12-01-2011, 12:50 | #1 (permalink) |
No Life Poster Join Date: Feb 2009
Member: 972745 Status: Offline Sonork: 100.1627715 Thanks Meter: 216 | Can't flash anything FlashChip[1]: 0x00EC0035 @ 0x02000000, Samsung, SectorSize: 576kB, Ext: 00000000 Signature: 0000000018F09FE518F09FE518F09FE5 Flashbus Write baud set to 1.0Mbits Flashbus Read baud set to 4Kbits te_essr.fia, Type: Algorithm, Target: FlashChip[1] 0x00EC0035 (256Mbits), Rev: 7.4.76.0, Algo: TIKU EIJA SSR Nominal VPP Voltage: 9V, Detected: 0.04V Flashbus Write baud set to 6.50Mbits Configuring MM Bus... Partitioning MM... Opening MM... Erasing MM... Erase taken 12.328s Writing 328 blocks... All blocks written OK! Time taken 20.94s Box VPP disabled Booting UPP... UPP ID: 1052 [HW_TIKUEDGE_v1_1] Box VPP disabled Processing Flash Image Failed -> Given Image not maches with readen UPP Id or Image problem Failed to Flash -> Problem with processing CNT Image file |
12-01-2011, 13:03 | #3 (permalink) |
Member: 972745 Status: Offline Sonork: 100.1627715 Thanks Meter: 216 | Code: Processing Flash Image Failed -> Given Image not maches with readen UPP Id or Image problem Failed to Flash -> Problem with processing CNT Image file |
12-01-2011, 13:11 | #5 (permalink) |
Member: 972745 Status: Offline Sonork: 100.1627715 Thanks Meter: 216 | Code: UPP ID: 1052 [HW_TIKUEDGE_v1_1] Box VPP disabled Processing Flash Image Failed -> Given Image not maches with readen UPP Id or Image problem Failed to Flash -> Problem with processing MCU Image file Br |
12-01-2011, 13:24 | #6 (permalink) |
Member: 972745 Status: Offline Sonork: 100.1627715 Thanks Meter: 216 | Code: CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-72\rm72_73_110M_03.89.ucp_m1 ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Phone Type: FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-72\rm72_73_110E_03.89v CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-72\rm72_73_110M_03.89.ucp_m1 ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,Vietnamese,Chinese S,Chinese T Backing up PM Field 208 as RPL... Setting local mode... Reading IMEI... Reading IMEI data... Building RPL backup file... C:\Program Files\ODEON\JAF\ProgData\357066006486625_imei_backup_1224112.rpl Done! Backup imei OK! CNT: C:\Program Files\Nokia\Phoenix\Products\RM-72\rm72_73_110M_03.89.ucp_m1 Booting phone... MCU ID: 0x1052 BOOT file: C:\Program Files\ODEON\JAF\Flash\te_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x2398 Boot is ready... FLASH ID0: 22F800EC <=> SAMSUNG (SEC) -> Type not in database Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: 003500EC <=> SAMSUNG (SEC) -> K5E5657ACB Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 9 FLASH ID2: 00010000 <=> Flash -> not used Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 0 FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0 First 16 bytes: 00 00 00 00 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5 Flash ID is 0x22F800EC Flash loader is C:\Program Files\ODEON\JAF\Flash\te_oncsm.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x5648; Loader chk: 3 Loader is ready... Operation took 0 minutes 7 seconds... Erasing Content Pack... Mass Memory Device Detected... MM Bus Configured... Formating MM...Format failed! SET WAS FINE FIRST |
12-01-2011, 14:05 | #8 (permalink) |
Member: 972745 Status: Offline Sonork: 100.1627715 Thanks Meter: 216 | Code: Backing up simlock... MCU Version V 07.10 MCU Date 25-03-10 Product RM-638 (Nokia 6303i classic) Manufacturer (c) Nokia IMEI 354345045665339 Mastercode 30753021 Simlock backup OK, saved to RM-638_354345045665339_01122011_124717.SLBackup.PM Backup simlock thread finished, continuing... Pre flash tasks finished, continuing... Processing rm638__09.83.mcusw (CMT)... Booting CMT... Failed to Boot CMT -> CMT Not Responding, Phone or Cable problem Processing Flash Image Failed -> Failed to Boot CMT Failed to Process all Image files -> Failed to process rm638__09.83.mcusw Processing pre flash tasks... Pre flash tasks finished, continuing... Processing rm638__09.83.mcusw (CMT)... Booting CMT... Failed to Boot CMT -> CMT Not Responding, Phone or Cable problem Processing Flash Image Failed -> Failed to Boot CMT Failed to Process all Image files -> Failed to process rm638__09.83.mcusw Processing pre flash tasks... Pre flash tasks finished, continuing... Processing rm638__09.83.mcusw (CMT)... Booting CMT... Failed to Boot CMT -> CMT Not Responding, Phone or Cable problem Processing Flash Image Failed -> Failed to Boot CMT Failed to Process all Image files -> Failed to process rm638__09.83.mcusw Processing pre flash tasks... Pre flash tasks finished, continuing... Processing rm638__09.83.mcusw (CMT)... Booting CMT... Failed to Boot CMT -> CMT Not Responding, Phone or Cable problem Processing Flash Image Failed -> Failed to Boot CMT Failed to Process all Image files -> Failed to process rm638__09.83.mcusw Processing pre flash tasks... Pre flash tasks finished, continuing... Processing rm638__09.83.mcusw (CMT)... Booting CMT... Failed to Boot CMT -> CMT Not Responding, Phone or Cable problem Processing Flash Image Failed -> Failed to Boot CMT Failed to Process all Image files -> Failed to process rm638__09.83.mcusw 6303ic has also got a issue as well? br shak |
12-01-2011, 14:44 | #9 (permalink) |
No Life Poster Join Date: Feb 2005 Location: Poland Age: 34
Member: 117496 Status: Offline Sonork: 100.83919 Thanks Meter: 22,689 | you get this error because you selected WRONG file. there exists two flash types for 6230i: E and M E for one type of nand flash chips, M for NOR+NAND ( or E for NOR+NAND - don't remember) if your flahing fails just select another variant of PPM and CNT file (those with E/M letter manually) and flashing will go smoothly. about 6303i, its RAP4 based phone. you probably using wrong, non modified cable for RAP3 (6303, not 6303i-c). you can use usb flashing aswell for this phone. |
12-01-2011, 15:38 | #10 (permalink) | |
Member: 972745 Status: Offline Sonork: 100.1627715 Thanks Meter: 216 | Quote:
do i need to purchase special modified cables for cyclone? Br Shak | |
12-03-2011, 15:52 | #11 (permalink) |
Freak Poster Join Date: Jul 2004 Location: Burgas, Bulgaria Age: 55
Member: 75528 Status: Offline Thanks Meter: 5 | I faced this problem some days ago. I flashed 6230 (not "i") and get same error - Given Image not maches with readen UPP Id or Image problem. Ticking skip upp check do not work and has no efect! This is attention to developers of soft. I flashed successfuly same files with JAF, but if i dont have it will be problem. |
12-04-2011, 00:30 | #12 (permalink) |
Member: 972745 Status: Offline Sonork: 100.1627715 Thanks Meter: 216 | Totally agree with peter if Uni - can flash it with the same sw i used i dont understand why cyclone has a issue? Maybe im making mistake somewhere. Im also confused when you say modifyed are the gpg new cables not good enough, and further need modifying? |
need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-16-2019 19:37 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
Anything new on Nokia 5.28? | mona | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 04-29-2000 08:04 |
