07-17-2011, 07:39 | #1 (permalink) |
No Life Poster Join Date: Jul 2002 Location: Slovakia Age: 43
Member: 13922 Status: Offline Thanks Meter: 334 | 6303 hang on nokia logo + Failed to read SP info [ Solved ] Code: MCU Version V 10.10 MCU Date 18-11-09 Product RM-443 (Nokia 6303 classic) Manufacturer (c) Nokia IMEI 351541042143568 Mastercode 152745727 IMEI Spare 3A15450124415306 IMEI SV 3315450124415336F8000000 PPM V 10.10, 18-11-09, RM-443, (c) Nokia , D CNT Content: d_cz_chestnut, V 10.10, 18-11-09, RM-443, (c) Nokia , PSN KMJ777877 Product Code 0588174 Module Code 0204282 Basic Product Code 0575069 PSD 0000000000000000 LPSN 0 RETU 16 TAHVO 22 AHNE 30 HW 2002 RFIC 0800 DSP ICPR81_09w37 LCD SEIKO BT 410B-v170 Failed to read info -> Failed to read SP info Selftests to proceed: 30 Passed ST_EAR_DATA_LOOP_TEST Passed ST_SIM_CLK_LOOP_TEST Passed ST_SIM_IO_CTRL_LOOP_TEST Passed ST_SLEEP_X_LOOP_TEST Passed ST_UEM_CBUS_IF_TEST Passed ST_KEYBOARD_STUCK_TEST Failed ST_CAMERA_IF_TEST Failed ST_LCD_TEST Passed ST_LPRF_IF_TEST Passed ST_LPRF_AUDIO_LINES_TEST Passed ST_CURRENT_CONS_TEST Failed ST_RADIO_TEST Passed ST_BACKLIGHT_TEST Failed ST_SIM_LOCK_TEST Passed ST_SECURITY_TEST Failed ST_BT_WAKEUP_TEST Failed ST_HOOKINT_TEST Passed ST_TAHVOINT_TEST Passed ST_BTEMP_TEST Failed ST_AMB_LIGHT_SENSOR_TEST Failed ST_IIC_TEST Passed ST_LED_CONTROLLER_TEST Passed ST_CDSP_SLEEPCLK_FREQ_TEST Passed ST_CDSP_SLEEPCLOCK_FREQ_TEST Passed ST_CDSP_RF_BB_IF_TEST Passed ST_CDSP_GSM_TX_POWER_TEST Passed ST_CDSP_RF_SUPPLY_TEST Passed ST_CDSP_TX_PLL_PHASE_LOCK_TEST Passed ST_CDSP_PWR_DETECTOR_BIAS_TEST Passed ST_CDSP_RX_IQ_TEST Selftests done, Tests total: 30, Tests passed: 22, Tests not passed: 8 http://forum.gsmhosting.com/vbb/f528...-rap4-1290576/ all passed OK, but no improvment Code: Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006030C192101033000 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 132001157F208E56CD56CEAD30D40C7572519EE1 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.42.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0089898200008A31, Intel, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x00898982 (Intel), Size: 64MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: E8E6E2AB6C2D394BC82633D2B4965E7E519E2FB2 APE Boot skipped on user request Flashbus Write baud set to 5.0Mbits Restarting MCU... RPL Creation started... Processing CMT Part... Storing Product Code... Storing PSN... Storing HWID... Trying to store Simlock... Reading Configuration Key... Hashing... Reading SHA1-RSA Signature... Reading SHA1-HMAC Signature... Storing Simlock... Trying to store WMDRM RPL... Reading Keys... Storing WMDRM PD... Reading Security Block... Security block OK and saved to "RM-443_351541042143568_7172011_75545 AM.SecurityBlock.PM" WARNING: "132001157F208E56CD56CEAD30D40C7572519EE1.C000087F" Not Exists, Will read it... Reading CYC file from phone... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006030C192101033000 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 132001157F208E56CD56CEAD30D40C7572519EE1 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.1.30.