06-20-2014, 12:59 | #1 (permalink) |
Freak Poster Join Date: Jun 2008
Member: 801055 Status: Offline Thanks Meter: 20 | c2-01 sl3 unlock problem (log) [ 20 Digits NCK - Cant be unlocked using Brute Force ] CMT_SYSTEM_ASIC_ID: 000000010000022600000001020C192102044100 CMT_EM_ASIC_ID: 00001051 CMT_EM_ASIC_ID: 00001060 CMT_PUBLIC_ID: 19300211A8D410494EDF3520EC3987F73750755B CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 7B045400E1752022F9EB80B0DEA9C65D CMT_BOOT_ROM_CRC: 67E82268 CMT_SECURE_ROM_CRC: F29CEA60 CMT Ready! Searching for BootCode: DualLine 32Bit RAP3Gv40_2nd.fg, Type: 2nd Boot Loader, Rev: 768.12.8.0, Algo: BB5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0000000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC003000000431, Samsung, ONENAND Requested Algorithm: XSR 1.6 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0030 (Samsung), Size: 128MBytes, VPP: Not Supported RAP3Gv40_XSR17_alg.fg, Type: Algorithm, Rev: 768.12.8.0, Algo: XSR 1.6 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 8443ECD57D2EDADDAADBAD248F1B3B559E14D184 APE Boot skipped on user request Flashbus Write baud set to 5.0Mbits Restarting MCU... Reading SL3 LOG File... MCU Version V 11.40 MCU Date 24-10-12 Product RM-721 (Nokia C2-01) Manufacturer (c) Nokia IMEI 357911048992462 Mastercode 3761275632 Analyzing Profile Bits... Phone can be NCK unlocked using KEYPAD Phone can be NCK unlocked using FBUS Failed to Read SL3 LOG File -> 20 Digits NCK Found! have 7 c c2-01 and 3 of them does this.... whats wrong? |
