
.::ARD::.'s Avatar
Member: 1705891
Sonork: 100.1604564
Thanks Meter: 8,139
When connected with pc , you need fast to disconnect the test point
The Following 4 Users Say Thank You to .::ARD::. For This Useful Post:
Old 03-23-2019, 08:20   #13 (permalink)
DYNET's Avatar
Member: 320363
Sonork: 100.1578853
Thanks Meter: 3,938
CPU_NAME: MT6771
Flash Name: UNKNOWN
it's seems your hold gnd to test point or some time your pc not able to change vcome port change pc
The Following User Says Thank You to DYNET For This Useful Post:
Old 03-23-2019, 09:27   #14 (permalink)
Member: 2747393
Thanks Meter: 7
Try Boot 1
Thats Will be Mak Nyoooz....
Old 03-27-2019, 07:05   #15 (permalink)
sigma xi's Avatar
Member: 773960
Thanks Meter: 529
ive done the testpoint in resistor.. failed at the end of mrt now phone doesnt turn on... tsk.... but still detecting
The Following User Says Thank You to sigma xi For This Useful Post:
Page generated in 0.28572 seconds with 9 queries