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL Exploiting - running preloader... Preloader running OK, Running Custom Loader... Custom loader running OK! Working... Old Loader Detected Readed OK, Saving to "132001157F208E56CD56CEAD30D40C7572519EE1.C000087F" Storing Additional Data... Checking Superdongle Key... Encrypting Superdongle Key... Storing Superdongle Key... Checking CMLA Key... Storing CMLA Key... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006030C192101033000 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 132001157F208E56CD56CEAD30D40C7572519EE1 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.42.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0089898200008A31, Intel, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x00898982 (Intel), Size: 64MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: E8E6E2AB6C2D394BC82633D2B4965E7E519E2FB2 APE Subsystem Not Found Flashbus Write baud set to 5.0Mbits Storing NPC... Storing CCC... Storing HWC... CMT VARIANT Not Found Restarting MCU... RPL Saved OK Starting PM read in range 0-512... Failed to read PM -> Failed to get PM Key 0 Length MCU Version V 10.10 MCU Date 18-11-09 Product RM-443 (Nokia 6303 classic) Manufacturer (c) Nokia IMEI 351541042143568 Mastercode 152745727 IMEI Spare 3A15450124415306 IMEI SV 3315450124415336F8000000 PPM V 10.10, 18-11-09, RM-443, (c) Nokia , D CNT Content: d_cz_matt_black, V 10.10, 18-11-09, RM-443, (c) Nokia , PSN KMJ777877 Product Code 0588174 Module Code 0204282 Basic Product Code 0575069 PSD 0000000000000000 LPSN 0 RETU 16 TAHVO 22 AHNE 30 HW 2002 RFIC 0800 DSP ICPR81_09w37 LCD SEIKO Failed to read info -> Failed to read SP info Starting PM read in range 0-512... [1] Reading 12 records [1,0] Reading 48 bytes [1,2] Reading 86 bytes [1,4] Reading 48 bytes [1,6] Reading 86 bytes [1,8] Reading 48 bytes [1,11] Reading 12 bytes [1,12] Reading 24 bytes [1,13] Reading 86 bytes [1,16] Reading 24 bytes [1,18] Reading 24 bytes [1,21] Reading 24 bytes [1,29] Reading 4 bytes [4] Reading 9 records [4,1] Reading 800 bytes [4,3] Reading 10 bytes [4,4] Reading 8 bytes [4,5] Reading 8 bytes [4,6] Reading 8 bytes [4,9] Reading 5 bytes [4,18] Reading 80 bytes [4,19] Reading 4 bytes [4,28] Reading 2 bytes [8] Reading 10 records [8,0] Reading 2 bytes [8,1] Reading 16 bytes [8,2] Reading 16 bytes [8,3] Reading 128 bytes [8,4] Reading 128 bytes [8,8] Reading 8 bytes [8,9] Reading 8 bytes [8,10] Reading 32 bytes [8,11] Reading 4 bytes [8,12] Reading 4 bytes [11] Reading 69 records [11,0] Reading 4 bytes [11,1] Reading 4 bytes [11,2] Reading 4 bytes [11,3] Reading 4 bytes [11,4] Reading 1 bytes [11,5] Reading 6 bytes [11,6] Reading 2 bytes [11,7] Reading 1 bytes [11,8] Reading 1 bytes [11,9] Reading 1 bytes [11,10] Reading 2 bytes [11,11] Reading 2 bytes [11,12] Reading 2 bytes [11,13] Reading 2 bytes [11,14] Reading 16 bytes [11,15] Reading 32 bytes [11,16] Reading 32 bytes [11,17] Reading 2 bytes [11,18] Reading 2 bytes [11,19] Reading 2 bytes [11,20] Reading 2 bytes [11,21] Reading 2 bytes [11,22] Reading 2 bytes [11,23] Reading 2 bytes [11,24] Reading 2 bytes [11,25] Reading 2 bytes [11,26] Reading 2 bytes [11,27] Reading 2 bytes [11,28] Reading 2 bytes [11,29] Reading 2 bytes [11,30] Reading 2 bytes [11,31] Reading 2 bytes [11,32] Reading 2 bytes [11,33] Reading 2 bytes [11,34] Reading 2 bytes [11,35] Reading 2 bytes [11,36] Reading 2 bytes [11,37] Reading 2 bytes [11,38] Reading 2 bytes [11,39] Reading 2 bytes [11,40] Reading 2 