03-27-2010, 00:31 | #1 (permalink) |
No Life Poster Join Date: Dec 2008 Location: morocco
Member: 931360 Status: Offline Sonork: 100.1592533 Thanks Meter: 539 | 6210n problem camera selftests any idea how to solve this problem Code: Started Phone Security Analysis... MCU Version V 08w17.16 MCU Date 10-09-08 Product RM-367 Manufacturer (c) Nokia IMEI 356788026815381 Mastercode 130131142 Reading Security Block... Security block OK and saved to "RM-367_356788026815381_26-03-2010_222530.SecurityBlock.PM" Step 1 : Testing SIMLOCK -- SECURITY PROBLEM -- Phone have failed SIMLOCK Test, that means Simlock Area is DAMAGED! To repair simlock area, Select Unlock method : "RPL CALCULATION", And then click DIRECT UNLOCK. SL Area will be re-formatted. If security problem still exists - check CCC and HWC Certificates. -- SECURITY PROBLEM -- Step 2 : Testing SECURITY SECURITY SEFLTEST PASSED OK! Step 3 : Analyzing Security Block "1000020A647C00529498647D63FECB63EDECFFF2.C00004BA" Exists, That is good... Checking SUPERDONGLE... SUPERDONGLE FOUND AND CHECKSUM OK! PASSED! Checking SIMLOCK... SIMLOCK FOUND AND CHECKSUM OK! PASSED! Checking MCU&DSP TIMESTAMPS... MCU&DSP TIMESTAMPS FOUND AND CHECKSUM OK! PASSED! Checking CMLA KEYS... CMLA KEYS FOUND AND CHECKSUM OK! PASSED! Checking ECC KEYS... ECC KEYS FOUND AND CHECKSUM OK! PASSED! Checking DIV KEYS... DIV KEYS FOUND AND CHECKSUM OK! PASSED! Analyze finished! Selftests to proceed: 39 Passed ST_TAHVOINT_TEST Passed ST_UEM_CBUS_IF_TEST Passed ST_EAR_DATA_LOOP_TEST Passed ST_SIM_CLK_LOOP_TEST Passed ST_SIM_IO_CTRL_LOOP_TEST Passed ST_SECURITY_TEST Passed ST_PWR_KEY_TEST Passed ST_CURRENT_CONS_TEST Passed ST_BACKUP_BATT_TEST Passed ST_SLEEPCLK_FREQ_TEST Passed ST_HOOKINT_TEST Passed ST_BTEMP_TEST Passed ST_AMB_LIGHT_SENSOR_TEST Passed ST_EXT_DEVICE_TEST Passed ST_CDSP_RF_BB_IF_TEST Passed ST_CDSP_RF_SUPPLY_TEST Passed ST_CDSP_TX_IQ_TEST Passed ST_CDSP_TXC_DATA_TEST Passed ST_CDSP_PWR_DETECTOR_BIAS_TEST Passed ST_CDSP_RX_PLL_PHASE_LOCK_TEST Failed ST_CDSP_TX_PLL_PHASE_LOCK_TEST Passed ST_CDSP_WCDMA_TX_POWER_TEST Passed ST_CDSP_RX_IQ_LOOP_BACK_TEST Passed ST_CDSP_GSM_TX_POWER_TEST Passed ST_KEYBOARD_STUCK_TEST Passed ST_LPRF_IF_TEST Passed ST_CAMERA_IF_TEST Passed ST_CAMERA_ACCELERATOR_TEST Passed ST_SEC_CAMERA_IF_TEST Passed ST_LED_FLASH_TEST Passed ST_CAMERA_AUTOFOCUS_TEST Passed ST_LPRF_AUDIO_LINES_TEST Passed ST_MAIN_LCD_IF_TEST Passed ST_BT_WAKEUP_TEST Passed ST_ACCEL_IF_TEST Passed ST_USB_LOOP_TEST Passed ST_RADIO_TEST Passed ST_IO_EXPANDER_IF_TEST Passed ST_MAGNETOMETER_TEST Selftests done, Tests total: 39, Tests passed: 38, Tests not passed: 1 |
nec 338 problem camera error saving file 01-01-04 | Chawkiz_gsm | NEC | 20 | 02-25-2008 07:00 |
Probleme Camera F300 | bartholomeo | UST Pro II | 3 | 01-13-2008 20:36 |
E900 problem camera | sakka | UST Pro II | 18 | 07-04-2007 07:49 |
Problem camera x820 | helder2 | Samsung Flashers, Software, Firmware. | 5 | 04-04-2007 00:00 |
E700... here we go again.. more problems.. Camera preview error .... | Burnt Cobba | SYSOL Platform | 5 | 03-23-2004 19:46 |
