01-22-2010, 14:41 | #1 (permalink) |
Major Poster Join Date: Apr 2009
Member: 1002355 Status: Offline Thanks Meter: 0 | 5220xm dead after flashing Please Help [SOLVED] Thank you very much in advance for your support, BR Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.0.8198 Handling device: [Cyclone Team], [Cyclone Bootloader] Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v01.15, (Jan 2 2010 03:59:40, gcc v4.3.2, RTOS V6.0.1), Type: Signed Production Application Box Serial Number: xxxxxxx HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk32 Initializing security card... Card Serial Number: xxxxxxx Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 4.91v PASSED MCU Voltage 3.28v PASSED Core Voltage 1.77v PASSED VBAT Voltage 0.71v PASSED VBAT Voltage 4.87v PASSED Box VPP disabled VPP Voltage 0.02v PASSED Internal Box VPP Enabled VPP Voltage 4.88v PASSED Box VPP disabled VPP Voltage 0.04v PASSED External Box VPP Enabled VPP Voltage 0.02v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work Scanning avaiable products... Processing C:\Archivos de programa\Nokia\Phoenix\Products\... Found 1 products, Filtering BB5 Products - wait... 1 Products left after filtering. Ready. Retrieving Variants for Product RM-411 - wait... 153 Variants Retrieved Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006030C192101033000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1720020982E3555070D85C59049F14EEB69E1D0C CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT_ROM_ID: 273F6D55DFAAF68F RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.9.11.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x0089898200008A31, Intel, NOR FlashContent[0,CMT]: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.9.17.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled Warning: PAPUBKEYS Hash Missing! APE Subsystem Not Found Flashbus Write baud set to 5.0Mbits Restarting MCU... Processing pre flash tasks... Applying downgrade patch... Apply downgrade patch failed -> Phone not detected Pre flash tasks finished, continuing... Processing rm411__04.00.mcusw (CMT)... Booting RAP... CMT_SYSTEM_ASIC_ID: 000000010000022600010006030C192101033000 CMT_EM_ASIC_ID: 00000295 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 1720020982E3555070D85C59049F14EEB69E1D0C CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT_ROM_ID: 273F6D55DFAAF68F rm411__04.00.mcusw, Type: Flash Image, Algo: BB5, BB5 ALGORITHM RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.9.11.1, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits FlashChip[0,CMT]: 0x0089898200008A31, Intel, NOR FlashContent[0,CMT]: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.9.17.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled Warning: PAPUBKEYS Hash Missing! Flashbus Write baud set to 5.0Mbits Sending Certificates... Certificates OK Started group flash erase EraseArea[0,CMT]: 0x00000000-0x000006BF, NOR EraseArea[0,CMT]: 0x000006C0-0x0001FFFF, NOR EraseArea[0,CMT]: 0x00040000-0x000BFFFF, NOR EraseArea[0,CMT]: 0x000C0000-0x0013FFFF, NOR EraseArea[0,CMT]: 0x00140000-0x0137FFFF, NOR EraseArea[0,CMT]: 0x01380000-0x0151FFFF, NOR Waiting 320s for erasure finish... Erase taken 3.984s Writing all blocks... Writing CMT NOLO Certificate... Block Write Failed -> Failed to write CMT cert data (3), Programming Status Error Processing Flash Image Failed -> Failed to write all blocks Failed to Process all Image files -> Failed to process rm411__04.00.mcusw |
01-22-2010, 14:56 | #3 (permalink) |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | You downgraded the phone (and you shouldn't as been warned by the software was not possible to apply the downgrade patch) and you are working on a bb5 mobile without the TX2 adapter (the yellow cable in bundle with the box) and got error 3 in flash.. use the tx2 adapter and flash it again with the original version of firmware. BR Alex |
The Following User Says Thank You to moulnisky For This Useful Post: |
01-22-2010, 16:34 | #5 (permalink) |
Member: 1002355 Status: Offline Thanks Meter: 0 | 5220 Thanks everyone Alex, I am working on the phone with the TX2 adapter as the manual says. I just do not know what is happening, how can I know what is the original version that the phone had. I ve tried with different versions and the error is the same. Sorry for my silly questions. BR |
01-22-2010, 17:04 | #6 (permalink) |
Member: 947561 Status: Offline Thanks Meter: 14,053 | if you keep getting error 3 and you are using the tx2 adapter, check both tx2 adapter (redo the soldering on the pcb rj45 socket side) and the fbus cable.. clean as well the mobile's pinouts. For the firmware, in the dubt, download the latest version and use that one BR Alex |
01-25-2010, 14:20 | #8 (permalink) |
Member: 1002355 Status: Offline Thanks Meter: 0 | 5220 Hi. I redid the soldering of the tx2 adapter and everything went almost ok, the flashing process stared with the version 05.63 but in the middle of the process i got an error, now the phone was not completly dead, it opened a white screen with the nokia sign and shut down.I write back the phone certificates and tried to flash it again, and this time everything went fine.I would like to know if this is a normal procedure or that this just happend by hassard. Thanks in avance, BR |
01-25-2010, 14:22 | #9 (permalink) |
Member: 947561 Status: Offline Thanks Meter: 14,053 | I think the mobile was a bit meesed up with all the try you did before.. and this the reason why you had a failure in the flash in the first attempt. After writing back the RPL the flash went fine. Happy you solved BR Alex |
K750i DEAD AFTER FLASH,PLEASE HELP!!! | miecom | UFS2 + UFS3-Tornadoflasher | 2 | 07-27-2006 14:20 |
K700i DEAD AFTER FLASH,PLEASE HELP!!! | miecom | Sony Ericsson | 4 | 07-27-2006 13:38 |
Panasonic G50 dead after Flash Please help. | Delsspare1 | Panasonic | 0 | 05-15-2005 15:09 |
C330 dead after flashing please help | comunicatel | Motorola P2k | 26 | 08-21-2003 09:46 |
