04-27-2011, 11:38 | #1 (permalink) |
No Life Poster Join Date: Dec 2001 Location: Prussia
Member: 7844 Status: Offline Thanks Meter: 182 | 5070 (6070) sim lock failed is it caz sim lock is FFFFF ? i tried to unlock but i didnt manage . any help ? Code: [325,1] Reading 15 bytes PM Read OK, Time taken 45.281s Starting PP array read... PP Read OK, Time taken 0.875s MCU Version V 04.23 MCU Date 26-10-07 Product RM-166 (Nokia 5070/6070/6080 CABLE 3220) Manufacturer (c) Nokia. IMEI 3* Mastercode 5562263314 Proceeding with RSA Unlock... Setting Local Mode... Local mode Set Asic 2 HW Signature C5E2E56F6AD0F676 Simlock Server SIMLOCK SERVER VERSION 58 Simlock Key FFFFFFFFFFFFFFFF Simlock Profile 0000000000000000 Simlock Aux 00025555 Simlock IMEI 00553576900104866800 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 00101F Asking card to sign HW Signature... Signed OK (9F1E8A152A64E64E79A47710D2E918C4DE38B07D) Calculating SP... Writing SP... Failed to Unlock DCT4 Plus -> Possible cause: Other error (0x00) |
05-01-2011, 21:32 | #2 (permalink) |
Member: 7844 Status: Offline Thanks Meter: 182 | flashed but still remained locked ! Code: Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v01.58, (Mar 28 2011 11:13:30, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2011 wk9 Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number: C0003E14 HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk32 / 2010, wk01 Initializing security card... Card Serial Number: DD0001DE Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 5.00v PASSED MCU Voltage 3.31v PASSED Core Voltage 1.79v PASSED VBAT Voltage 0.66v PASSED VBAT Voltage 5.02v PASSED Box VPP disabled VPP Voltage 0.04v PASSED Internal Box VPP Enabled VPP Voltage 4.92v PASSED Box VPP disabled VPP Voltage 0.00v PASSED External Box VPP Enabled VPP Voltage 0.04v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work Scanning avaiable products... Processing C:\Program Files\Nokia\Phoenix\Products\... Processing C:\Program Files\Common Files\Nokia\DataPackage\Products\... Found 0 products, Filtering DCT4 Products - wait... Failed to retrieve DCT4 Products -> List index out of bounds (0) Processing pre-flash tasks... Pre-flash tasks finished Booting UPP... UPP ID: 3160 [HW_UNKNOWN] rm166__04.230, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM Flashbus Write baud set to 100Kbits u_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 Box VPP disabled Internal Phone VPP Selected PLL Factor: 3 FlashChip[0]: 0x00208804 @ 0x01000000, ST, SectorSize: 128kB, Ext: 00007221 Signature: AD7EB61A1BBE0BE27D586BE4DBEE6514 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 51Kbits u_intel.fia, Type: Algorithm, Target: FlashChip[0] 0x00208804 (128Mbits), Rev: 7.4.80.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.02V MSID-Crypted: 84FBA56120968B1D252D0672BD MSID-Plain: 8A0CBAE90044B28EA9000000 FAID-Crypted: 52A2E80FC6FE02F3E084D3C0 Flashbus Write baud set to 6.50Mbits 3 Region(s) to erase Erasing NOR Region [0x01000000-0x0101FFFF] Erasing NOR Region [0x01020000-0x018DFFFF] Erasing NOR Region [0x01E60000-0x01FDFFFF] Erase taken 84.609s Writing 559 blocks... All blocks written OK! Time taken 49.281s Terminating flash session Box VPP disabled Booting UPP... UPP ID: 3160 [HW_UNKNOWN] rm166__04.23.image_x, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM Flashbus Write baud set to 100Kbits u_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 Box VPP disabled Internal Phone VPP Selected PLL Factor: 3 FlashChip[0]: 0x00208804 @ 0x01000000, ST, SectorSize: 128kB, Ext: 00007221 Signature: AD7EB61A1BBE0BE27D586BE4DBEE6514 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 51Kbits u_intel.fia, Type: Algorithm, Target: FlashChip[0] 0x00208804 (128Mbits), Rev: 7.4.80.