bytes [11,41] Reading 2 bytes [11,42] Reading 2 bytes [11,43] Reading 2 bytes [11,44] Reading 2 bytes [11,45] Reading 2 bytes [11,46] Reading 2 bytes [11,47] Reading 2 bytes [11,48] Reading 2 bytes [11,49] Reading 2 bytes [11,50] Reading 2 bytes [11,51] Reading 2 bytes [11,52] Reading 2 bytes [11,53] Reading 2 bytes [11,54] Reading 2 bytes [11,55] Reading 2 bytes [11,56] Reading 2 bytes [11,57] Reading 2 bytes [11,58] Reading 2 bytes [11,59] Reading 2 bytes [11,60] Reading 2 bytes [11,61] Reading 2 bytes [11,62] Reading 4 bytes [11,63] Reading 4 bytes [11,64] Reading 4 bytes [11,65] Reading 4 bytes [11,66] Reading 16 bytes [11,67] Reading 4 bytes [11,68] Reading 2 bytes [31] Reading 1 records [31,4] Reading 14 bytes [54] Reading 1 records [54,0] Reading 2 bytes [88] Reading 1 records [88,0] Reading 36 bytes [96] Reading 1 records [96,0] Reading 2 bytes [120] Reading 4 records [120,0] Reading 56 bytes [120,1] Reading 160 bytes [120,2] Reading 130 bytes [120,3] Reading 112 bytes [193] Reading 4 records [193,2] Reading 8 bytes [193,3] Reading 32 bytes [193,4] Reading 32 bytes [193,9] Reading 64 bytes [218] Reading 1 records [218,0] Reading 2 bytes [308] Reading 9 records [308,0] Reading 1 bytes [308,1] Reading 8192 bytes [308,3] Reading 1 bytes [308,4] Reading 1 bytes [308,5] Reading 10 bytes [308,6] Reading 1 bytes [308,7] Reading 1 bytes [308,8] Reading 1 bytes [308,9] Reading 40 bytes [309] Reading 6 records [309,0] Reading 4 bytes [309,1] Reading 2 bytes [309,2] Reading 12 bytes [309,4] Reading 12 bytes [309,7] Reading 12 bytes [309,17] Reading 12 bytes [322] Reading 1 records [322,0] Reading 1 bytes [341] Reading 3 records [341,0] Reading 1 bytes [341,3] Reading 4 bytes [341,4] Reading 4408 bytes [354] Reading 1 records [354,0] Reading 3 bytes [356] Reading 2 records [356,0] Reading 2 bytes [356,1] Reading 8 bytes [362] Reading 2 records [362,0] Reading 1 bytes [362,1] Reading 120 bytes PM Read OK, Time taken 9.469s Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006030C192101033000 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 132001157F208E56CD56CEAD30D40C7572519EE1 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.42.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0089898200008A31, Intel, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x00898982 (Intel), Size: 64MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: E8E6E2AB6C2D394BC82633D2B4965E7E519E2FB2 APE Subsystem Not Found Flashbus Write baud set to 5.0Mbits Erasing flash chip... Started group flash erase EraseArea[0,CMT]: 0x00000000-0x03FFFFFF, NOR Waiting 640s for erasure finish... Erase taken 264.844s Restarting MCU... BB5 Full Erase Finished! Processing pre flash tasks... Pre flash tasks finished, continuing... Processing rm443__10.10.mcusw (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006030C192101033000 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 132001157F208E56CD56CEAD30D40C7572519EE1 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! rm443__10.10.mcusw, Type: Flash Image, Algo: BB5, BB5 ALGORITHM Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.42.