03-04-2010, 12:20 | #1 (permalink) |
Freak Poster Join Date: Jun 2003 Location: Russia Age: 45
Member: 31044 Status: Offline Thanks Meter: 0 | 5220 Contact retailer, RPL not helps? Selftests to proceed: 29 Passed ST_EAR_DATA_LOOP_TEST Passed ST_SIM_CLK_LOOP_TEST Passed ST_SIM_IO_CTRL_LOOP_TEST Passed ST_SLEEP_X_LOOP_TEST Passed ST_UEM_CBUS_IF_TEST Passed ST_KEYBOARD_STUCK_TEST Failed ST_CAMERA_IF_TEST Passed ST_BACKUP_BATT_TEST Passed ST_LCD_TEST Passed ST_LPRF_IF_TEST Passed ST_LPRF_AUDIO_LINES_TEST Passed ST_CURRENT_CONS_TEST Passed ST_RADIO_TEST Passed ST_BACKLIGHT_TEST Passed ST_SIM_LOCK_TEST Failed ST_SECURITY_TEST Passed ST_BT_WAKEUP_TEST Passed ST_HOOKINT_TEST Passed ST_TAHVOINT_TEST Passed ST_BTEMP_TEST Passed ST_IIC_TEST Passed ST_EXT_DEVICE_TEST Passed ST_CDSP_SLEEPCLK_FREQ_TEST Passed ST_CDSP_SLEEPCLOCK_FREQ_TEST Passed ST_CDSP_RF_BB_IF_TEST Passed ST_CDSP_RF_SUPPLY_TEST Passed ST_CDSP_TX_PLL_PHASE_LOCK_TEST Passed ST_CDSP_RX_IQ_LOOP_BACK_TEST Passed ST_CDSP_GSM_TX_POWER_TEST Analize security: Started Phone Security Analysis... MCU Version V 06.51 MCU Date 23-03-09 Product RM-411 Manufacturer (c) Nokia IMEI 355717022080998 Mastercode 45233353 Reading Security Block... Security block OK and saved to "RM-411_355717022080998_04.03.2010_162129.SecurityBloc k.PM" Step 1 : Testing SIMLOCK SIMLOCK SEFLTEST PASSED OK! Step 2 : Testing SECURITY -- SECURITY PROBLEM -- Phone have failed SECURITY Test, that means Superdongle Area is DAMAGED! To repair it, simply slick "SX4 Authorization / SD Repair" button. After SX4/SD Repair, don't forget to write PM file with fields 1,309 -- SECURITY PROBLEM -- Step 3 : Analyzing Security Block "28B0010DEE160354BC51D0DE60E54CC635E3A795.C0003640 " Exists, That is good... Checking SUPERDONGLE... SUPERDONGLE FOUND AND CHECKSUM OK! PASSED! Checking SIMLOCK... SIMLOCK FOUND AND CHECKSUM OK! PASSED! Checking MCU&DSP TIMESTAMPS... MCU&DSP TIMESTAMPS FOUND AND CHECKSUM OK! PASSED! Checking CMLA KEYS... CMLA KEYS FOUND AND CHECKSUM OK! PASSED! Checking ECC KEYS... ECC KEYS FOUND AND CHECKSUM OK! PASSED! Checking DIV KEYS... Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?) Analyze finished! What i do: Write RPL, SX4, pm, but still St_security fails. HElp me plz. |
03-04-2010, 13:11 | #7 (permalink) |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | If the sx4 and the good PM didn't help you, you must write a good rpl for this model to fix the HWC and CCC certs Thick plain RPL and click on write RPL select the RPL file in the zip attached and go. Afterward sx4 again and good PM 1 and 309 Please, report BR Alex Last edited by moulnisky; 03-04-2010 at 13:21. |
6630 contact retailer st..fail help me | themobileguy1 | Universalbox | 2 | 02-06-2010 14:07 |
5220 contact service... tried to solve by cyclone not RPL cal. | mitch_md3 | Cyclonebox | 15 | 11-15-2009 13:40 |
n96 contact retailler -can not write write pm 1 and 309 after sx4-help me | zone2 | Cyclonebox | 8 | 10-23-2009 05:16 |
Phone Startup Failed Contact Retailer N82 (Plz Help How to Repair via MT-BOX) | Shayesta197 | Nokia Base Band 5 ( BB-5 ) | 21 | 01-11-2009 04:48 |
6550c IMEI 123456 write rpl not help | mroa | MT-BOX | 4 | 11-28-2007 16:00 |
