Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 03-30-2010, 08:36   #1 (permalink)
rickliew's Avatar
Member: 522783
Thanks Meter: 62
5130 contact service(hardware fault...?)
i have 5130 c.s,software seems ok.
MCU Version V 07.95
MCU Date 03-02-10
Product RM-495
Manufacturer (c) Nokia
IMEI 358293034793983
Mastercode 313774667
IMEI Spare 3A85920343979308
IMEI SV 3385920343979348F8000000
PPM V 07.95, 03-02-10, RM-495, (c) Nokia , S
CNT Content: s_red, V 07.95, 03-02-10, RM-495, (c) Nokia ,
PSN HEC345703
Product Code 0571584
Module Code 0204024
Basic Product Code 0567773
PSD 0000000000000000
LPSN 0
RETU 16
TAHVO 22
AHNE 30
HW 1000
RFIC 06540601
DSP ICPR72_10w01
LCD SEIKO
BT 2222-302
Simlock Server SIMLOCK SERVER
Simlock Key 2440700000000000
Simlock Profile 0000000000000000
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Simlock [1,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [1,2] State: OPENED Type: GID Data: FFFF
Simlock [1,3] State: OPENED Type: GID Data: FFFF
Simlock [1,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [1,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [2,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [2,2] State: OPENED Type: GID Data: FFFF
Simlock [2,3] State: OPENED Type: GID Data: FFFF
Simlock [2,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [2,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [3,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [3,2] State: OPENED Type: GID Data: FFFF
Simlock [3,3] State: OPENED Type: GID Data: FFFF
Simlock [3,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [3,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [4,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [4,2] State: OPENED Type: GID Data: FFFF
Simlock [4,3] State: OPENED Type: GID Data: FFFF
Simlock [4,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [4,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [5,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [5,2] State: OPENED Type: GID Data: FFFF
Simlock [5,3] State: OPENED Type: GID Data: FFFF
Simlock [5,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [5,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [6,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [6,2] State: OPENED Type: GID Data: FFFF
Simlock [6,3] State: OPENED Type: GID Data: FFFF
Simlock [6,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [6,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [7,1] State: OPENED Type: MCC-MNC Data: FFFFFF
Simlock [7,2] State: OPENED Type: GID Data: FFFF
Simlock [7,3] State: OPENED Type: GID Data: FFFF
Simlock [7,4] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Simlock [7,5] State: OPENED Type: IMSI Data: FFFFFFFFFFFFFFFF
Started Phone Security Analysis...
MCU Version V 07.95
MCU Date 03-02-10
Product RM-495
Reading Security Block...
Security block OK and saved to "RM-495_358293034793983_3302010_33406 PM.SecurityBlock.PM"
Step 1 : Testing SIMLOCK
SIMLOCK SEFLTEST PASSED OK!
Step 2 : Testing SECURITY
SECURITY SEFLTEST PASSED OK!
Step 3 : Analyzing Security Block
"1D900017AA026B50612F7AFB52BDDA587DA4F424.C0000EEE " Exists, That is good...
Checking SUPERDONGLE...
SUPERDONGLE FOUND AND CHECKSUM OK! PASSED!
Checking SIMLOCK...
Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?)
Checking MCU&DSP TIMESTAMPS...
MCU&DSP TIMESTAMPS FOUND AND CHECKSUM OK! PASSED!
Checking CMLA KEYS...
CMLA KEYS FOUND AND CHECKSUM OK! PASSED!
Checking ECC KEYS...
ECC KEYS FOUND AND CHECKSUM OK! PASSED!
Checking DIV KEYS...
DIV KEYS FOUND AND CHECKSUM OK! PASSED!
Analyze finished!
Selftests to proceed: 29
Failed ST_EAR_DATA_LOOP_TEST
Passed ST_SIM_CLK_LOOP_TEST
Passed ST_SIM_IO_CTRL_LOOP_TEST
Passed ST_SLEEP_X_LOOP_TEST
Passed ST_UEM_CBUS_IF_TEST
Failed ST_KEYBOARD_STUCK_TEST
Passed ST_CAMERA_IF_TEST
Passed ST_BACKUP_BATT_TEST
Passed ST_LCD_TEST
Passed ST_LPRF_IF_TEST
Passed ST_LPRF_AUDIO_LINES_TEST
Passed ST_CURRENT_CONS_TEST
Passed ST_RADIO_TEST
Passed ST_BACKLIGHT_TEST
Passed ST_SIM_LOCK_TEST
Passed ST_SECURITY_TEST
Passed ST_BT_WAKEUP_TEST
Passed ST_HOOKINT_TEST
Passed ST_TAHVOINT_TEST
Passed ST_BTEMP_TEST
Passed ST_IIC_TEST
Passed ST_EXT_DEVICE_TEST
Passed ST_CDSP_SLEEPCLK_FREQ_TEST
Passed ST_CDSP_SLEEPCLOCK_FREQ_TEST
Passed ST_CDSP_RF_BB_IF_TEST
Passed ST_CDSP_RF_SUPPLY_TEST
Passed ST_CDSP_TX_PLL_PHASE_LOCK_TEST
Passed ST_CDSP_RX_IQ_LOOP_BACK_TEST
Passed ST_CDSP_GSM_TX_POWER_TEST
Selftests done, Tests total: 29, Tests passed: 27, Tests not passed: 2
what to do?
Old 03-30-2010, 08:44   #2 (permalink)
Member: 823633
Thanks Meter: 1,705
bro write good pm file sx4 authorize
after
re-heat pcb normall
Old 03-30-2010, 08:51   #3 (permalink)
Thanks Meter: 4,071
just write good pm ......
Old 03-30-2010, 08:56   #4 (permalink)
Member: 765059
Arrow
Hello man, how unlock this cellphone???
thanks
Old 03-30-2010, 09:02   #5 (permalink)
Thanks Meter: 4,071
Arrow
thanks
this is SL3 phone
unlock not supported yet
Old 03-30-2010, 09:18   #6 (permalink)
rickliew's Avatar
Member: 522783
Thanks Meter: 62
after write good pm still same.
all not work man...
Old 03-30-2010, 14:10   #7 (permalink)
[Shadab_M]'s Avatar
Member: 238812
Sonork: 100.1602669
Thanks Meter: 1,443
all not work man...
Its hardware problem Bro!
How can you solve Hardware Problem with Software?
Check if any Button or Side Switch is pressed or stuck. If not remove Keypad IC and then check if ST_KEYBOARD_STUCK_TEST is passed or not.
For Ear Data Loop Test, you may reheat AVILMA or SIMPLY CHANGE IT!
@others
Before giving advise, it is better to look deeply into logs. Bcoz wrong advise may kill a phone easily.
Br,
Shadab Ahmad
nokia 5130 contact service burhani mobile Nokia Hardware & Hardware Repair 165 12-02-2012 12:27
5130 contact service (ANSWERED) vishal123123 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 3 08-10-2011 11:05
5130 contact service data link snowkp Nokia Base Band 5 ( BB-5 ) 40 07-25-2011 09:19
nokia 5130 contact service bombayteji Nokia Hardware & Hardware Repair 8 06-06-2010 13:01
NOKIA LOGO & Contact Retailer fault asrar Nokia Hardware & Hardware Repair 7 11-06-2007 21:52
Page generated in 0.28754 seconds with 9 queries