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0089898200008A31, Intel, NOR FlashContent[0,CMT]: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x00898982 (Intel), Size: 64MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled Warning: PAPUBKEYS Hash Missing! Flashbus Write baud set to 5.0Mbits Sending Certificates... Certificates OK Started group flash erase EraseArea[0,CMT]: 0x00000000-0x0001FFFF, NOR EraseArea[0,CMT]: 0x00040000-0x0005FFFF, NOR EraseArea[0,CMT]: 0x00060000-0x0007FFFF, NOR EraseArea[0,CMT]: 0x00080000-0x0015FFFF, NOR EraseArea[0,CMT]: 0x00160000-0x0023FFFF, NOR EraseArea[0,CMT]: 0x01740000-0x0191FFFF, NOR EraseArea[0,CMT]: 0x00240000-0x0173FFFF, NOR EraseArea[0,CMT]: 0x022E0000-0x0261FFFF, NOR Waiting 320s for erasure finish... Erase taken 0.282s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT NOLO Certificate... Writing CMT KEYS Certificate... Writing CMT PRIMAPP Certificate... Writing CMT PASUBTOC Certificate... WARNING: CMT PAPUBKEYS Hash is Empty, writing first found PAPUBKEYS Writing CMT PAPUBKEYS Certificate... Writing CMT UPDAPP Certificate... Writing CMT DSP0 Certificate... Writing CMT MCUSW Certificate... Writing CMT ISA+DYNSW Certificate... Programming Status OK! All blocks written OK! Time taken 71.859s Flashing Speed: 2880.23 kBit/S Restarting MCU... Processing rm443__10.10.mcusw (APE)... Processing rm443__10.10.ppm_d (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006030C192101033000 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 132001157F208E56CD56CEAD30D40C7572519EE1 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! rm443__10.10.ppm_d, Type: Flash Image, Algo: BB5, BB5 ALGORITHM Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.42.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0089898200008A31, Intel, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x00898982 (Intel), Size: 64MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: E8E6E2AB6C2D394BC82633D2B4965E7E519E2FB2 Flashbus Write baud set to 5.0Mbits Started group flash erase EraseArea[0,CMT]: 0x01920000-0x022DFFFF, NOR Waiting 320s for erasure finish... Erase taken 0.93s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Programming Status OK! All blocks written OK! Time taken 16.360s Flashing Speed: 3525.08 kBit/S Restarting MCU... Processing rm443__10.10.ppm_d (APE)... Processing rm443__10.10.image_d_cz_chestnut (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006030C192101033000 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 132001157F208E56CD56CEAD30D40C7572519EE1 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! rm443__10.10.image_d_cz_chestnut, Type: Flash Image, Algo: BB5, BB5 ALGORITHM Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.42.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0089898200008A31, Intel, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x00898982 (Intel), Size: 64MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: E8E6E2AB6C2D394BC82633D2B4965E7E519E2FB2 Flashbus Write baud set to 5.0Mbits Started group flash erase EraseArea[0,CMT]: 0x02620000-0x029BFFFF, NOR EraseArea[0,CMT]: 0x029C0000-0x03FBFFFF, NOR Waiting 320s for erasure finish... Erase taken 0.235s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Programming Status OK! All blocks written OK! Time taken 24.312s Flashing Speed: 3584.01 kBit/S Restarting MCU... Processing rm443__10.10.image_d_cz_chestnut (APE)... All images processed OK! Processing post flash tasks... Post flash