Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > BB5KING
Old 12-16-2008, 18:07   #16 (permalink)
muhned's Avatar
Member: 201469
Sonork: software
not found slove it
tthe phone nokia 5300 , 5200 was work fine , imei ok , work with all sim card , charging ok
but i trying unlock by jaf p-key bb5 king
i asked jaf team why
jaf p-key unlock w/o very very very very very bad
i trying backup rpl , full earse , full flash high - low ver , restore backup rpl , pm ok
but same problem the two phone 5200, 5300 automatically off after 10-15mins - and now when put it charger write me
( the charger not support )
bb5 king killer me two nokia 5300 , 5200
i asked user gsm to help me , no asked jaf p-key ( failure )
Old 12-16-2008, 21:45   #17 (permalink)
Member: 220143
Originally Posted by muhned View Post
not found slove it
I am awaiting solution too my brother
Old 12-18-2008, 20:04   #18 (permalink)
Member: 227454
hi guys i had this problem with n95 phone off after 10 to 15 minutes & it will not come on until u take the battery out and put it back again, if this is happenning with your phones then the solution is to reflow the rapido or rap ic and uem if still the problem still presist then write a good full pm using sx4 through jaf server. bcs charging values and power values are in the pm. post result to help others.
Old 12-20-2008, 06:01   #19 (permalink)
asif_ae's Avatar
Member: 334999
brother i have same problem with 6630 imei is ok but after unlock about 5 minutes phone turn to off i flash the latest version but problem is still , plz give any solution
Old 12-20-2008, 10:21   #20 (permalink)
muhned's Avatar
Member: 201469
Sonork: software
where is raskal & cinek ?
not found slove
Old 12-21-2008, 02:05   #21 (permalink)
Member: 79715
you got config key 00000000000. try to sx4 authorize and write full pm. problem solves, tested
Old 12-21-2008, 15:00   #22 (permalink)
Member: 780644
Sonork: 100.88888
not found slove
Cinek run away to Poland with 200.000 euro.
Raskal is in HK and working in his master plan for try kill my business.
And your problem can not be solved by BB5KING software.
It is stated from beginning that only Repair SimLock zone.
Your phones do not have this problem, they have IMEI problem.
BR,
Manole
The Following User Says Thank You to MANOLE For This Useful Post:
Old 12-23-2008, 20:05   #23 (permalink)
foo_men's Avatar
Member: 296918
get them
BR,
Manole
JAJAJAJAJAJAJAJAJA Call the luftwaffe to get Cienk.......call the red army to apress raskal.i have the same problem with a 5300 and 7373 i fixed with repair sl zone but it turns off. imei is ok. I will flash and post results.B.R.
Old 12-23-2008, 21:35   #24 (permalink)
Member: 156434
hardware problem reball power ic or replace
Old 12-25-2008, 15:10   #25 (permalink)
hackgsm's Avatar
Member: 64014
Sonork: 100.1603152
have IMEI problem................
Old 12-25-2008, 15:29   #26 (permalink)
zohaib555's Avatar
Member: 491151
Sonork: 1601375
i think your phone is imei patched you check you imei 35644014664644? if imei last ? then your phone is blocked and imei patched
Old 12-27-2008, 21:09   #27 (permalink)
foo_men's Avatar
Member: 296918
5300 turn off
Realy?? I flashed a 7373, 5300 after repair sl zone turn off, imei is ok, but doesn´r resolves whit flash, i write pm, too, so nop nop nop, doesnt resolve.
Old 12-27-2008, 23:20   #28 (permalink)
Nurettin Duman's Avatar
Member: 115596
BR,
Manole
Thanks for your Cinek Poland with 200.000 euro.
Old 02-07-2009, 14:23   #29 (permalink)
Member: 277710
i have same probem,my phone power off after 30 min.(3500 & 6300)
Old 02-19-2009, 09:58   #30 (permalink)
a7mad01's Avatar
Member: 178689
you need RPL FILE THEN FULL PM W.T 308 USING SX4
TESTED BY ME 101%
B.R
Ahmad
6500c turns off after 15 min XpErTsGsM MXKEY Nokia Flasher and Unlocker (by Alim Hape) 2 03-04-2010 16:38
6300 superdongle key invalid phone goes off after 15 min. mobilezone1997 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 3 11-25-2009 05:30
5310 Problem Switch off after 15 mins xahin Nokia Base Band 5 ( BB-5 ) 4 11-18-2009 06:38
5310 Problem Switch off after 15 mins xahin MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 11-16-2009 12:15
Nokia 6300 switchess off afetr 15 mins??? jdwe Nokia Hardware & Hardware-Repair Area 7 06-26-2009 21:38
Page generated in 0.40566 seconds with 11 queries
