Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Cyclonebox
Old 12-08-2009, 07:47   #1 (permalink)
djparadi's Avatar
Member: 4385
BOx VPP Disabled.
Nokia DCT4/WD2/BB5 Service Tool Initialization Started, Engine Revision: 1.0.0.7918
Handling device: [Cyclone Team], [Cyclone Bootloader]
Handling device: [Cyclone Team], [Cyclone Box]
Initializing box...
Box Firmware: Cyclone Nokia Application v01.0C, (Nov 25 2009 03:18:28, gcc v4.3.2, RTOS V6.0.0), Type: Signed Production Application
Box Serial Number: C0001355
HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk14
Initializing security card...
Card Serial Number: D0000958
Card Firmware Revision: 0109
Card is activated
Box is activated
Started box selftests procedure
USB Voltage 5,11v PASSED
MCU Voltage 3,30v PASSED
Core Voltage 1,77v PASSED
VBAT Voltage 0,50v PASSED
VBAT Voltage 5,07v PASSED
Box VPP disabled
VPP Voltage 0,04v PASSED
Internal Box VPP Enabled
VPP Voltage 5,01v PASSED
Box VPP disabled
External Box VPP Enabled
VPP Voltage 0,02v FAILED - IGNORED - Probably power supply is not connected
Box VPP disabled
All box selftests passed!
Super DCT4 Activation: TRUE
Initializing FBUS...
All initialized - Ready to work
Failed to read info -> Phone not detected
Booting UPP...
Failed to Check DCT4 Flashing Bus -> UPP Not Responding
My box is not work! pls help me?
Old 12-08-2009, 08:22   #2 (permalink)
KIKO_GSM's Avatar
Member: 1151970
Sonork: 100.1597000
cyclone porblem............................
Old 12-08-2009, 08:34   #3 (permalink)
djparadi's Avatar
Member: 4385
Since the last update does not do anything! What do you eat to do this? This can be improved?
Old 12-08-2009, 08:41   #4 (permalink)
Super Moderator
moulnisky's Avatar
Member: 947561
The selftest looks OK 100%.. Box VPP disabled part is normal.
have you problem with the BB5 mobiles, the DCT4 or both?
Alex
Old 12-08-2009, 10:36   #5 (permalink)
misterG's Avatar
Member: 249276
Box selftest is ok check your cable and your mobile....
Br,
Mister G
Old 12-08-2009, 11:31   #6 (permalink)
djparadi's Avatar
Member: 4385
Do everything before the last update! The cables are perfect! Another cyclonbox's worked 100%! Each of the two types do not do anything (BB5 or DCT4)
Cyclone BOX VPP what power supply ? alkazeltser Cyclonebox 8 11-23-2009 21:39
cyclone Box....VPP problem? husainm Cyclonebox 1 07-01-2009 19:32
Cyclone Box VPP Adapter .... xiangmdn Cyclonebox 4 05-21-2009 12:48
mt-box vpp pin error mujeep MT-BOX 0 05-21-2008 13:10
WARNING: VPP pin is not connected, disabling VPP. gsaalmeida MT-BOX 4 10-26-2007 07:04
Page generated in 0.28222 seconds with 11 queries