tasks finished! Flashing successfully finished! MCU Version V 10.10 MCU Date 18-11-09 Product RM-443 (Nokia 6303 classic) Manufacturer (c) Nokia IMEI 12345610654321? IMEI Spare 1A32541660452301 IMEI SV 1332541660452331F8000000 PPM V 10.10, 18-11-09, RM-443, (c) Nokia , D CNT Content: d_cz_chestnut, V 10.10, 18-11-09, RM-443, (c) Nokia , PSN 0 PSD 0000000000000000 LPSN 0 RETU 16 TAHVO 22 AHNE 30 RFIC 0800 DSP ICPR81_09w37 LCD SEIKO BT 410B-v170 Failed to read info -> Failed to read SP info Skipping RPL decryption... Parsing decrypted RPL... Processing FBUS Part... Writing Product Code... Writing PSN... Writing HWID... Writing Simlock... Handling as SL3 Simlock Data Reading Security Block... Security block OK and saved to "RM-443_12345610654321_7172011_83031 AM.SecurityBlock.PM" Simlock ACCEPTED OK ! Writing Superdongle key... Superdongle Key ACCEPTED OK ! Writing CMLA key... CMLA Key ACCEPTED OK ! Writing WMDRM PD Data... WMDRM PD Data ACCEPTED OK ! Processing FLASHBUS Part... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006030C192101033000 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 132001157F208E56CD56CEAD30D40C7572519EE1 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.42.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0089898200008A31, Intel, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x00898982 (Intel), Size: 64MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: E8E6E2AB6C2D394BC82633D2B4965E7E519E2FB2 APE Subsystem Not Found Flashbus Write baud set to 5.0Mbits CMT NPC Erased WARNING: Certificate not accepted, Probably TX2 Problem (check Adapter/Cable!) CMT HWC Erased WARNING: Certificate not accepted, Probably TX2 Problem (check Adapter/Cable!) CMT CCC Erased WARNING: Certificate not accepted, Probably TX2 Problem (check Adapter/Cable!) Restarting MCU... Write RPL Finished! Skipping RPL decryption... Parsing decrypted RPL... Processing FBUS Part... Writing Product Code... Writing PSN... Writing HWID... Writing Simlock... Handling as SL3 Simlock Data Reading Security Block... Security block OK and saved to "RM-443_12345610654321_7172011_83152 AM.SecurityBlock.PM" Simlock ACCEPTED OK ! Writing Superdongle key... Superdongle Key ACCEPTED OK ! Writing CMLA key... CMLA Key ACCEPTED OK ! Writing WMDRM PD Data... WMDRM PD Data ACCEPTED OK ! Processing FLASHBUS Part... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000010000022600010006030C192101033000 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 132001157F208E56CD56CEAD30D40C7572519EE1 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT_BOOT_ROM_CRC: 273F6D55 CMT_SECURE_ROM_CRC: DFAAF68F CMT Ready! Searching for BootCode: DualLine 32Bit RAP3Gv3_2nd.fg, Type: 2nd Boot Loader, Rev: 0.10.42.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using OLD BB5 FLASHING PROTOCOL If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0089898200008A31, Intel, NOR FlashContent[0,CMT]: 00000000000000000000000000000000, NOR FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC Transmission Mode Requested: Single Line, 8 bit, Accepted: Single Line, 8 bit Searching for BootCode: DualLine 32Bit FlashChip 0x00898982 (Intel), Size: 64MBytes, VPP: 9V RAP3Gv3_algo.fg, Type: Algorithm, Rev: 0.10.40.0, Algo: BB5 ALGORITHM Flashbus Write baud set to 