Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 04-01-2009, 13:18   #1 (permalink)
Member: 754345
Thanks Meter: 32
6131 flashing with cyclone good !
[COLOR="White"]6131 FBUS
[B][FONT=Arial][SIZE=2]MCU Version V 05.50
MCU Date 20-09-06
Product RM-115
Manufacturer (c) Nokia.
IMEI 359374003220783
IMEI Spare 3A95730430227008
IMEI SV 3395730430227008F6000000
PPM V 05.50, 20-09-06, RM-115, (c) Nokia. , V
CNT Content: viet, V 05.50, 20-09-06, RM-115, (c) Nokia. ,
PSN MFJ192541
Product Code 0535211
Module Code 0202802
Basic Product Code 0526012
PSD 0000001D00000000
RETU 32
TAHVO 52
AHNE 11
HW 4007
RFIC 17201720
DSP dsp_mojito_05w46v31.1
Simlock Server SIMLOCK SERVER VERSION 63
Simlock Key 2440700000000000
Simlock Profile 8000000000000000
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Processing pre flash tasks...
Backing up certificates...
Booting RAP...
CMT_SYSTEM_ASIC_ID: 000000010000022600010006010C192101001101
CMT_EM_ASIC_ID: 00000232
CMT_EM_ASIC_ID: 00000352
CMT_PUBLIC_ID: 07C00018213B005857ADD51C64E9B9C6F8139544
CMT_ASIC_MODE_ID: 00
CMT_ROOT_KEY_HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
CMT_ROM_ID: 191EC665DFAAF68F
RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5
Flashbus Write baud set to 1.0Mbits
Flashbus Read baud set to 98Kbits
FlashChip[0,CMT]: 0x0001002F00006921, AMD, NOR
FlashContent[0,CMT]: 00000000000000000000000000000000, NOR
FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC
Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit
RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.1.40.0, Algo: BB5 ALGORITHM
Flashbus Write baud set to 4.0Mbits
Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit
Box TX2 Data Pin set to: Service Pin 3
Box VPP disabled
Internal CMT Phone VPP Enabled
PAPUBKEYS Hash for CMT: A8192FC6AD7BF7A1A4419A3953F3856B1F3F7D4A
APE Subsystem Not Found
CMT NPC Ok
CMT HWC Not Found
CMT CCC Not Found
CMT R&D Ok
CMT VARIANT Ok
CMT PAPUBKEYS Ok
CMT KEYS Ok
Restarting MCU...
Read all certificates finished
Certificates backup thread finished, continuing...
Backing up simlock...
Starting PM read in range 308-308...
[308] Reading 8 records
[308,0] Reading 1 bytes
[308,1] Reading 8192 bytes
[308,3] Reading 1 bytes
[308,4] Reading 1 bytes
[308,6] Reading 1 bytes
[308,7] Reading 1 bytes
[308,8] Reading 1 bytes
[308,9] Reading 40 bytes
PM Read OK, Time taken 1.969s
Simlock backup OK
Backup simlock thread finished, continuing...
Pre flash tasks finished, continuing...
Processing rm115__06.60.mcusw (CMT)...
Booting RAP...
rm115__06.60.mcusw, Type: Flash Image, Algo: BB5, BB5 ALGORITHM
Flashbus Write baud set to 3.25Mbits
Box VPP disabled
Started group flash erase
EraseArea[0,CMT]: 0x00000000-0x000006BF, NOR
EraseArea[0,CMT]: 0x000006C0-0x0001FFFF, NOR
EraseArea[0,CMT]: 0x00020000-0x0007FFFF, NOR
EraseArea[0,CMT]: 0x00080000-0x000DFFFF, NOR
EraseArea[0,CMT]: 0x00100000-0x001FFFFF, NOR
EraseArea[0,CMT]: 0x00200000-0x002DFFFF, NOR
EraseArea[0,CMT]: 0x002E0000-0x00EDFFFF, NOR
EraseArea[0,CMT]: 0x00EE0000-0x00EF7FFF, NOR
EraseArea[0,CMT]: 0x00EF8000-0x00EFFFFF, NOR
Waiting 320s for erasure finish...
Erase taken 57.406s
Writing all blocks...
Writing CMT NOLO Certificate...
Writing CMT KEYS Certificate...
Writing CMT PRIMAPP Certificate...
Writing CMT PASUBTOC Certificate...
Writing CMT PAPUBKEYS Certificate...
Writing CMT UPDAPP Certificate...
Writing CMT DSP0 Certificate...
Writing CMT MCUSW Certificate...
Writing CMT PMM_CONF Certificate...
Writing CMT SBIF_CONF Certificate...
Programming Status OK!
All blocks written OK! Time taken 66.969s
Restarting MCU...
Processing rm115__06.60.mcusw (APE)...
Processing rm115__06.60.ppm_t (CMT)...
Booting RAP...
rm115__06.60.ppm_t, Type: Flash Image, Algo: BB5, BB5 ALGORITHM
Box VPP disabled
EraseArea[0,CMT]: 0x00F00000-0x0145FFFF, NOR
Erase taken 23.406s
All blocks written OK! Time taken 24.516s
Restarting MCU...
Processing rm115__06.60.ppm_t (APE)...
Processing rm115__06.60.image_tw_128 (CMT)...
Booting RAP...
rm115__06.60.image_tw_128, Type: Flash Image, Algo: BB5, BB5 ALGORITHM
Box VPP disabled
EraseArea[0,CMT]: 0x01460000-0x01FDFFFF, NOR
Erase taken 53.781s
All blocks written OK! Time taken 31.734s
Restarting MCU...
Processing rm115__06.60.image_tw_128 (APE)...
All images processed OK! Processing post flash tasks...
Setting Factory Defaults...
Factory defaults OK
Reading info...
MCU Version V 06.60
MCU Date 30-07-07
Product RM-115
IMEI SV 3395730430227008F8000000
PPM V 06.60, 30-07-07, RM-115, (c) Nokia. , T
CNT Content: tw, V 06.60, 30-07-07, RM-115, (c) Nokia. ,
PSN MFJ192541
Module Code 0202802
RETU 32
TAHVO 52
AHNE 11
HW 4007
RFIC 17201720
DSP dsp_mojito_05w46v50.1
Simlock Key Cnt 0
Simlock FBUS Cnt 0
Read info thread finished, continuing...
Post flash tasks finished!
Flashing successfully finished!
The Following 4 Users Say Thank You to vanhue For This Useful Post:
Old 04-01-2009, 17:35   #2 (permalink)
NADEEM GONDAL's Avatar
Member: 575900
Thanks Meter: 3,177
thanks for good test report.
Old 04-01-2009, 18:53   #3 (permalink)
Member: 501129
Thanks Meter: 63
device new Cyclonebox as good than device other?thank for test model report
5730 Successfully flash with Cyclone invisible990200 Cyclonebox 2 10-11-2009 22:29
N95 rm159 flash with cyclone.... dghersin Cyclonebox 1 07-24-2009 18:28
help me 6131 flash with dku2 saeid_gsm Universalbox 0 04-17-2007 07:25
Page generated in 0.18499 seconds with 9 queries
