Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Cyclonebox
Old 04-10-2015, 20:38   #1 (permalink)
kenjatech's Avatar
Member: 1299439
Thanks Meter: 77
C3.00 security code
I've flashed this phone 8 times with eight different firmwares, but the security code does not reset. Can anyone help me?
Processing pre flash tasks...
Pre flash tasks finished, continuing...
Processing rm614__08.65.mcusw (CMT)...
Booting CMT...
[Nokia USB Flashing Generic]: Port opened OK!
New ROM Detected
CMT_SYSTEM_ASIC_ID: 000000000000000022000509200C0000
CMT_EM_ASIC_ID: 00005361
CMT_PUBLIC_ID: 0000000000957B489F09BC04EC4D2CC0BAAB329D
CMT_ASIC_MODE_ID: 00
CMT_ROOT_KEY_HASH: 1B0D74C532CA1C6133940C740E8C786E
CMT_BOOT_ROM_CRC: DE56D582
CMT_SECURE_ROM_CRC: BDDE7A3A
CMT Ready!
rm614__08.65.mcusw, Type: Flash Image, Algo: BB5, XSR 1.6
Searching for BootCode: DualLine 32Bit
BCM21351_usb2nd.fg, Type: 2nd Boot Loader, Rev: 513.12.8.0, Algo: BB5
Using NEW BB5 FLASHING PROTOCOL
Transmission Mode Requested: Control USB, Accepted: Control USB
FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM
FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC
FlashChip[0,CMT]: 0x0020003000000131, ST, NOR
FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR
FlashChip[0,CMT]: 0x0020003000000131, ST, ONENAND
Requested Algorithm: XSR 1.6 (CMT)
FlashChip 0x00200030 (ST), Size: 128MBytes, VPP: Not Supported
BCM21351_XSR16_usbalg.fg, Type: Algorithm, Rev: 513.12.8.0, Algo: XSR 1.6
Initializing TurboCache...
TurboCache Loaded!
Writing CMT PASUBTOC Certificate...
Writing CMT ALG Certificate...
CMT Algorithm Ready!
Transmission Mode Requested: Bulk USB, Accepted: Bulk USB
Box TX2 Data Pin set to: Service Pin 3
Waiting for FUR Client become avaiable...
FUR Avaiable!
Adding FUR Client (CMT, State: Ready)...
CMT FUR Ready!
Overriding VPP Setting, USB can't use VPP
Box VPP disabled
Internal CMT Phone VPP Enabled
PAPUBKEYS Hash for CMT: 697F747788AD72E77DB3BC8DFEC0C28DA22F16D8
Sending Certificates...
Certificates OK
Partitioning...
Partitioning OK
Started group flash erase
EraseArea[0,CMT]: 0x00000000-0x0001FFFF, ONENAND
EraseArea[0,CMT]: 0x00020000-0x000203FF, ONENAND
EraseArea[0,CMT]: 0x00060000-0x012FFFFF, ONENAND
EraseArea[0,CMT]: 0x01300000-0x01DFFFFF, ONENAND
EraseArea[0,CMT]: 0x02600000-0x029FFFFF, ONENAND
Erase Partition (CMT)
Waiting 320s for erasure finish...
Erase taken 0.374s
Writing all blocks...
TurboCache Loaded!
Writing CMT KEYS Certificate...
Writing CMT ADA Certificate...
Writing CMT PRIMAPP Certificate...
Writing CMT RAP3NAND Certificate...
Writing CMT PAPUBKEYS Certificate...
Writing CMT UPDAPP Certificate...
Writing CMT MCUSW Certificate...
Writing CMT MCUSW1 Certificate...
Writing CMT GENIO_INIT Certificate...
Writing CMT ISA+DYNSW Certificate...
Programming Status OK!
All blocks written OK! Time taken 7.145s
Flashing Speed: 32772.74 kBit/S
Processing rm614__08.65.mcusw (APE)...
Processing rm614__08.65.ppm_l (CMT)...
rm614__08.65.ppm_l, Type: Flash Image, Algo: BB5, XSR 1.6
Partitioning...
Partitioning OK
EraseArea[0,CMT]: 0x01E00000-0x025FFFFF, ONENAND
Erase taken 0.63s
TurboCache Loaded!
All blocks written OK! Time taken 1.248s
Flashing Speed: 38109.20 kBit/S
Processing rm614__08.65.ppm_l (APE)...
Processing rm614__08.65_001.image_l_digicel_jm_v2_9k1b2 (CMT)...
rm614__08.65_001.image_l_digicel_jm_v2_9k1b2, Type: Flash Image, Algo: BB5, XSR 1.6
Partitioning...
Partitioning OK
EraseArea[0,CMT]: 0x02A00000-0x0753FFFF, ONENAND
Erase taken 0.968s
TurboCache Loaded!
All blocks written OK! Time taken 3.339s
Flashing Speed: 39052.60 kBit/S
Processing rm614__08.65_001.image_l_digicel_jm_v2_9k1b2 (APE)...
Restarting MCU...
All images processed OK! Processing post flash tasks...
Setting Factory Defaults...
Factory defaults OK
Reading info...
Failed to read info -> Phone not detected
Read info thread finished, continuing...
Post flash tasks finished!
Flashing successfully finished!
Old 04-10-2015, 21:01   #2 (permalink)
irenijus71's Avatar
Member: 1723841
Sonork: N/A
Thanks Meter: 4,165
Booting CMT...
New ROM Detected
CMT Ready!
TurboCache Loaded!
FUR Avaiable!
CMT FUR Ready!
Box VPP disabled
Certificates OK
Partitioning...
Partitioning OK
Erase taken 0.374s
TurboCache Loaded!
Partitioning...
Partitioning OK
Erase taken 0.63s
TurboCache Loaded!
Partitioning...
Partitioning OK
Erase taken 0.968s
TurboCache Loaded!
Restarting MCU...
Factory defaults OK
Reading info...
hi try factory reset or setings after fliashing
Page generated in 0.33463 seconds with 8 queries