2.0Mbits Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: E8E6E2AB6C2D394BC82633D2B4965E7E519E2FB2 APE Subsystem Not Found Flashbus Write baud set to 5.0Mbits CMT NPC Erased CMT NPC Written CMT HWC Erased CMT HWC Written CMT CCC Erased CMT CCC Written Restarting MCU... Write RPL Finished! MCU Version V 10.10 MCU Date 18-11-09 Product RM-443 (Nokia 6303 classic) Manufacturer (c) Nokia IMEI 351541042143568 Mastercode 152745727 IMEI Spare 3A15450124415306 IMEI SV 3315450124415336F8000000 PPM V 10.10, 18-11-09, RM-443, (c) Nokia , D CNT Content: d_cz_chestnut, V 10.10, 18-11-09, RM-443, (c) Nokia , PSN KMJ777877 Product Code 0588174 PSD 0000000000000000 LPSN 0 RETU 16 TAHVO 22 AHNE 30 HW 2002 RFIC 0800 DSP ICPR81_09w37 LCD SEIKO BT 410B-v170 Failed to read info -> Failed to read SP info SX4 Authorization / SD Repair Procedure Started.... Failed to obtain Phone Unique Data, Will use Server and Original Card MCU Version V 10.10 MCU Date 18-11-09 Product RM-443 (Nokia 6303 classic) Manufacturer (c) Nokia IMEI 351541042143568 Mastercode 152745727 SX4 Status: Not authorized (74) Started mutual authenthication with card... Cyclone Server (1.0.0.667), Cyclone Box Team 2008-2011 - Ready. Receiving Phone Seed 1... Phone Seed 1 Received Sending calculated Data 1, and expecting Seed 2... Calculated Data 1 accepted, Phone Seed 2 Received Sending calculated Data 2 Calculated Data 2 sent, Checking Authorization Status again Authorization successfully finished! Looking for Virgin PM In Database... Found, writing... [1,0] Written, Length: 48 bytes, Status: OK [1,2] Written, Length: 86 bytes, Status: OK [1,4] Written, Length: 48 bytes, Status: OK [1,6] Written, Length: 86 bytes, Status: OK [1,8] Written, Length: 48 bytes, Status: OK [1,11] Written, Length: 12 bytes, Status: OK [1,12] Written, Length: 24 bytes, Status: OK [1,13] Written, Length: 86 bytes, Status: OK [1,16] Written, Length: 24 bytes, Status: OK [1,18] Written, Length: 24 bytes, Status: OK [1,21] Written, Length: 24 bytes, Status: OK [1,29] Written, Length: 4 bytes, Status: OK [309,0] Written, Length: 4 bytes, Status: OK [309,1] Written, Length: 2 bytes, Status: OK [309,2] Written, Length: 12 bytes, Status: OK [309,4] Written, Length: 12 bytes, Status: OK [309,7] Written, Length: 12 bytes, Status: OK [309,17] Written, Length: 12 bytes, Status: OK Write PM Finished, Record written OK: 18, Record written NOT OK: 0 Disconnected from Cyclone Server MCU Version V 10.10 MCU Date 18-11-09 Product RM-443 (Nokia 6303 classic) Manufacturer (c) Nokia IMEI 351541042143568 Mastercode 152745727 IMEI Spare 3A15450124415306 IMEI SV 3315450124415336F8000000 PPM V 10.10, 18-11-09, RM-443, (c) Nokia , D CNT Content: d_cz_chestnut, V 10.10, 18-11-09, RM-443, (c) Nokia , PSN KMJ777877 Product Code 0588174 PSD 0000000000000000 LPSN 0 RETU 16 TAHVO 22 AHNE 30 HW 2002 RFIC 0800 DSP ICPR81_09w37 LCD SEIKO BT 410B-v170 Failed to read info -> Failed to read SP info [1,0] Written, Length: 48 bytes, Status: OK [1,2] Written, Length: 86 bytes, Status: OK [1,4] Written, Length: 48 bytes, Status: OK [1,6] Written, Length: 86 bytes, Status: OK [1,8] Written, Length: 48 bytes, Status: OK [1,11] Written, Length: 12 bytes, Status: OK [1,12] Written, Length: 24 bytes, Status: OK [1,13] Written, Length: 86 bytes, Status: OK [1,16] Written, Length: 24 bytes, Status: