06-23-2011, 10:57 | #1 (permalink) |
Freak Poster Join Date: Aug 2009 Location: spain
Member: 1092309 Status: Offline Sonork: 1001606496 Thanks Meter: 52 | code security c7 solution !!! Code: Handling device: [Cyclone Team], [Cyclone Bootloader] Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v01.62, (Jun 5 2011 22:22:07, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2011 Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number: xxxxxxxxx HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk27 Initializing security card... Card Serial Number: xxxxxxxx Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 4,93v PASSED MCU Voltage 3,29v PASSED Core Voltage 1,78v PASSED VBAT Voltage 0,01v PASSED VBAT Voltage 4,86v PASSED Box VPP disabled VPP Voltage 0,04v PASSED Internal Box VPP Enabled VPP Voltage 4,83v PASSED Box VPP disabled VPP Voltage 0,04v PASSED External Box VPP Enabled VPP Voltage 0,02v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work Processing pre flash tasks... Pre flash tasks finished, continuing... Processing RM-675_014.002_79.92_prd.core.fpsx (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000030000022600010007600C192102031104 CMT_EM_ASIC_ID: 00001040 CMT_EM_ASIC_ID: 00001030 CMT_PUBLIC_ID: 1840010EA5A60344DDF862FED5C813A9D0AAA6D0 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 916F75217F32081248B15C38DFC8E81B CMT_BOOT_ROM_CRC: E693EF0D CMT_SECURE_ROM_CRC: AC22615B CMT Ready! RM-675_014.002_79.92_prd.core.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5 Searching for BootCode: DualLine 32Bit RAPUv11_2nd.fg, Type: 2nd Boot Loader, Rev: 768.11.16.0, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0000000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC006800000131, Samsung, ONENAND Requested Algorithm: XSR 1.6 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0068 (Samsung), Size: 1024MBytes, VPP: Not Supported RAPUv11_XSR17_alg.fg, Type: Algorithm, Rev: 768.11.16.0, Algo: XSR 1.6 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 95A68E9FA27B2BFA89EA204FC846EB73DEF1D93F Flashbus Write baud set to 5.0Mbits Sending Certificates... Certificates OK Partitioning... Partitioning OK Started group flash erase EraseArea[0,CMT]: 0x00040000-0x0007FFFF, ONENAND EraseArea[0,CMT]: 0x000C0000-0x008BFFFF, ONENAND EraseArea[0,CMT]: 0x00DC0000-0x0E97FFFF, ONENAND EraseArea[0,CMT]: 0x2E100000-0x3E5FFFFF, ONENAND Erase Partition (CMT) Waiting 320s for erasure finish... Erase taken 2.94s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT ADA Certificate... Writing CMT KEYS Certificate... Writing CMT PRIMAPP Certificate... Writing CMT RAP3NAND Certificate... Writing CMT SOS+PMML Certificate... Writing CMT PASUBTOC Certificate... Writing CMT PAPUBKEYS Certificate... Writing CMT GENIO_INIT Certificate... Writing CMT SOS*UPDAPP Certificate... Writing CMT SOS*DSP0 Certificate... Writing CMT LDSP Certificate... Writing CMT SOS*ISASW Certificate... Writing CMT SOS+CORE Certificate... Writing CMT SOS+ROFS1 Certificate... Programming Status OK! All blocks written OK! Time taken 182.485s Flashing Speed: 5935,40 kBit/S Restarting MCU... Processing RM-675_014.002_79.92_prd.core.fpsx (APE)... Processing RM-675_014.002_11.01_Hispania_79.92_prd.rofs2.fpsx (CMT)... Booting CMT... Failed to Boot CMT -> CMT Not Responding, Phone or Cable problem Processing Flash Image Failed -> Failed to Boot CMT Failed to Process all Image files -> Failed to process RM-675_014.002_11.01_Hispania_79.92_prd.rofs2.fpsx LOG Code: Handling device: [Cyclone Team], [Cyclone Bootloader] Handling device: [Cyclone Team], [Cyclone Box] Initializing box... Box Firmware: Cyclone Nokia Application v01.62, (Jun 5 2011 22:22:07, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2011 Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number: XXXXXXX HW Revision: A, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2009, wk27 