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.00V MSID-Crypted: 845FB00DF3D75A726ABDE6687A MSID-Plain: 1C15BAE30044B28EAD0005BD FAID-Crypted: EABEB471B2A031D73D9F8FD9 Flashbus Write baud set to 6.50Mbits 1 Region(s) to erase Erasing NOR Region [0x01B20000-0x01E5FFFF] Erase taken 26.578s File Sector Size: 64kB, Flash Chip Sector Size: 128kB Converting CNT... Checking image... Unpacking image... Image Unpacked OK, Base Address = 0x1B20000, Chunk Size = 0x4000, Convertion 64kB -> 128kB Unformatting Image... Writing 0 blocks... All blocks written OK! Time taken 0.31s Terminating flash session Extracting Content Package... CP Server: (c) Nokia File Server Content Package Extracted OK Box VPP disabled Booting UPP... UPP ID: 3160 [HW_UNKNOWN] rm166__04.23x, Type: Flash Image, Algo: DCT4, DCT4 ALGORITHM Flashbus Write baud set to 100Kbits u_2nd.fia, Type: 2nd Boot Loader, Rev: 7.4.79.0, Algo: DCT4 Box VPP disabled Internal Phone VPP Selected PLL Factor: 3 FlashChip[0]: 0x00208804 @ 0x01000000, ST, SectorSize: 128kB, Ext: 00007221 Signature: AD7EB61A1BBE0BE27D586BE4DBEE6514 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 51Kbits u_intel.fia, Type: Algorithm, Target: FlashChip[0] 0x00208804 (128Mbits), Rev: 7.4.80.0, Algo: DCT4 ALGORITHM Nominal VPP Voltage: 9V, Detected: 0.04V MSID-Crypted: 843E3007215A33D6D584138F3D MSID-Plain: 3E4EBAE90044B28EA8000000 FAID-Crypted: 1AA2503B2CB8E137D92916F9 Flashbus Write baud set to 3.25Mbits 1 Region(s) to erase Erasing NOR Region [0x018E0000-0x01B1FFFF] Erase taken 18.516s Writing 134 blocks... All blocks written OK! Time taken 12.375s Terminating flash session Box VPP disabled Processing post-flash tasks... Setting Factory Defaults... Factory defaults OK Post-flash tasks finished... Flash successfully finished! |
05-01-2011, 21:46 | #3 (permalink) |
Member: 7844 Status: Offline Thanks Meter: 182 | wrote PM but still same error Code: [1,0] Written, Length: 114 bytes, Status: OK [1,1] Written, Length: 11 bytes, Status: OK [1,2] Written, Length: 86 bytes, Status: OK [1,4] Written, Length: 110 bytes, Status: OK [1,5] Written, Length: 2 bytes, Status: OK [1,6] Written, Length: 86 bytes, Status: OK [1,8] Written, Length: 110 bytes, Status: OK [1,11] Written, Length: 8 bytes, Status: OK [1,12] Written, Length: 2 bytes, Status: OK [1,13] Written, Length: 86 bytes, Status: OK [1,15] Written, Length: 2 bytes, Status: OK [1,16] Written, Length: 86 bytes, Status: OK [1,18] Written, Length: 86 bytes, Status: OK [1,20] Written, Length: 86 bytes, Status: OK [2,0] Written, Length: 356 bytes, Status: OK [4,0] Written, Length: 1 bytes, Status: OK [4,1] Written, Length: 24 bytes, Status: OK [4,2] Written, Length: 44 bytes, Status: OK [4,3] Written, Length: 10 bytes, Status: OK [4,4] Written, Length: 8 bytes, Status: OK [4,5] Written, Length: 8 bytes, Status: OK [4,6] Written, Length: 8 bytes, Status: OK [4,8] Written, Length: 8 bytes, Status: OK [4,9] Written, Length: 5 bytes, Status: OK [4,12] Written, Length: 50 bytes, Status: OK [4,13] Written, Length: 1 bytes, Status: OK [4,16] Written, Length: 4 bytes, Status: OK [4,18] Written, Length: 60 bytes, Status: OK [4,19] Written, Length: 4 bytes, Status: OK [7,0] Written, Length: 4 bytes, Status: OK [7,1] Written, Length: 40 bytes, Status: OK [7,2] Written, Length: 2 bytes, Status: OK [8,0] Written, Length: 12 bytes, Status: OK [8,1] Written, Length: 12 bytes, Status: OK [8,2] Written, Length: 0 bytes, Status: OK [8,3] Written, Length: 0 bytes, Status: OK [8,7] Written, Length: 8 bytes, Status: OK [11,0] Written, Length: 4 bytes, Status: OK [11,1] Written, Length: 4 bytes, Status: OK [11,2] Written, Length: 4 bytes, Status: OK [11,3] Written, Length: 4 bytes, Status: OK [11,4] Written, Length: 1 bytes, Status: OK [11,5] Written, Length: 6 bytes, Status: OK [11,6] Written, Length: 2 bytes, Status: OK [11,7] Written, Length: 1 bytes, Status: OK [11,8] Written, Length: 1 bytes, Status: OK [11,9] Written, Length: 1 bytes, Status: OK [11,10] Written, Length: 2 bytes, Status: OK [11,11] Written, Length: 2 bytes, Status: OK [11,12] Written, Length: 2 bytes, Status: OK [11,13] Written, Length: 16 bytes, Status: OK [11,14] Written, Length: 2 bytes, Status: OK [11,15] Written, Length: 2 bytes, Status: OK [11,16] Written, Length: 2 bytes, Status: OK [11,17] Written, Length: 2 bytes, Status: OK [11,18] Written, Length: 2 bytes, Status: OK [11,19] Written, Length: 2 bytes, Status: OK [11,20] Written, Length: 2 bytes, Status: OK [11,21] Written, Length: 2 bytes, Status: OK [11,22] Written, Length: 2 bytes, Status: OK [11,23] Written, Length: 2 bytes, Status: OK [11,24] Written, Length: 2 bytes, Status: OK [11,25] Written, Length: 2 bytes, Status: OK [11,26] Written, Length: 2 bytes, Status: OK [11,27] Written, Length: 2 bytes, Status: OK [11,28] Written, Length: 2 bytes, Status: OK [11,29] Written, Length: 2 bytes, Status: OK [11,30] Written, Length: 2 bytes, Status: OK [11,31] Written, Length: 2 bytes, Status: OK [11,32] Written, Length: 2 bytes, Status: OK [11,33] Written, Length: 2 bytes, Status: OK [11,34] Written, Length: 2 bytes, Status: OK [11,35] Written, Length: 2 bytes, Status: OK [11,36] Written, Length: 2 bytes, Status: OK [11,37] Written, Length: 2 bytes, Status: OK [11,38] Written, Length: 2 bytes, Status: OK [11,39] Written, Length: 2 bytes, Status: OK [11,40] Written, Length: 2 bytes, Status: OK [11,41] Written, Length: 2 bytes, Status: OK [11,42] Written, Length: 2 bytes, Status: OK [11,43] Written, Length: 2 bytes, Status: OK [11,44] Written, Length: 2 bytes, Status: OK [11,45] Written, Length: 2 bytes, Status: OK [11,46] Written, Length: 2 bytes, Status: OK [11,47] Written, Length: 2 bytes, Status: OK [11,48] Written, Length: 2 bytes, Status: OK [11,49] Written, Length: 2 bytes, Status: OK [11,50] Written, Length: 2 bytes, Status: OK [11,51] Written, Length: 2 bytes, Status: OK [11,52] Written, Length: 2 bytes, Status: OK [11,53] Written, Length: 2 bytes, Status: OK [11,54] Written, Length: 2 bytes, Status: OK [11,55] Written, Length: 4 bytes, Status: OK [11,56] Written, Length: 1 bytes, Status: OK [11,57] Written, Length: 4 bytes, Status: OK [11,58] Written, Length: 4 bytes, Status: OK [11,59] Written, Length: 4 bytes, Status: OK [11,60] Written, Length: 4 bytes, Status: OK [11,61] Written, Length: 16 bytes, Status: OK [11,62] Written, Length: 4 bytes, Status: OK [11,63] Written, Length: 2 bytes, Status: OK [11,64] Written, Length: 4 bytes, Status: OK [12,0] Written, Length: 102 bytes, Status: OK [13,0] Written, Length: 1 bytes, Status: OK [13,1] Written, Length: 2 bytes, Status: OK [13,2] Written, Length: 1 bytes, Status: OK [13,3] Written, Length: 2 bytes, Status: OK [13,4] Written, Length: 1 bytes, Status: OK [13,5] Written, Length: 1 bytes, Status: OK [13,6] Written, Length: 1 bytes, Status: OK [13,7] Written, Length: 1 bytes, Status: OK [13,8] Written, Length: 2 bytes, Status: OK [13,9] Written, Length: 1 bytes, Status: OK [13,10] Written, Length: 1 bytes, Status: OK [13,11] Written, Length: 48 bytes, Status: OK [13,12] Written, Length: 4 bytes, Status: OK [13,13] Written, Length: 1 bytes, Status: OK [13,14] Written, Length: 1 bytes, Status: OK [13,15] Written, Length: 886 bytes, Status: OK [13,16] Written, Length: 2 bytes, Status: OK [13,17] Written, Length: 1 bytes, Status: OK [13,18] Written, Length: 1 bytes, Status: OK [13,19] Written, Length: 8 bytes, Status: OK [13,20] Written, Length: 1 bytes, Status: OK [13,21] Written, Length: 1 bytes, Status: OK [13,22] Written, Length: 1 bytes, Status: OK [13,23] Written, Length: 1 bytes, Status: OK [13,24] Written, Length: 1 bytes, Status: OK [13,25] Written, Length: 2 bytes, Status: OK [13,26] Written, Length: 1 bytes, Status: OK [13,27] Written, Length: 1 bytes, Status: OK [13,28] Written, Length: 1 bytes, Status: OK [13,29] Written, Length: 1 bytes, Status: OK [13,30] Written, Length: 1 bytes, Status: OK [13,31] Written, Length: 1 bytes, Status: OK [13,32] Written, Length: 1 bytes, Status: OK [13,33] Written, Length: 1 bytes, Status: OK [13,34] Written, Length: 1 bytes, Status: OK [13,35] Written, Length: 1 bytes, Status: OK [13,36] Written, Length: 1 bytes, Status: OK [13,37] Written, Length: 4 bytes, Status: OK [13,38] Written, Length: 1 bytes, Status: OK [13,39] Written, Length: 1 bytes, Status: OK [13,40] Written, Length: 1 bytes, Status: OK [13,41] Written, Length: 1 bytes, Status: OK [13,42] Written, Length: 4 bytes, Status: OK [13,43] Written, Length: 4 bytes, Status: OK [13,44] Written, Length: 1 bytes, Status: OK [13,45] Written, Length: 4 bytes, Status: OK [13,46] Written, Length: 4 bytes, Status: OK [13,47] Written, Length: 1 bytes, Status: OK [13,48] Written, Length: 4 bytes, Status: OK [13,49] Written, Length: 1 bytes, Status: OK [13,50] Written, Length: 1 bytes, Status: OK [13,51] Written, Length: 1 bytes, Status: OK [13,52] Written, Length: 2 bytes, Status: OK [13,53] Written, Length: 4 bytes, Status: OK [13,54] Written, Length: 4 bytes, Status: OK [13,55] Written, Length: 1 bytes, Status: OK [13,56] Written, Length: 1 bytes, Status: OK [13,57] Written, Length: 1 bytes, Status: OK [13,58] Written, Length: 2 bytes, Status: OK [13,59] Written, Length: 1 bytes, Status: OK [13,60] Written, Length: 4 bytes, Status: OK [13,61] Written, Length: 4 bytes, Status: OK [13,62] Written, Length: 1 bytes, Status: OK [13,63] Written, Length: 4 bytes, Status: OK [13,64] Written, Length: 4 bytes, Status: OK [13,65] Written, Length: 1 bytes, Status: OK [13,66] Written, Length: 4 bytes, Status: OK [13,67] Written, Length: 4 bytes, Status: OK [13,68] Written, Length: 1 bytes, Status: OK [13,69] Written, Length: 1 bytes, Status: OK [13,70] Written, Length: 1 bytes, Status: OK [13,71] Written, Length: 4 bytes, Status: OK [13,72] Written, Length: 4 bytes, Status: OK [13,73] Written, Length: 1 bytes, Status: OK [13,74] Written, Length: 4 bytes, Status: OK [13,75] Written, Length: 2 bytes, Status: OK [13,76] Written, Length: 2 bytes, Status: OK [13,77] Written, Length: 2 bytes, Status: OK [13,78] Written, Length: 1 bytes, Status: OK [13,79] Written, Length: 1 bytes, Status: OK [13,80] Written, Length: 1 bytes, Status: OK [13,81] Written, Length: 1 bytes, Status: OK [13,82] Written, Length: 1 bytes, Status: OK [13,83] Written, Length: 2 bytes, Status: OK [13,84] Written, Length: 1 bytes, Status: OK [13,85] Written, Length: 4 bytes, Status: OK [13,86] Written, Length: 4 bytes, Status: OK [13,87] Written, Length: 2 bytes, Status: OK [13,88] Written, Length: 1 bytes, Status: OK [13,89] Written, Length: 4 bytes, Status: OK [13,90] Written, Length: 4 bytes, Status: OK [13,91] Written, Length: 2 bytes, Status: OK [13,92] Written, Length: 1 bytes, Status: OK [13,93] Written, Length: 4 bytes, Status: OK [13,94] Written, Length: 4 bytes, Status: OK [13,95] Written, Length: 2 bytes, Status: OK [13,96] Written, Length: 1 bytes, Status: OK [13,97] Written, Length: 4 bytes, Status: OK [13,98] Written, Length: 4 bytes, Status: OK [13,99] Written, Length: 2 bytes, Status: OK [13,100] Written, Length: 4 bytes, Status: OK [13,101] Written, Length: 2 bytes, Status: OK [13,102] Written, Length: 1 bytes, Status: OK [13,103] Written, Length: 4 bytes, Status: OK [13,104] Written, Length: 4 bytes, Status: OK [13,105] Written, Length: 4 bytes, Status: OK [13,106] Written, Length: 4 bytes, Status: OK [13,107] Written, Length: 4 bytes, Status: OK [13,108] Written, Length: 2 bytes, Status: OK [13,109] Written, Length: 4 bytes, Status: OK [13,110] Written, Length: 4 bytes, Status: OK [13,111] Written, Length: 4 bytes, Status: OK [13,112] Written, Length: 2 bytes, Status: OK [13,113] Written, Length: 4 bytes, Status: OK [13,114] Written, Length: 4 bytes, Status: OK [13,115] Written, Length: 1 bytes, Status: OK [13,116] Written, Length: 1 bytes, Status: OK [13,117] Written, Length: 1 bytes, Status: OK [13,118] Written, Length: 4 bytes, Status: OK [13,119] Written, Length: 4 bytes, Status: OK [13,120] Written, Length: 1 bytes, Status: OK [33,0] Written, Length: 1 bytes, Status: OK [33,1] Written, Length: 1 bytes, Status: OK [42,0] Written, Length: 2 bytes, Status: OK [42,1] Written, Length: 12 bytes, Status: OK [42,2] Written, Length: 36 bytes, Status: OK [42,3] Written, Length: 36 bytes, Status: OK [42,4] Written, Length: 36 bytes, Status: OK [42,5] Written, Length: 36 bytes, Status: OK [42,6] Written, Length: 36 bytes, Status: OK [42,7] Written, Length: 36 bytes, Status: OK [42,8] Written, Length: 36 bytes, Status: OK [42,9] Written, Length: 36 bytes, Status: OK [42,10] Written, Length: 36 bytes, Status: OK [42,11] Written, Length: 36 bytes, Status: OK [42,12] Written, Length: 36 bytes, Status: OK [42,13] Written, Length: 36 bytes, Status: OK [42,14] Written, Length: 36 bytes, Status: OK [42,15] Written, Length: 36 bytes, Status: OK [42,16] Written, Length: 36 bytes, Status: OK [42,17] Written, Length: 36 bytes, Status: OK [42,18] Written, Length: 36 bytes, Status: OK [42,19] Written, Length: 36 bytes, Status: OK [42,20] Written, Length: 36 bytes, Status: OK [42,21] Written, Length: 36 bytes, Status: OK [42,22] Written, Length: 36 bytes, Status: OK [42,23] Written, Length: 40 bytes, Status: OK [42,24] Written, Length: 40 