OK [1,18] Written, Length: 24 bytes, Status: OK [1,21] Written, Length: 24 bytes, Status: OK [1,29] Written, Length: 4 bytes, Status: OK [4,1] Written, Length: 800 bytes, Status: OK [4,3] Written, Length: 10 bytes, Status: OK [4,4] Written, Length: 8 bytes, Status: OK [4,5] Written, Length: 8 bytes, Status: OK [4,6] Written, Length: 8 bytes, Status: OK [4,9] Written, Length: 5 bytes, Status: OK [4,18] Written, Length: 80 bytes, Status: OK [4,19] Written, Length: 4 bytes, Status: OK [4,28] Written, Length: 2 bytes, Status: OK [8,0] Written, Length: 2 bytes, Status: OK [8,1] Written, Length: 16 bytes, Status: OK [8,2] Written, Length: 16 bytes, Status: OK [8,3] Written, Length: 128 bytes, Status: OK [8,4] Written, Length: 128 bytes, Status: OK [8,8] Written, Length: 8 bytes, Status: OK [8,9] Written, Length: 8 bytes, Status: OK [8,10] Written, Length: 32 bytes, Status: OK [8,11] Written, Length: 4 bytes, Status: OK [8,12] Written, Length: 4 bytes, Status: OK [11,0] Written, Length: 4 bytes, Status: OK [11,1] Written, Length: 4 bytes, Status: OK [11,2] Written, Length: 4 bytes, Status: OK [11,3] Written, Length: 4 bytes, Status: OK [11,4] Written, Length: 1 bytes, Status: OK [11,5] Written, Length: 6 bytes, Status: OK [11,6] Written, Length: 2 bytes, Status: OK [11,7] Written, Length: 1 bytes, Status: OK [11,8] Written, Length: 1 bytes, Status: OK [11,9] Written, Length: 1 bytes, Status: OK [11,10] Written, Length: 2 bytes, Status: OK [11,11] Written, Length: 2 bytes, Status: OK [11,12] Written, Length: 2 bytes, Status: OK [11,13] Written, Length: 2 bytes, Status: OK [11,14] Written, Length: 16 bytes, Status: OK [11,15] Written, Length: 32 bytes, Status: OK [11,16] Written, Length: 32 bytes, Status: OK [11,17] Written, Length: 2 bytes, Status: OK [11,18] Written, Length: 2 bytes, Status: OK [11,19] Written, Length: 2 bytes, Status: OK [11,20] Written, Length: 2 bytes, Status: OK [11,21] Written, Length: 2 bytes, Status: OK [11,22] Written, Length: 2 bytes, Status: OK [11,23] Written, Length: 2 bytes, Status: OK [11,24] Written, Length: 2 bytes, Status: OK [11,25] Written, Length: 2 bytes, Status: OK [11,26] Written, Length: 2 bytes, Status: OK [11,27] Written, Length: 2 bytes, Status: OK [11,28] Written, Length: 2 bytes, Status: OK [11,29] Written, Length: 2 bytes, Status: OK [11,30] Written, Length: 2 bytes, Status: OK [11,31] Written, Length: 2 bytes, Status: OK [11,32] Written, Length: 2 bytes, Status: OK [11,33] Written, Length: 2 bytes, Status: OK [11,34] Written, Length: 2 bytes, Status: OK [11,35] Written, Length: 2 bytes, Status: OK [11,36] Written, Length: 2 bytes, Status: OK [11,37] Written, Length: 2 bytes, Status: OK [11,38] Written, Length: 2 bytes, Status: OK [11,39] Written, Length: 2 bytes, Status: OK [11,40] Written, Length: 2 bytes, Status: OK [11,41] Written, Length: 2 bytes, Status: OK [11,42] Written, Length: 2 bytes, Status: OK [11,43] Written, Length: 2 bytes, Status: OK [11,44] Written, Length: 2 bytes, Status: OK [11,45] Written, Length: 2 bytes, Status: OK [11,46] Written, Length: 2 bytes, Status: OK [11,47] Written, Length: 2 bytes, Status: OK [11,48] Written, Length: 2 bytes, Status: OK [11,49] Written, Length: 2 bytes, Status: OK [11,50] Written, Length: 2 bytes, Status: OK [11,51] Written, Length: 2 bytes, Status: OK [11,52] Written, Length: 2 bytes, Status: OK [11,53] Written, Length: 2 bytes, Status: OK [11,54] Written, Length: 2 bytes, Status: OK [11,55] Written, Length: 2 bytes, Status: OK [11,56] Written, Length: 2 bytes, Status: OK [11,57] Written, Length: 2 bytes, Status: OK [11,58] Written, Length: 2 bytes, Status: OK [11,59] Written, Length: 2 bytes, Status: OK [11,60] Written, Length: 2 bytes, Status: OK [11,61] Written, Length: 2 bytes, Status: OK [11,62] Written, Length: 4 bytes, Status: OK [11,63] Written, Length: 4 bytes, Status: OK [11,64] Written, Length: 4 bytes, Status: OK [11,65] Written, Length: 4 bytes, Status: OK [11,66] Written, Length: 16 bytes, Status: OK [11,67] Written, Length: 4 bytes, Status: OK [11,68] Written, Length: 2 bytes, Status: OK [31,4] Written, Length: 14 bytes, Status: OK [54,0] Written, Length: 2 bytes, Status: OK [88,0] Written, Length: 36 bytes, Status: OK [96,0] Written, Length: 2 bytes, Status: OK [120,0] Written, Length: 56 bytes, Status: OK [120,1] Written, Length: 160 bytes, Status: OK [120,2] Written, Length: 130 bytes, Status: OK [120,3] Written, Length: 112 bytes, Status: OK [193,2] Written, Length: 8 bytes, Status: OK [193,3] Written, Length: 32 bytes, Status: OK [193,4] Written, Length: 32 bytes, Status: OK [193,9] Written, Length: 64 bytes, Status: OK [218,0] Written, Length: 2 bytes, Status: OK [308,0] Written, Length: 1 bytes, Status: Not accepted, Code: 19 [308,1] Written, Length: 8192 bytes, Status: Not accepted, Code: 19 [308,3] Written, Length: 1 bytes, Status: Not accepted, Code: 19 [308,4] Written, Length: 1 bytes, Status: Not accepted, Code: 19 [308,5] Written, Length: 10 bytes, Status: Not accepted, Code: 19 [308,6] Written, Length: 1 bytes, Status: Not accepted, Code: 19 [308,7] Written, Length: 1 bytes, Status: Not accepted, Code: 19 [308,8] Written, Length: 1 bytes, Status: Not accepted, Code: 19 [308,9] Written, Length: 40 bytes, Status: Not accepted, Code: 19 [309,0] Written, Length: 4 bytes, Status: OK [309,1] Written, Length: 2 bytes, Status: OK [309,2] Written, Length: 12 bytes, Status: OK [309,4] Written, Length: 12 bytes, Status: OK [309,7] Written, Length: 12 bytes, Status: OK [309,17] Written, Length: 12 bytes, Status: OK [322,0] Written, Length: 1 bytes, Status: OK [341,0] Written, Length: 1 bytes, Status: OK [341,3] Written, Length: 4 bytes, Status: OK [341,4] Written, Length: 4408 bytes, Status: OK [354,0] Written, Length: 3 bytes, Status: OK [356,0] Written, Length: 2 bytes, Status: OK [356,1] Written, Length: 8 bytes, Status: OK [362,0] Written, Length: 1 bytes, Status: OK [362,1] Written, Length: 120 bytes, Status: OK Write PM Finished, Record written OK: 128, Record written NOT OK: 9 MCU Version V 10.10 MCU Date 18-11-09 Product RM-443 (Nokia 6303 classic) Manufacturer (c) Nokia IMEI 351541042143568 Mastercode 152745727 IMEI Spare 3A15450124415306 IMEI SV 3315450124415336F8000000 PPM V 10.10, 18-11-09, RM-443, (c) Nokia , D CNT Content: d_cz_chestnut, V 10.10, 18-11-09, RM-443, (c) Nokia , PSN KMJ777877 Product Code 0588174 Module Code 0204282 Basic Product Code 0575069 PSD 0000000000000000 LPSN 0 RETU 16 TAHVO 22 AHNE 30 HW 2002 RFIC 0800 DSP ICPR81_09w37 LCD SEIKO BT 410B-v170 Failed to read info -> Failed to read SP info Last edited by ptt; 07-17-2011 at 16:01. Reason: add CODE tag |