Initializing security card... Card Serial Number: XXXXXX Card Firmware Revision: 0109 Card is activated Box is activated Started box selftests procedure USB Voltage 4,84v PASSED MCU Voltage 3,28v PASSED Core Voltage 1,79v PASSED VBAT Voltage 1,37v PASSED VBAT Voltage 4,82v PASSED Box VPP disabled VPP Voltage 0,04v PASSED Internal Box VPP Enabled VPP Voltage 4,83v PASSED Box VPP disabled VPP Voltage 0,04v PASSED External Box VPP Enabled VPP Voltage 0,04v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE Initializing FBUS... All initialized - Ready to work MCU Version V 92PS1_10w46.9 MCU Date 01-03-11 Product RM-675 (Nokia C7-00) Manufacturer (c) Nokia IMEI 353755049424668 Mastercode 552134146 IMEI Spare 3A35570594246406 IMEI SV 3335570594246406F8000000 PSN CJP322830 Product Code 059D0B0 Module Code 0204505 Basic Product Code 0591401 PSD 0000000000000000 LPSN 0 WLAN MAC 942053DAF32D APE SW 014.002 APE Variant 014.002.00.01 APE Test rm675_ENO_v_0.0308 APE HW 256 APE ADSP 256 APE BT HCI Version 4 (rev. 0). LMP Version 4 (rev. 7455). Manufacturer 13. RETU 40 TAHVO 00 AHNE 11 HW 6010 PCI o256qHDHCI Version 4 (rev. 0). LMP Version 4 (rev. 7455). Manufacturer 13.n256i014.002j014.002.00.01krm675_ENO_v_0.0308¥RM675_006_000_M007, UEM 256qHDHCI Version 4 (rev. 0). LMP Version 4 (rev. 7455). Manufacturer 13.n256i014.002j014.002.00.01krm675_ENO_v_0.0308¥RM675_006_000_M007, RFIC |Alli_4.3.4 DSP TB92PS1_10w46.4o256qHDHCI Version 4 (rev. 0). LMP Version 4 (rev. 7455). Manufacturer 13.n256i014.002j014.002.00.01krm675_ENO_v_0.0308 LCD 256qHDHCI Version 4 (rev. 0). LMP Version 4 (rev. 7455). Manufacturer 13.n256i014.002j014.002.00.01krm675_ENO_v_0.0308 ADSP DevID 256qHDHCI Version 4 (rev. 0). LMP Version 4 (rev. 7455). Manufacturer 13.n256i014.002j014.002.00.01krm675_ENO_v_0.0308¥RM675_006_000_M007, ADSP RevID 256qHDHCI Version 4 (rev. 0). LMP Version 4 (rev. 7455). Manufacturer 13.n256i014.002j014.002.00.01krm675_ENO_v_0.0308¥RM675_006_000_M007, Simlock Server SIMLOCK SERVER Simlock Key 2140100000000000 Simlock Profile 0000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 21401F Simlock [2,1] State: CLOSED Type: MCC-MNC Data: 21401F Processing pre flash tasks... Pre flash tasks finished, continuing... Processing RM-675_014.002_79.92_prd.core.fpsx (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000030000022600010007600C192102031104 CMT_EM_ASIC_ID: 00001040 CMT_EM_ASIC_ID: 00001030 CMT_PUBLIC_ID: 1840010EA5A60344DDF862FED5C813A9D0AAA6D0 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 916F75217F32081248B15C38DFC8E81B CMT_BOOT_ROM_CRC: E693EF0D CMT_SECURE_ROM_CRC: AC22615B CMT Ready! RM-675_014.002_79.92_prd.core.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5 Searching for BootCode: DualLine 32Bit RAPUv11_2nd.fg, Type: 2nd Boot Loader, Rev: 768.11.16.0, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0000000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC006800000131, Samsung, ONENAND Requested Algorithm: XSR 1.6 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0068 (Samsung), Size: 1024MBytes, VPP: Not Supported RAPUv11_XSR17_alg.fg, Type: Algorithm, Rev: 768.11.16.0, Algo: XSR 1.6 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 95A68E9FA27B2BFA89EA204FC846EB73DEF1D93F Flashbus Write baud set to 5.0Mbits Sending Certificates... Certificates OK Partitioning... Partitioning OK Started group flash erase EraseArea[0,CMT]: 0x00040000-0x0007FFFF, ONENAND EraseArea[0,CMT]: 0x000C0000-0x008BFFFF, ONENAND EraseArea[0,CMT]: 0x00DC0000-0x0E97FFFF, ONENAND EraseArea[0,CMT]: 0x2E100000-0x3E5FFFFF, ONENAND Erase Partition (CMT) Waiting 320s for erasure finish... Erase taken 2.93s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT ADA Certificate... Writing CMT KEYS Certificate... Writing CMT PRIMAPP Certificate... Writing CMT RAP3NAND Certificate... Writing