bytes, Status: OK [42,25] Written, Length: 40 bytes, Status: OK [42,26] Written, Length: 40 bytes, Status: OK [42,27] Written, Length: 40 bytes, Status: OK [42,28] Written, Length: 40 bytes, Status: OK [42,29] Written, Length: 40 bytes, Status: OK [42,30] Written, Length: 40 bytes, Status: OK [44,0] Written, Length: 2020 bytes, Status: OK [44,1] Written, Length: 420 bytes, Status: OK [44,2] Written, Length: 1 bytes, Status: OK [44,3] Written, Length: 1 bytes, Status: OK [46,0] Written, Length: 8 bytes, Status: OK [50,0] Written, Length: 2 bytes, Status: OK [54,0] Written, Length: 2 bytes, Status: OK [55,0] Written, Length: 76 bytes, Status: OK [56,0] Written, Length: 4 bytes, Status: OK [65,0] Written, Length: 11 bytes, Status: OK [65,1] Written, Length: 11 bytes, Status: OK [65,2] Written, Length: 11 bytes, Status: OK [65,3] Written, Length: 11 bytes, Status: OK [65,4] Written, Length: 11 bytes, Status: OK [66,0] Written, Length: 40 bytes, Status: OK [66,1] Written, Length: 40 bytes, Status: OK [66,2] Written, Length: 1 bytes, Status: OK [66,3] Written, Length: 1 bytes, Status: OK [66,4] Written, Length: 40 bytes, Status: OK [66,5] Written, Length: 20 bytes, Status: OK [66,6] Written, Length: 1 bytes, Status: OK [66,7] Written, Length: 2 bytes, Status: OK [66,8] Written, Length: 2 bytes, Status: OK [66,9] Written, Length: 2 bytes, Status: OK [66,11] Written, Length: 2 bytes, Status: OK [66,16] Written, Length: 2 bytes, Status: OK [66,17] Written, Length: 2 bytes, Status: OK [66,18] Written, Length: 2 bytes, Status: OK [66,19] Written, Length: 2 bytes, Status: OK [66,20] Written, Length: 2 bytes, Status: OK [66,22] Written, Length: 2 bytes, Status: OK [66,24] Written, Length: 2 bytes, Status: OK [66,26] Written, Length: 2 bytes, Status: OK [66,28] Written, Length: 2 bytes, Status: OK [66,30] Written, Length: 2 bytes, Status: OK [66,32] Written, Length: 2 bytes, Status: OK [66,34] Written, Length: 2 bytes, Status: OK [66,36] Written, Length: 2 bytes, Status: OK [66,43] Written, Length: 63 bytes, Status: OK [66,48] Written, Length: 2 bytes, Status: OK [66,49] Written, Length: 1 bytes, Status: OK [66,50] Written, Length: 2 bytes, Status: OK [66,61] Written, Length: 4 bytes, Status: OK [66,62] Written, Length: 4 bytes, Status: OK [66,63] Written, Length: 4 bytes, Status: OK [66,64] Written, Length: 4 bytes, Status: OK [66,65] Written, Length: 4 bytes, Status: OK [66,66] Written, Length: 4 bytes, Status: OK [66,67] Written, Length: 4 bytes, Status: OK [66,68] Written, Length: 4 bytes, Status: OK [66,69] Written, Length: 4 bytes, Status: OK [66,70] Written, Length: 4 bytes, Status: OK [66,71] Written, Length: 4 bytes, Status: OK [66,72] Written, Length: 4 bytes, Status: OK [66,73] Written, Length: 4 bytes, Status: OK [66,74] Written, Length: 4 bytes, Status: OK [66,75] Written, Length: 4 bytes, Status: OK [66,76] Written, Length: 4 bytes, Status: OK [66,77] Written, Length: 4 bytes, Status: OK [66,79] Written, Length: 4 bytes, Status: OK [66,80] Written, Length: 4 bytes, Status: OK [66,81] Written, Length: 4 bytes, Status: OK [66,83] Written, Length: 4 bytes, Status: OK [66,84] Written, Length: 1800 bytes, Status: OK [66,85] Written, Length: 60 bytes, Status: OK [66,86] Written, Length: 4800 bytes, Status: OK [66,87] Written, Length: 300 bytes, Status: OK [66,88] Written, Length: 50 bytes, Status: OK [66,89] Written, Length: 6 bytes, Status: OK [66,90] Written, Length: 4 bytes, Status: OK [66,94] Written, Length: 64 bytes, Status: OK [66,95] Written, Length: 64 bytes, Status: OK [66,96] Written, Length: 15080 bytes, Status: OK [66,101] Written, Length: 3 bytes, Status: OK [66,102] Written, Length: 3 bytes, Status: OK [66,103] Written, Length: 3 bytes, Status: OK [66,104] Written, Length: 3 bytes, Status: OK [67,0] Written, Length: 1848 bytes, Status: OK [76,0] Written, Length: 532 bytes, Status: OK [83,0] Written, Length: 811 bytes, Status: OK [83,1] Written, Length: 791 bytes, Status: OK [83,2] Written, Length: 1054 bytes, Status: OK [83,3] Written, Length: 774 bytes, Status: OK [83,4] Written, Length: 576 bytes, Status: OK [83,5] Written, Length: 850 bytes, Status: OK [83,6] Written, Length: 940 bytes, Status: OK [83,7] Written, Length: 910 bytes, Status: OK [84,0] Written, Length: 3 bytes, Status: OK [84,1] Written, Length: 89 bytes, Status: OK [84,2] Written, Length: 93 bytes, Status: OK [84,3] Written, Length: 147 bytes, Status: OK [84,4] Written, Length: 141 bytes, Status: OK [84,5] Written, Length: 133 bytes, Status: OK [84,6] Written, Length: 113 bytes, Status: OK [84,7] Written, Length: 125 bytes, Status: OK [84,8] Written, Length: 137 bytes, Status: OK [84,9] Written, Length: 113 bytes, Status: OK [84,10] Written, Length: 121 bytes, Status: OK [84,11] Written, Length: 125 bytes, Status: OK [84,12] Written, Length: 149 bytes, Status: OK [84,13] Written, Length: 139 bytes, Status: OK [87,0] Written, Length: 4 bytes, Status: OK [94,0] Written, Length: 40 bytes, Status: OK [95,0] Written, Length: 1 bytes, Status: OK [95,1] Written, Length: 1 bytes, Status: OK [96,0] Written, Length: 24 bytes, Status: OK [107,0] Written, Length: 21 bytes, Status: OK [107,1] Written, Length: 89 bytes, Status: OK [107,2] Written, Length: 69 bytes, Status: OK [107,3] Written, Length: 70 bytes, Status: OK [107,25] Written, Length: 132 bytes, Status: OK [110,0] Written, Length: 6 bytes, Status: OK [111,0] Written, Length: 200 bytes, Status: OK [111,1] Written, Length: 20 bytes, Status: OK [111,2] Written, Length: 20 bytes, Status: OK [111,126] Written, Length: 20 bytes, Status: OK [111,127] Written, Length: 20 bytes, Status: OK [111,150] Written, Length: 8 bytes, Status: OK [111,151] Written, Length: 4 bytes, Status: OK [111,152] Written, Length: 40 bytes, Status: OK [116,0] Written, Length: 2 bytes, Status: OK [116,1] Written, Length: 12 bytes, Status: OK [116,2] Written, Length: 36 bytes, Status: OK [116,3] Written, Length: 36 bytes, Status: OK [116,4] Written, Length: 36 bytes, Status: OK [116,5] Written, Length: 36 bytes, Status: OK [116,6] Written, Length: 36 bytes, Status: OK [116,7] Written, Length: 36 bytes, Status: OK [116,8] Written, Length: 36 bytes, Status: OK [116,9] Written, Length: 36 bytes, Status: OK [116,10] Written, Length: 36 bytes, Status: OK [116,11] Written, Length: 36 bytes, Status: OK [116,12] Written, Length: 36 bytes, Status: OK [116,13] Written, Length: 36 bytes, Status: OK [116,14] Written, Length: 36 bytes, Status: OK [116,15] Written, Length: 36 bytes, Status: OK [116,16] Written, Length: 36 bytes, Status: OK [116,17] Written, Length: 36 bytes, Status: OK [116,18] Written, Length: 36 bytes, Status: OK [116,19] Written, Length: 36 bytes, Status: OK [116,20] Written, Length: 36 bytes, Status: OK [116,21] Written, Length: 36 bytes, Status: OK [116,22] Written, Length: 36 bytes, Status: OK [116,23] Written, Length: 40 bytes, Status: OK [116,24] Written, Length: 40 bytes, Status: OK [116,25] Written, Length: 40 bytes, Status: OK [116,26] Written, Length: 40 bytes, Status: OK [116,27] Written, Length: 40 bytes, Status: OK [116,28] Written, Length: 40 bytes, Status: OK [116,29] Written, Length: 40 bytes, Status: OK [116,30] Written, Length: 40 bytes, Status: OK [116,31] Written, Length: 40 bytes, Status: OK [116,32] Written, Length: 40 bytes, Status: OK [117,0] Written, Length: 4 bytes, Status: OK [117,1] Written, Length: 3 bytes, Status: OK [117,2] Written, Length: 6 bytes, Status: OK [117,3] Written, Length: 1 bytes, Status: OK [117,4] Written, Length: 9 bytes, Status: OK [117,5] Written, Length: 10 bytes, Status: OK [117,6] Written, Length: 8 bytes, Status: OK [117,13] Written, Length: 3 bytes, Status: OK [117,14] Written, Length: 3 bytes, Status: OK [117,15] Written, Length: 1 bytes, Status: OK [118,0] Written, Length: 1 bytes, Status: OK [120,0] Written, Length: 8 bytes, Status: OK [120,1] Written, Length: 8 bytes, Status: OK [120,2] Written, Length: 8 bytes, Status: OK [120,3] Written, Length: 2 bytes, Status: OK [120,4] Written, Length: 72 bytes, Status: OK [120,5] Written, Length: 1 bytes, Status: OK [120,6] Written, Length: 8 bytes, Status: OK [120,7] Written, Length: 8 bytes, Status: OK [127,1] Written, Length: 614 bytes, Status: OK [127,2] Written, Length: 614 bytes, Status: OK [127,3] Written, Length: 614 bytes, Status: OK [127,4] Written, Length: 614 bytes, Status: OK [127,5] Written, Length: 614 bytes, Status: OK [127,6] Written, Length: 614 bytes, Status: OK [127,7] Written, Length: 614 