05-20-2013, 18:54 | #1 (permalink) |
No Life Poster Join Date: Jan 2008 Location: Hell
Member: 679176 Status: Offline Sonork: 1585224 Thanks Meter: 119 | 6700c contact service after i write original PM For understood the problem its necessary the tell the phone story. The phone come to service with signal problem.i tryed to make a hardwar repair, after that i observe liquid to the mainboard. I put the pcb in the ultrasonic cleaner, after this operation i try to power on the phone but the set vibrate and start with NOKIA logo, and than go off. I try to writte full flash but first off all i read full pm, because it was necessary to extract the phone numbers. I writte full flah and the phone power on., I writte pm that i read but set go to contact service. I need to have phone number more important that the phone to be a live Best regards Read info log: MCU Version V 13.21 MCU Date 12-01-11 Product RM-470 (Nokia 6700 classic) Manufacturer (c) Nokia IMEI 351525043557199 Mastercode 7310667750 IMEI Spare 3A15250534551709 IMEI SV 3315250534551749F9000000 PPM V 13.21, 12-01-11, RM-470, (c) Nokia , C CNT Content: ctv DE, V 13.21, 12-01-11, RM-470, (c) Nokia PSN KQB693731 Product Code 0583454 Module Code 0203926 Basic Product Code 0565911 PSD 0000000000000000 LPSN 0 RETU 34 TAHVO 00 AHNE 11 HW 1000 RFIC |Vapaus_0.0 | Aura_?.? DSP ICPR81_10w09 LCD TPO BT 410B-v190 Failed to read info -> Failed to read SP info Analisy security log: Started Phone Security Analysis... MCU Version V 13.21 MCU Date 12-01-11 Product RM-470 (Nokia 6700 classic) Manufacturer (c) Nokia IMEI 351525043557199 Mastercode 7310667750 Reading Security Block... Security block OK and saved to "RM-470_351525043557199_5172013_104540 AM.SecurityBlock.PM" Step 1 : Testing SIMLOCK -- SIMLOCK PROBLEM -- Phone have failed SIMLOCK Test, that means Simlock Area is DAMAGED! To repair simlock area, Select Unlock method : "RPL CALCULATION", And then click DIRECT UNLOCK. SL Area will be re-formatted. -- SIMLOCK PROBLEM -- Step 2 : Testing SECURITY SECURITY SEFLTEST PASSED OK! Step 3 : Analyzing Security Block "2190010ED96C0344A279B958E3F54FD33356F7EC.C0001E39 " Exists, That is good... Checking SUPERDONGLE... SUPERDONGLE FOUND AND CHECKSUM OK! PASSED! Checking SIMLOCK... Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?) Checking MCU&DSP TIMESTAMPS... MCU&DSP TIMESTAMPS FOUND AND CHECKSUM OK! PASSED! Checking CMLA KEYS... Failed to decode Security Section, Box Reported: Security Section Not Found (SL3 phone?) Checking ECC KEYS... ECC KEYS FOUND AND CHECKSUM OK! PASSED! Checking DIV KEYS... DIV KEYS FOUND AND CHECKSUM OK! PASSED! Analyze finished! |