CMT SOS+PMML Certificate... Writing CMT PASUBTOC Certificate... Writing CMT PAPUBKEYS Certificate... Writing CMT GENIO_INIT Certificate... Writing CMT SOS*UPDAPP Certificate... Writing CMT SOS*DSP0 Certificate... Writing CMT LDSP Certificate... Writing CMT SOS*ISASW Certificate... Writing CMT SOS+CORE Certificate... Writing CMT SOS+ROFS1 Certificate... Programming Status OK! All blocks written OK! Time taken 182.438s Flashing Speed: 5936,93 kBit/S Restarting MCU... Processing RM-675_014.002_79.92_prd.core.fpsx (APE)... Processing RM-675_014.002_11.01_Hispania_79.92_prd.rofs2.fpsx (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000030000022600010007600C192102031104 CMT_EM_ASIC_ID: 00001040 CMT_EM_ASIC_ID: 00001030 CMT_PUBLIC_ID: 1840010EA5A60344DDF862FED5C813A9D0AAA6D0 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 916F75217F32081248B15C38DFC8E81B CMT_BOOT_ROM_CRC: E693EF0D CMT_SECURE_ROM_CRC: AC22615B CMT Ready! RM-675_014.002_11.01_Hispania_79.92_prd.rofs2.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5 Searching for BootCode: DualLine 32Bit RAPUv11_2nd.fg, Type: 2nd Boot Loader, Rev: 768.11.16.0, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0000000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC006800000131, Samsung, ONENAND Requested Algorithm: XSR 1.6 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0068 (Samsung), Size: 1024MBytes, VPP: Not Supported RAPUv11_XSR17_alg.fg, Type: Algorithm, Rev: 768.11.16.0, Algo: XSR 1.6 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 95A68E9FA27B2BFA89EA204FC846EB73DEF1D93F Flashbus Write baud set to 5.0Mbits Started group flash erase EraseArea[0,CMT]: 0x09F40000-0x0DA7FFFF, ONENAND Waiting 320s for erasure finish... Erase taken 0.266s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT SOS+ROFS2 Certificate... Programming Status OK! All blocks written OK! Time taken 60.172s Flashing Speed: 6031,48 kBit/S Restarting MCU... Processing RM-675_014.002_11.01_Hispania_79.92_prd.rofs2.fpsx (APE)... Processing RM-675_014.002_206.06_VF_ES_79.92_prd.rofs3.fpsx (CMT)... Booting CMT... CMT_SYSTEM_ASIC_ID: 000000030000022600010007600C192102031104 CMT_EM_ASIC_ID: 00001040 CMT_EM_ASIC_ID: 00001030 CMT_PUBLIC_ID: 1840010EA5A60344DDF862FED5C813A9D0AAA6D0 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: 916F75217F32081248B15C38DFC8E81B CMT_BOOT_ROM_CRC: E693EF0D CMT_SECURE_ROM_CRC: AC22615B CMT Ready! RM-675_014.002_206.06_VF_ES_79.92_prd.rofs3.fpsx, Type: Flash Image, Algo: XSR 1.6, BB5 Searching for BootCode: DualLine 32Bit RAPUv11_2nd.fg, Type: 2nd Boot Loader, Rev: 768.11.16.0, Algo: BB5 Flashbus Write baud set to 650Kbits Flashbus Read baud set to 98Kbits Using NEW BB5 FLASHING PROTOCOL Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 If software STUCK HERE with box TX LED lit, that means: 1. You have not attached yellow TX2 Adapter (IT IS REQUIRED FOR BB5 PHONES WHEN USING JAF/UFS CABLES!) 2. Your cable is not TX2 Enabled! 3. Transmission error occured, try again In either cases, you need to reconnect your box from USB. FlashChip[0,CMT]: 0x0000000000000000, Unknown, RAM FlashChip[0,CMT]: 0xFFFF000000000000, Unknown, MMC FlashChip[0,CMT]: 0x0000000000000000, Unknown, NOR FlashChip[1,CMT]: 0x0000000100000000, Unknown, NOR FlashChip[0,CMT]: 0x00EC006800000131, Samsung, ONENAND Requested Algorithm: XSR 1.6 (CMT) Searching for BootCode: DualLine 32Bit FlashChip 0x00EC0068 (Samsung), Size: 1024MBytes, VPP: Not Supported RAPUv11_XSR17_alg.fg, Type: Algorithm, Rev: 768.11.16.0, Algo: XSR 1.6 Initializing TurboCache... TurboCache Loaded! Writing CMT PASUBTOC Certificate... Writing CMT ALG Certificate... CMT Algorithm Ready! Default Transmission Mode Requested by Loader: Dual Line, 32 bit, Overriding Transmission Mode Requested: Dual Line, 32 bit, Accepted: Dual Line, 32 bit Box TX2 Data Pin set to: Service Pin 3 Adding