12-19-2017, 06:15 | #724 (permalink) |
No Life Poster Join Date: May 2009 Location: pattaya
Member: 1043111 Status: Offline Sonork: 1000.2 Thanks Meter: 385 | VIVO V5 done. Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM481 >>> Device driver identification: MediaTek USB Port >>> Mobile Has Connect... CPU_NAME: MT6755 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CB00 >>> Initialization Mobile ...>>> Sending Auth File To Mobile...Success >>> Downloading Boot1 To Mobile Phone...Success Mobile phone status:SYNC... Mobile phone status swtich to :brom...Success Success Make sure Mobile status has in :brom... Init Mobile BOOT2 ... =====================Flash Type(eMMC)============== Flash Size: 0x0000000747C00000 -> 29820M Flash ID: 0x150100525831424D Flash Name: Samsung_Unknow Flash symbol: RX1BMB >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM122 >>> Device driver identification: MediaTek DA USB VCOM (Android) >>> Reading Mobile Map Data...Success >>>>Formating Mobile USER Data... ADD(HEX):0x00F9800000 Size(HEX):0x064D3FBE00 Corresponding operation completed!!! |
The Following User Says Thank You to wsmobile For This Useful Post: |
12-21-2017, 16:51 | #725 (permalink) |
Freak Poster Join Date: Mar 2004 Location: kocaeli Age: 46
Member: 58232 Status: Offline Thanks Meter: 91 | ale-l21 repair https://imgur.com/Z3mhpC8 no root one click >>>>Searching mobile phones... Get Hisi cpu Mobile Phones... >>> Get Mobile Port: COM168 >>>>Device identification : Android Adapter PCUI >>>>Switch Mobile to Auth Mode PCB SN: 7N3MVK173xxxxxx Mobile SN: W3D7N174xxxxx Mobile Code: ORT >>>>Switch Mobile mode... IMEI1: 353134013xxxx >>>>Write IMEI1...Success >>>>Write IMEI2...Success Read information timeout.... All is done |
The Following User Says Thank You to muzi_31 For This Useful Post: |
12-24-2017, 04:01 | #726 (permalink) |
Junior Member Join Date: Sep 2017
Member: 2761982 Status: Offline Thanks Meter: 10 | MEIZU M3S UNLOCK PASSWOD Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM26 >>> Device driver identification: MTK USB Port >>> Mobile Has Connect... CPU_NAME: MT6755 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CB00 >>> Initialization Mobile ... >>> Sending Auth File To Mobile...Success >>>>Trying Connect to Service verification data... Success >>> Downloading Boot1 To Mobile Phone...Success Mobile phone status:SYNC... Mobile phone status swtich to :brom...Success Success Make sure Mobile status has in :brom... Init Mobile BOOT2 ... =====================Flash Type(eMMC)============== Flash Size: 0x0000000390000000 -> 14592M Flash ID: 0x7001004548414345 Flash Name: Kingston_Unknow Flash symbol: EHACEA >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM25 >>> Device driver identification: MediaTek DA USB VCOM Port >>> Reading Mobile Map Data...Success >>>>Formating Mobile USER Data... ADD(HEX):0x00EA800000 Size(HEX):0x02A47FBE00 Corresponding operation completed!!! After Finish;Disconnect usb cable,keep hold the power key 10s more,mobile will reboot!!! |
12-24-2017, 06:29 | #727 (permalink) |
Member: 2761982 Status: Offline Thanks Meter: 10 | VIVO Y55L PASSWORD UNLOCK, DONE >>>Try connect to mobile...Success CPU_SN: 0xF0F8B0DF MSM_ID: 0x0004F0E1 >>>Try connect to mobile...Success >>>init mobile...Success >>>Downloading boot...Success >>>Switch mobile to RE\WR ...Success Flasy type: eMMC >>>>正在读取手机分区数据...Success Clear Moblile Lock data... After Click Mobile userdata will be lost... Format add: ADD:0x010AA82000 Size:0x0299379E00 Erase Userdata.. Success Erase Userdata Block 2... Erase Userdata.. Success Erase Userdata Block 3... Erase Userdata.. Success Erase Userdata Block 4... Erase Userdata.. Success >>>all is done ******************************** Please disconnect mobile set,and hold vol up and power key Mobile will be into recovery Click Restart ******************************** if mobile hand on logo or auto restart... You can in recovery erase data After ease data in recovery mobile will working normal |
12-24-2017, 10:58 | #728 (permalink) |
Freak Poster Join Date: Nov 2015 Location: INDIA
Member: 2482400 Status: Offline Sonork: 100.1677259 Thanks Meter: 115 | lenovo a7020a48 imei repair successfully Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM71COM71 >>> Device driver identification: MediaTek PreLoader USB VCOM (Android) Set Port To COM71Success Into Meta Mode...Success Switch Moile to Repair IMEI Port... >>> Searching Mobile Port... Get Mobile Port is: COM98COM98 >>> Device driver identification: Android Gadget VCOM Driver >>> Into META Repair IMEI Mode...Success reading the relevant parameters of the phone information... CPU_TYPE:mt6755,S01 Bulid_Time:Thu Jul 21 10:48:05 CST 2016 Base_Ver:alps-mp-m0.mp7-V2.3_lenovo6755.66c.m_P67 Soft_Ver:A7020a48_S259_160721_ROW Software Has be change to IMEI algorithm 2... Reading Mobile Hardware Info... Original_IMEI 1: New_IMEI 1: 86814302288**** Original_IMEI 2: New_IMEI 2: 86814302288**** Corresponding operation completed!!!:rolleye s: |
The Following User Says Thank You to lastmile For This Useful Post: |
12-25-2017, 20:53 | #731 (permalink) |
Freak Poster Join Date: May 2013 Location: india punjab
Member: 1930279 Status: Offline Sonork: 100.1663273 Thanks Meter: 113 | oppo f3 pattern remove done. full log. Disconnect Mobile... Re-Put the Mobile Bettery... Then Connect your Phone to Computer again.... Please Make sure Mobile better has Power... >>> Searching Mobile Port... Get Mobile Port is: COM11 >>> Mobile Has Connect... CPU_NAME: MT6755 >>> Reading Mobile Hardware Info...Success HW_Inf: 8A00 SW_Inf: CB00 >>> Initialization Mobile ...>>> Sending Auth File To Mobile...Success >>> Downloading Boot1 To Mobile Phone...Success Mobile phone status:SYNC... Mobile phone status swtich to :brom...Success Success Make sure Mobile status has in :brom... Init Mobile BOOT2 ... =====================Flash Type(eMMC)============== Flash Size: 0x0000000E8F800000 -> 59640M Flash ID: 0x150100524836344D Flash Name: Samsung_Unknow Flash symbol: RH64MB >>> Swich Mobile to Hight Speed Re\Wr Port... Get Mobile Port is: COM12 >>> Device driver identification: MediaTek DA USB VCOM (Android) >>> Reading Mobile Map Data...Success >>>>Formating Mobile USER Data... ADD(HEX):0x0137000000 Size(HEX):0x0D577FBE00 Corresponding operation completed!!! |
The Following User Says Thank You to manpreetmani For This Useful Post: |
12-27-2017, 09:03 | #735 (permalink) |
Junior Member Join Date: Jan 2016 Location: JP
Member: 2511587 Status: Offline Sonork: NONE Thanks Meter: 10 | OPPO F5 FRP RESET DONE Last edited by master41; 12-27-2017 at 09:08. Reason: no image |
The Following User Says Thank You to master41 For This Useful Post: |
