03-27-2011, 21:34 | #1 (permalink) |
No Life Poster Join Date: Nov 2005 Location: Morocco-Khenifra
Member: 198621 Status: Offline Sonork: 100.1591649 Thanks Meter: 1,083 | C1-00 dead after change language ! [ Solved ] Code: Checking rm689_003.000... Flash file sorted Okay. 1 file(s) embedded into image. Booting X-Gold via ASC (press power-on if used non-battery cable)... X-Gold: Ready, MCU ID: 0x3400 [PBL] : Ready [EBL] : Mode CC [EBL] : Default_RAM_Bootloader [EBL] : Ready Setting Baudrate to 921600bps... Baudrate Accepted (921600bps) Flash Chip 0x002088C0, ST, Size: 8MBytes Certificates Block not found in TOC, Skipping Backup Simlock Block not found in TOC, Skipping Backup Processing "hw_s01_rm689_r03.000.fls"... Sending Certificate... Certificate Accepted Erasing 0x00800000-0x00A0FFFF... Flashing at 0x00800000... Flashed 2162688 bytes OK Erasing 0x00C60000-0x00EAFFFF... Flashing at 0x00C60000... Flashed 2140288 bytes OK Erasing 0x00FFC000-0x00FFFFFF... Flashing at 0x00FFC000... Flashed 64 bytes OK Box VPP disabled Checking rm6890_nai03.00ic... Flash file sorted Okay. 1 file(s) embedded into image. Booting X-Gold via ASC (press power-on if used non-battery cable)... X-Gold: Ready, MCU ID: 0x3400 [PBL] : Ready [EBL] : Mode CC [EBL] : Default_RAM_Bootloader [EBL] : Ready Setting Baudrate to 921600bps... Baudrate Accepted (921600bps) Flash Chip 0x002088C0, ST, Size: 8MBytes Certificates Block not found in TOC, Skipping Backup Simlock Block not found in TOC, Skipping Backup Processing "hw_s01_rm6890_nai03.00ic.fls"... Sending Certificate... Certificate Accepted Erasing 0x00EB0000-0x00F7FFFF... Flashing at 0x00EB0000... Flashed 332736 bytes OK Box VPP disabled Checking rm689_003.00ic... Flash file sorted Okay. 1 file(s) embedded into image. Booting X-Gold via ASC (press power-on if used non-battery cable)... X-Gold: Ready, MCU ID: 0x3400 [PBL] : Ready [EBL] : Mode CC [EBL] : Default_RAM_Bootloader [EBL] : Ready Setting Baudrate to 921600bps... Baudrate Accepted (921600bps) Flash Chip 0x002088C0, ST, Size: 8MBytes Certificates Block not found in TOC, Skipping Backup Simlock Block not found in TOC, Skipping Backup Processing "hw_s01_rm689_003.00ic.fls"... Sending Certificate... Certificate Accepted Erasing 0x00210000-0x0045FFFF... Flashing at 0x00210000... Flashed 2001280 bytes OK Box VPP disabled Processing post-flash tasks... Setting Factory Defaults... Last edited by ptt; 03-28-2011 at 22:21. Reason: add Code Tag |
Working IMEI changed phone? | Barjo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 03-01-2015 11:49 |
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
Change Bin-file in Nokia..possible?? | BiG | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 11-20-1999 16:56 |
ESN Change | OGOMEZ | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 09-21-1999 23:56 |