FUR Client (CMT, State: Ready)... CMT FUR Ready! Box VPP disabled Internal CMT Phone VPP Enabled PAPUBKEYS Hash for CMT: 95A68E9FA27B2BFA89EA204FC846EB73DEF1D93F Flashbus Write baud set to 5.0Mbits Started group flash erase EraseArea[0,CMT]: 0x0DA80000-0x0E97FFFF, ONENAND Waiting 320s for erasure finish... Erase taken 0.78s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT SOS+ROFS3 Certificate... Programming Status OK! All blocks written OK! Time taken 3.578s Flashing Speed: 5592,14 kBit/S Restarting MCU... Processing RM-675_014.002_206.06_VF_ES_79.92_prd.rofs3.fpsx (APE)... All images processed OK! Processing post flash tasks... Setting Factory Defaults... Factory defaults OK Reading info... MCU Version V 92PS1_10w46.9 MCU Date 01-03-11 Product RM-675 (Nokia C7-00) Manufacturer (c) Nokia IMEI 35375504XXXXXX Mastercode 552134146 IMEI Spare 3A35570594246406 IMEI SV 3335570594246406F8000000 PPM 256qHDHCI Version 4 (rev. 0). LMP Version 4 (rev. 7455). Manufacturer 13.n256i014.002j0)014.002.00.01014.002.11.01014.002.206.06krm675_ENO_v_0.0308 PSN CJP322830 Product Code 059D0B0 Module Code 0204505 Basic Product Code 0591401 PSD 0000000000000000 LPSN 0 WLAN MAC 942053DAF32D APE SW 014.002 APE Variant 014.002.00.01014.002.11.01014.002.206.06 APE Test rm675_ENO_v_0.0308 APE HW 256 APE ADSP 256 APE BT HCI Version 4 (rev. 0). LMP Version 4 (rev. 7455). Manufacturer 13. RETU 40 TAHVO 00 AHNE 11 HW 6010o256qHDHCI Version 4 (rev. 0). LMP Version 4 (rev. 7455). Manufacturer 13.n256i014.002j0)014.002.00.01014.002.11.01014.002.206.06krm675_ENO_v_0.0308 PCI o256qHDHCI Version 4 (rev. 0). LMP Version 4 (rev. 7455). Manufacturer 13.n256i014.002j0)014.002.00.01014.002.11.01014.002.206.06krm675_ENO_v_0.0308 RFIC |Alli_4.3.4 DSP TB92PS1_10w46.4o256qHDHCI Version 4 (rev. 0). LMP Version 4 (rev. 7455). Manufacturer 13.n256i014.002j0)014.002.00.01014.002.11.01014.002.206.06krm675_ENO_v_0.0308¥RM675_006_000_M007, ADSP Sw 256qHDHCI Version 4 (rev. 0). LMP Version 4 (rev. 7455). Manufacturer 13.n256i014.002j0)014.002.00.01014.002.11.01014.002.206.06krm675_ENO_v_0.0308 ADSP DevID 256qHDHCI Version 4 (rev. 0). LMP Version 4 (rev. 7455). Manufacturer 13.n256i014.002j0)014.002.00.01014.002.11.01014.002.206.06krm675_ENO_v_0.0308 Flip MCUSW 256qHDHCI Version 4 (rev. 0). LMP Version 4 (rev. 7455). Manufacturer 13.n256i014.002j0)014.002.00.01014.002.11.01014.002.206.06krm675_ENO_v_0.0308¥RM675_006_000_M007, Simlock Server SIMLOCK SERVER Simlock Key 2140100000000000 Simlock Profile 0000000000000000 Simlock Key Cnt 0 Simlock FBUS Cnt 0 Simlock [1,1] State: CLOSED Type: MCC-MNC Data: 21401F Simlock [2,1] State: CLOSED Type: MCC-MNC Data: 21401F Read info thread finished, continuing... Post flash tasks finished! Flashing successfully finished! Last edited by ptt; 06-23-2011 at 22:12. Reason: ADD CODE TAG |
06-23-2011, 19:33 | #3 (permalink) |
Member: 1092309 Status: Offline Sonork: 1001606496 Thanks Meter: 52 | thank you my sir for reply,but i have any problem in my cable,i have flashed my phone correctly with same cable and it·s working fine with v1.14 but with latest v1.15 i got error in FBUS booting.please check if latest version have bug.with this thread just i want helping not spaming. And never the student know better than his teatcher and i am very gratful to you my sir. |
Help: Forgot my 6110 user lock code!! | GByte9 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 02-26-2016 14:52 |
Anybody know solution | Robi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 12-10-2014 12:35 |
PIN1/PIN2 CODE | Jon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 12-26-2012 04:40 |
Solution for GSM phones!?!?!?!? | todosije | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 12-16-2010 05:52 |
!!!!!!TO ALL NOKIA 51XX/61XX SP LOCKS 1,2,3,4 SOLUTION latest news!!!!! | spterminator | Main Sales Section | 2 | 08-13-1999 05:55 |
