03-31-2010, 05:55 | #1 (permalink) |
Freak Poster Join Date: Oct 2005 Location: perth aust.
Member: 188959 Status: Offline Thanks Meter: 7 | 5800d-1 problem I was presented a nokia 5800d-1 that was purchased in the UK , and may have also been unlocked there as well, but not sure whether it was flash based or code based. The handset will not send or recieve any sms , mms, and will not register missed calls. I flashed with the original version , [v24.0.**** ] and it worked ok for 2 weeks. Handset was returned with the same issue 14 days later , so I tried to update firmware/software , [v34.0.****] , but still no result. On closer investigation ,it was noted that message centre numbers can be changed easily, all settings can be changed , HOWEVER the message centre [vodafone] cannot be changed , and appears to be hard coded in some way [with no way to add or change]. It looks to have the UK message centre , but the Aus message centre number [ Voda] . Can I use a particular file to flash into the handset ,or any advice would be greatfully accepted! [Alex????] . |
03-31-2010, 07:30 | #2 (permalink) |
No Life Poster Join Date: Jan 2009 Location: England Age: 59
Member: 947561 Status: Offline Thanks Meter: 14,053 | Hi Flash the mobile using an unbranded firmware related to your region. As well, to prevent the customer rebrand again the mobile doing a software update with NSS, change the product code of the mobile with the one used for the flash. BR Alex |
04-07-2010, 12:20 | #3 (permalink) |
Member: 188959 Status: Offline Thanks Meter: 7 | Gday Alex, sorry for the late reply , but have been testing this handset for a few days. The unit has had the product code changed , and upgraded to the latest nok firmware. The phone still has the same problem. Of approx 10 sent/recieved text messages sent , only sent 1 arrived , 5 hours later! The rest went straight to the outbox,and were never sent. Also, the handset still does register missed calls , even though it says missed call on the screen, but no details are ever stored... Am starting to think hardware , however unit is not ingressed , and áppears ''structually'' intact [diplexor/s , filters, PA all ok , solders points intact and unbroken/uncorroded. Any more ideas I could try , am finally stumped after years repairing this type of thing, and am fresh out of ideas!! Cheers |
5800d-1 problem | ammamun | Nokia Hardware & Hardware Repair | 4 | 03-05-2010 17:49 |
5800d satrange problem | GSMTURBO | Nokia Hardware & Hardware Repair | 10 | 11-13-2009 23:52 |
5800d unlock problem................ | UNLOCK PARK ® | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 10-14-2009 17:20 |
5800d unlock problem | ahmed00 | Cyclonebox | 10 | 09-16-2009 21:14 |
ned help 5800d bt problem | jhun_blinkstar | Nokia Hardware & Hardware Repair | 1 | 08-07-2009 16:32 |