bytes, Status: OK [127,8] Written, Length: 614 bytes, Status: OK [127,9] Written, Length: 614 bytes, Status: OK [127,10] Written, Length: 614 bytes, Status: OK [127,11] Written, Length: 614 bytes, Status: OK [127,12] Written, Length: 614 bytes, Status: OK [127,13] Written, Length: 614 bytes, Status: OK [127,14] Written, Length: 614 bytes, Status: OK [127,15] Written, Length: 614 bytes, Status: OK [127,16] Written, Length: 614 bytes, Status: OK [127,17] Written, Length: 614 bytes, Status: OK [127,18] Written, Length: 614 bytes, Status: OK [127,19] Written, Length: 614 bytes, Status: OK [127,20] Written, Length: 614 bytes, Status: OK [127,21] Written, Length: 614 bytes, Status: OK [127,22] Written, Length: 614 bytes, Status: OK [127,23] Written, Length: 614 bytes, Status: OK [127,24] Written, Length: 614 bytes, Status: OK [127,25] Written, Length: 614 bytes, Status: OK [127,26] Written, Length: 614 bytes, Status: OK [127,27] Written, Length: 614 bytes, Status: OK [127,28] Written, Length: 614 bytes, Status: OK [127,29] Written, Length: 614 bytes, Status: OK [127,30] Written, Length: 614 bytes, Status: OK [127,31] Written, Length: 614 bytes, Status: OK [127,32] Written, Length: 614 bytes, Status: OK [127,33] Written, Length: 614 bytes, Status: OK [127,34] Written, Length: 614 bytes, Status: OK [127,35] Written, Length: 614 bytes, Status: OK [127,36] Written, Length: 614 bytes, Status: OK [127,37] Written, Length: 614 bytes, Status: OK [127,38] Written, Length: 614 bytes, Status: OK [127,39] Written, Length: 614 bytes, Status: OK [127,40] Written, Length: 614 bytes, Status: OK [127,41] Written, Length: 614 bytes, Status: OK [127,42] Written, Length: 614 bytes, Status: OK [163,0] Written, Length: 8 bytes, Status: OK [181,0] Written, Length: 8 bytes, Status: OK [181,1] Written, Length: 10 bytes, Status: OK [181,2] Written, Length: 1 bytes, Status: OK [182,0] Written, Length: 1 bytes, Status: OK [182,1] Written, Length: 1 bytes, Status: OK [182,2] Written, Length: 1 bytes, Status: OK [182,3] Written, Length: 8 bytes, Status: OK [182,4] Written, Length: 1 bytes, Status: OK [182,5] Written, Length: 1 bytes, Status: OK [182,6] Written, Length: 1 bytes, Status: OK [182,7] Written, Length: 1 bytes, Status: OK [182,8] Written, Length: 1 bytes, Status: OK [182,9] Written, Length: 1 bytes, Status: OK [182,10] Written, Length: 1 bytes, Status: OK [182,13] Written, Length: 8 bytes, Status: OK [182,17] Written, Length: 1 bytes, Status: OK [182,18] Written, Length: 8 bytes, Status: OK [182,19] Written, Length: 8 bytes, Status: OK [183,0] Written, Length: 1 bytes, Status: OK [183,1] Written, Length: 1 bytes, Status: OK [183,2] Written, Length: 1 bytes, Status: OK [183,3] Written, Length: 8 bytes, Status: OK [183,4] Written, Length: 1 bytes, Status: OK [183,5] Written, Length: 1 bytes, Status: OK [183,6] Written, Length: 1 bytes, Status: OK [183,7] Written, Length: 1 bytes, Status: OK [183,8] Written, Length: 1 bytes, Status: OK [183,9] Written, Length: 1 bytes, Status: OK [183,10] Written, Length: 1 bytes, Status: OK [183,13] Written, Length: 8 bytes, Status: OK [183,17] Written, Length: 1 bytes, Status: OK [183,18] Written, Length: 8 bytes, Status: OK [183,19] Written, Length: 8 bytes, Status: OK [184,0] Written, Length: 1 bytes, Status: OK [184,1] Written, Length: 1 bytes, Status: OK [184,2] Written, Length: 1 bytes, Status: OK [184,3] Written, Length: 8 bytes, Status: OK [184,4] Written, Length: 1 bytes, Status: OK [184,5] Written, Length: 1 bytes, Status: OK [184,6] Written, Length: 1 bytes, Status: OK [184,7] Written, Length: 1 bytes, Status: OK [184,8] Written, Length: 1 bytes, Status: OK [184,9] Written, Length: 1 bytes, Status: OK [184,10] Written, Length: 1 bytes, Status: OK [184,13] Written, Length: 8 bytes, Status: OK [184,17] Written, Length: 1 bytes, Status: OK [184,18] Written, Length: 8 bytes, Status: OK [184,19] Written, Length: 8 bytes, Status: OK [185,0] Written, Length: 1 bytes, Status: OK [185,1] Written, Length: 1 bytes, Status: OK [185,2] Written, Length: 1 bytes, Status: OK [185,3] Written, Length: 8 bytes, Status: OK [185,4] Written, Length: 1 bytes, Status: OK [185,5] Written, Length: 1 bytes, Status: OK [185,6] Written, Length: 1 bytes, Status: OK [185,7] Written, Length: 1 bytes, Status: OK [185,8] Written, Length: 1 bytes, Status: OK [185,9] Written, Length: 1 bytes, Status: OK [185,10] Written, Length: 1 bytes, Status: OK [185,13] Written, Length: 8 bytes, Status: OK [185,17] Written, Length: 1 bytes, Status: OK [185,18] Written, Length: 8 bytes, Status: OK [185,19] Written, Length: 8 bytes, Status: OK [186,0] Written, Length: 1 bytes, Status: OK [186,1] Written, Length: 1 bytes, Status: OK [186,2] Written, Length: 1 bytes, Status: OK [186,3] Written, Length: 8 bytes, Status: OK [186,4] Written, Length: 1 bytes, Status: OK [186,5] Written, Length: 1 bytes, Status: OK [186,6] Written, Length: 1 bytes, Status: OK [186,7] Written, Length: 1 bytes, Status: OK [186,8] Written, Length: 1 bytes, Status: OK [186,9] Written, Length: 1 bytes, Status: OK [186,10] Written, Length: 1 bytes, Status: OK [186,13] Written, Length: 8 bytes, Status: OK [186,17] Written, Length: 1 bytes, Status: OK [186,18] Written, Length: 8 bytes, Status: OK [186,19] Written, Length: 8 bytes, Status: OK [187,0] Written, Length: 1 bytes, Status: OK [187,1] Written, Length: 1 bytes, Status: OK [187,2] Written, Length: 1 bytes, Status: OK [187,3] Written, Length: 8 bytes, Status: OK [187,4] Written, Length: 1 bytes, Status: OK [187,5] Written, Length: 1 bytes, Status: OK [187,6] Written, Length: 1 bytes, Status: OK [187,7] Written, Length: 1 bytes, Status: OK [187,8] Written, Length: 1 bytes, Status: OK [187,9] Written, Length: 1 bytes, Status: OK [187,10] Written, Length: 1 bytes, Status: OK [187,13] Written, Length: 8 bytes, Status: OK [187,17] Written, Length: 1 bytes, Status: OK [187,18] Written, Length: 8 bytes, Status: OK [187,19] Written, Length: 8 bytes, Status: OK [190,0] Written, Length: 355 bytes, Status: OK [191,0] Written, Length: 4 bytes, Status: OK [193,2] Written, Length: 8 bytes, Status: OK [193,3] Written, Length: 32 bytes, Status: OK [193,4] Written, Length: 32 bytes, Status: OK [200,0] Written, Length: 5 bytes, Status: OK [206,0] Written, Length: 269 bytes, Status: OK [206,1] Written, Length: 259 bytes, Status: OK [206,2] Written, Length: 227 bytes, Status: OK [206,3] Written, Length: 191 bytes, Status: OK [206,4] Written, Length: 186 bytes, Status: OK [206,5] Written, Length: 154 bytes, Status: OK [206,6] Written, Length: 176 bytes, Status: OK [206,7] Written, Length: 155 bytes, Status: OK [208,0] Written, Length: 40 bytes, Status: OK [213,0] Written, Length: 20 bytes, Status: OK [218,0] Written, Length: 2 bytes, Status: OK [225,0] Written, Length: 1 bytes, Status: OK [225,1] Written, Length: 6 bytes, Status: OK [225,2] Written, Length: 6 bytes, Status: OK [228,1] Written, Length: 4 bytes, Status: OK [232,0] Written, Length: 20 bytes, Status: OK [232,1] Written, Length: 1 bytes, Status: OK [232,3] Written, Length: 1 bytes, Status: OK [232,4] Written, Length: 1 bytes, Status: OK [232,5] Written, Length: 1 bytes, Status: OK [238,0] Written, Length: 78 bytes, Status: OK [238,1] Written, Length: 1 bytes, Status: OK [250,1] Written, Length: 992 bytes, Status: OK [250,2] Written, Length: 128 bytes, Status: OK [250,3] Written, Length: 250 bytes, Status: OK [250,4] Written, Length: 32 bytes, Status: OK Write PM Finished, Record written OK: 597, Record written NOT OK: 0 simlock not corrupted anymore MCU Version V 04.23 MCU Date 26-10-07 Product RM-166 (Nokia 5070/6070/6080 CABLE 3220) Manufacturer (c) Nokia. IMEI 357690010486683 Mastercode 5562263314 Proceeding with RSA Unlock... Setting Local Mode... Local mode Set Warning: Failed to read SP Info, Assuming defaults Asic 2 HW Signature 009DF3DACBF1B4A1 Simlock Server SIMLOCK SERVER VERSION 58 Simlock Key D28299A3D3C72A3B Simlock Profile 0E7DF4DD2ECDEEBB Simlock Aux 00025555 Simlock IMEI 00553576900104866800 Simlock Key Cnt 5 Simlock FBUS Cnt 8 Asking card to sign HW Signature... Signed OK (F0C2D99888ECB9C13537B00AC089B0652B5BF56E) Calculating SP... Writing SP... Failed to Unlock DCT4 Plus -> Possible cause: Other error (0x00) Last edited by mp3hot; 05-01-2011 at 21:54. |
Help: Forgot my 6110 user lock code!! | GByte9 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 02-26-2016 14:52 |
SP Lock 1&4 | dw | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 11 | 06-26-1999 06:22 |
